Question about Panasonic Lumix DMC-LZ2 Digital Camera
Lumix won't focus
Hello, My Lumix DMC-FX07 is not focusing. When I am trying to take a photo, it looks blurry through the viewfinder (LCD) even before I take it and the actual photo is blurry too. This started after I was trying to take several pictures in a pretty dark setting and trying different things with the flash.
Is this problem easily fixable, maybe by resetting the settings? How would I go about resetting?
Thanks!!!
  • katbetmark Aug 24, 2008
    lumix dmc-fx07 won't focus, and I am promted to turn camera off then on again. But it continues to be unable to focus, and get the same prompt. Also, the lens will not retract and close when camera is turned off.
  • debdegraf Sep 14, 2008
    same problem...blurry image and won't clearly focus in viewfinder . Photos turn out blurry as well.
SOURCE: Rebel XT pictures are in focus but look blurry in viewfinder
Use the little wheel dial with the +/- sign on it right on the viewfinder...ajust it until things are clear
Posted on Nov 26, 2007
cyrylthewolf
  • 143 Answers
SOURCE: Viewfinder is blurry
I have given DRHIFI a "Fixya" rating as this is the exact solution to the problem. (As shown in previous solutions I have given for the same issue.)
Tone down the CAPS though, buddy. :P
Cyryl
Posted on Dec 08, 2007
SOURCE: The viewfinder on my Canon PowerShot SX20 is blurry
Check the diopter adjustment on the left side of the viewfinder.
Posted on Dec 31, 2009
  • 11967 Answers
SOURCE: Panasonic Lumix DMC FX 33 wont focus and shows
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Feb 23, 2010
lock123
  • 6831 Answers
SOURCE: my panasonic lumix DMC-FS15 won't
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. Please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 10, 2010
Problem with viewfinder - focus?! I've been using my Nikon d3000 for over a year now. Few days ago I tried to take a photo but when looking through the viewfinder, the photo wasn't focused. It was...
There's a diopter control near the viewfinder to adjust the viewfinder to your eye. Try adjusting that while peering into the viewfinder and try to get the focus brackets and the data at the bottom of the viewfinder into focus.
Jun 20, 2011 | Nikon D3000 Digital Camera
The electronic viewfinder will not focus. Photo results, however, are properly focused. LCD properly focuses, but I prefer to frame my pics using viewfinder. What's the fix?
There's a diopter adjustment control near the viewfinder. Adjust it while peering through the viewfinder until the image suits your eyes.
Sep 10, 2010 | Panasonic Lumix DMC-FZ28 Digital Camera
Lumix Panasonic DMC FZ28 18x optical zoom, 27mm wide pix always out of focus... what could be the problem? thanks!
Does it make 2 beeps and have a green spot in the center of viewfinder/lcd? if so it is thinking it is focused, test this to see. If it is 2 beeps but definitely out of focus, it will need to go in for a back-focus alignment. Simple operation for the repair team.
Sep 21, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
I have a Panasonic Lumix DMC FX07. My photos are blurry 90% of the time. What are the best settings to put in on to get the best quality?
I have looked around, and it appears that there are others with the same problem, with that same model. Either the camera has an issue, or there are picky settings on the camera.
Start with the obvious. Make sure the lens is very clean. Use lens tissue, or a very soft, lint free cloth. Try that first and see if there is any difference.
When you are taking pictures, take advantage of focus lock. You center the subject you are focusing on, then push down the shutter button half way. Then while holding it half way, you can reposition the camera and take the picture. The focus will lock on whatever you first clicked on. It works really cool.
Make sure the stabalizer is turned on, the little hand with lines around it, like shake.. Make sure that is on 1 or 2 mode and not turned off. Try all three and experiment with that.
Lastly, make sure you use your scene modes. Moving subjects need the sports mode, people portrait mode, etc. That adjusts the shutter speed and lens opening for the right type of photo.
If you have Adobe Reader, here is a link to your manual, you can download it to your computer.
http://www.olympusamerica.com/files/Stylus740_750InstructionManual.pdf
I hope this helps!
Paul
Apr 17, 2009 | Panasonic Lumix DMC-FX07T Digital Camera
Looking for viewfinder is blurry (Panasonic Lumix DMC FZ28)
There's a small dial on the left side of the viewfinder (next to the flash button) that allows you to focus the viewfinder. I only found it because I had the same problem - must have knocked it out of focus by accident!
Apr 07, 2009 | Panasonic Lumix DMC-LZ2 Digital Camera
My camera is panasonic lumix dmc-fx 50
hello psdubbs, maybe you should reset the function parameters, they could have been changed.
Jun 25, 2008 | Panasonic Lumix DMC-LZ2 Digital Camera
Viewfinder focus
Mickykay,
Have you tried focusing the diopter? The focus wheel is just left of the viewer. If you know all this then consider one more thing. There is a plus and minus setting for your eye so roll the wheel slowly to not miss the sweet spot for your vision. goodeye
Jan 13, 2008 | Panasonic Lumix DMC-FZ50K Digital Camera
Photoes are not sharp
Hi, I have never had focus problems with my FX7. I suggest you set the AF mode to 1-area-focusing. This mode is quicker than the 9-area-focusing. To eliminate any possibility that the blurry photos are caused by camera shake, I also suggest placing the camera on a tripod (or setting it down on a flat surface) and using the self-timer to release the shutter. At this point you can also turn off the image stabiliser. A well lit outdoor subject is probably preferable for this test, as low contrast scenes sometimes cause the auto focus problems. If the photos under these conditions are still blurry, then you probably have a defective autofocus. Otherwise...
Sep 04, 2005 | Panasonic Lumix DMC-FX7 Digital Camera
Panasonic Lumix DMC-LZ2 Digital Camera Logo
582 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
