Question about Maytag MDG9606 Dryer
Maytag dryer giving heat only for shor time
I have checked and cleaned all filters and ducts. Heats for awhile, then nothing. Otherwise, dryer is fine. What is this and can I fix it or do I need to call a repairman?
    President:
  • Maytag Master
  • 2,651 Answers
If heat works, and vent is definitely not an issue, i would look to replacing the valve coils(279834), the coils heating up and not allowing the valve to re-open on subsequent tries through length of cycle. $20 repair
Posted on Mar 03, 2008
Maytag DG410 gas dryer-no flame, no heat. I replaced the ignitor - that apparently isn't the problem. Other ideas?
Motor runs, but main burner will not ignite
1.heat switch set wrong---correct switch setting
2.defective timer or timer circuit---check timer wiring--replace timer motor or switch as needed
3.defective centrifugal switch in motor---clean switch or replace as needed
4.gas supply valve closed----open gas valve
5.inoperative solenoid coil---test coil for open circuit & the voltage to it
Pilot burner goes out
1.insufficient gas supply---- low gas pressure or clogged pilot filter or partially closed gas valve
2.carbon deposit on thermocouple tube---clean tube & check pilot burner for proper combustion
3.improperly adjusted pilot flame--adjust pilot flame until faint yellow tip begins to appear
4.faulty ignition or reset valve or thermocouple---replace
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag PYG4500A Gas Dryer
My maytag atlantis dryer heats up but on any cycle the dryer doesnt run long enough to dry the clothes i have to turn it on two or more times to dry clothes
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Mar 21, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag bravos mw3801309 spins, heats, no air coming out vent....??
heatman101
Mar 20, 2011 | Dryers
Dryer heats and runs a full cycle but doesnt dry clothes all the way.
If your
dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Dryer Maintenance
heatman101
Jan 24, 2011 | Maytag PYE2300AY Electric Dryer
Problem with the Maytag Neptune MDG6700A Gas Dryer WHEN STARTED HEATS UP THEN NO HEAT AT ALL. MAYTAG MDG6700AWW
Hello & Welcome to FixYa
When the dryer heats for few minutes and then it won't work it means that the thermostat is bad and needs replacement. This part is located on the blower wheel housing inside the duct, you can also check this part for continuity before replacing. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | Maytag Neptune MDG6700A Gas Dryer
Dryer heats up but close remain wet
heatman101
Nov 10, 2010 | Maytag Neptune MDE5500AY Electric Dryer
When dryer is off it was still heating now it heats but will not dry
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Nov 04, 2010 | Maytag MDE5806AY Electric Dryer
Gas will come on and heat for a few minutes and then go out
you either have bad gas coils if it heats for the first 15 to 30 minutes and then the flame doesn't lite any more or you need to clean out the dryer because there is a blocked vent line or duct stopping the air from moving through the dryer and then to the outside.you need to clean out the duct that the lint filter slides into,vac out the inside of dryer where the motor is and if the vent line is long i use a leaf blower to blow out the vent line.unplug the dryer when ever you're working on it
Jun 22, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer heats once or twice then stops heating
It's likely one of the coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. The number for the coil kit, which will replace ALL the coils, for your machine is 12001348.
Disconnect power and turn off gas before working on this dryer. Working on gas dryers is not recommended for people who are not professionals.
Service on gas appliances should be undertaken by professionals only due to the danger of gas leakage which can cause fires or death by asphyxiation.
The disassembly procedure is covered beginning on page 3-10 of the manual listed at the link below. Operation and replacement of coils is covered at page 3-32. Replace All coils with Kit Number listed above. Take care not to touch or hit the ignitor or you will be replacing it also. It is VERY brittle.
Reverse process to re-assemble. Good Luck
Maytag Dryer Service Manual
Sep 15, 2009 | Maytag Dryers
WILL NOT DRY
Check that the dryer duct at the back where it connects the dryer to the wall has not collapsed to restrict air movement to the house vent duct.
Check that the vent duct all the way to the outside of the house is not fully or partially restricted in any way.
Make sure the lint screen is clean.
Make sure there is no buildup of lint inside the dryer where the heat enter the drum.
You should be able to walk outside with the dryer running, and feel a blast of air exiting the dryer vent. If not, find the restriction.
A dryer warming up, and then shutting down is normally a sign of a restricted vent duct at some point in the system. Particularly if nothing is done, and the dryer heats up momentarily when the cycle is tried again.
Reply back your findings for further instruction or information.
Jan 29, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
93 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
