Question about Canon PIXMA MP460 All-In-One InkJet Printer
Paper misfeed Printer about 1 year old. Never a problem before but today it takes multiple sheets of paper at a time and then jams. If I feed a single sheet printer takes in in crooked. I have done all of the maintenance. Very frustrating. HELP.
  • 1 more comment
  • luaulou May 08, 2008
    I have the exact same problem. My printer is also about a year old
  • yodelius Jun 04, 2008
    Also had my mp460 just over one year. Paper feeds crooked; one side grabbed before the other, big ink mess.
  • Anonymous Oct 17, 2008
    Same thing, paper misfeed. Just over a year old pulls paper at one side and jams.
My solution may not address the problem for others, but in looking for what was wrong, I began to turn the printer over for a better view and a pencil fell out! After that, no problem.
Posted on Oct 14, 2008
I took it in for repair. I was told that the roller that takes up the paper was bad, The cost to repair it would cost just as much a new printer.
Misfeed- cleared, but still says misfeed is there
Hi
1st when using transparency paper U must set up the printer propreties to paper kind U use.
for now do the sim. 30 -1 to see hows sensor is detected bi touche
Jun 16, 2014 | Sharp MX-2700N Color Copier
My Lexmark 4600 printer has a paper jam. do not know how to unjam it.
How to clear and avoid paper jams
Follow these instructions to remove and/or avoid paper jams and misfeeds in your Lexmark X3500, X4500, X4600 & X4800 Series All-In-One.
Paper jam in the printer
Remove the paper manually
  1. Press pattlnk_10282008_1820-power-icon.gif to turn off the printer.
  2. Firmly grasp the paper, and gently pull it out.
  3. Press pattlnk_10282008_1820-power-icon.gif to turn the printer back on.
NOTE: Check inside the printer to ensure that all the paper is removed. Any small pieces of paper left in the printer will continue to cause paper jams.
Paper jam in the paper support
Paper or specialty media misfeeds
These are possible solutions if paper or specialty media misfeeds or skews, or if multiple sheets feed or stick together.
Try one or more of the following:
Check paper condition
  • Use only new, unwrinkled paper.
Check paper loading
  • Load a smaller amount of paper into the printer.
  • Load paper with the print side facing you. (If you are not sure which side is the printable side, see the instructions that came with the paper.)
Remove each page as it is printed
  • Remove each page as it exits, and let it dry completely before stacking.
Adjust the paper guides
  • When using media less than 8.5 inches wide
  • To rest against the edges of the paper or media, making sure it does not buckle
Printer does not feed paper, envelopes, or specialty media
These are possible solutions. Try one or more of the following:
Check for paper jams
  • Check for and clear any paper jams. For more information, see "Paper jam in the printer" and "Paper jam in the paper support" above.
Check media loading
  • Verify that the specialty media is loaded correctly.
  • Try loading one page, envelope, or sheet of specialty media at a time.
Check printer default and pause settings
  1. Click:
    • In Windows XP (default Start menu): Start pattlnk_10282008_1829-right-arrow.gif Printers and Faxes.
    • In Windows XP (Classic Start menu): Start pattlnk_10282008_1829-right-arrow.gif Settings pattlnk_10282008_1829-right-arrow.gif Printers and Faxes.
    • In Windows Vista (default Start Menu): pattlnk_10282008_1829-vista-start-button.gifpattlnk_10282008_1829-right-arrow.gifControl Panel pattlnk_10282008_1829-right-arrow.gif Printers (under Hardware and Sound).
    • In Windows Vista (Classic Start menu): pattlnk_10282008_1829-vista-start-button.gifpattlnk_10282008_1829-right-arrow.gif Settings pattlnk_10282008_1829-right-arrow.gif Printers.
  2. Double-click the print queue device.
  3. Click Printer.
    • Make sure no check mark appears next to Pause Printing.
    • If a check mark does not appear next to Set As Default Printer, you must select the print queue device for each file you want to print.
Banner paper jams
There are many possible solutions. Try one or more of the following:
Clear banner paper jams
  2. Remove the jammed banner paper from the printer.
Review banner printing checklist
  • Use only the number of sheets needed for the banner.
  • Select the following settings to enable the printer to feed paper continuously without jamming:
    1. With a document open, click File pattlnk_10282008_1829-right-arrow.gif Print.
    2. Click Properties, Preferences, Options, or Setup.
    3. Select the Paper Setup tab.
    4. From the Paper Size area, select Banner.
    5. Select Letter Banner or A4 Banner as the paper size.
    6. Select Portrait or Landscape.
    7. Click OK.
    8. Click OK or Print.
Regards,
Ron
Mar 26, 2011 | Lexmark 4600 Multi Function Printer Option...
Hi Canon LBP 1120 paper feed and paper jam problem: My Printer mostly take in multiple paper sheets instead of taking just one sheet. Sometimes the extra sheets are taken in while the printing sheet...
You need new pickup rollers
google search "LPB1120 pickup rollers" and find your nearest dealer. usualy quite easy to replace as long as your a "can do" person
Mar 18, 2011 | Canon LBP 1120 Laser Printer
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    Paper keeps shifting during loading and eventually gets jammed every time
    Seems like the rollers are either dirty, or worn out. Probably the latter.
    “Paper jams” on page 68
    “Paper or specialty media misfeeds” on page 68
    “Printer does not feed paper, envelopes, or specialty media” on page 69
    “Banner paper jams” on page 69
    Paper jams
    Is the jam in the paper
    support?
    1 Press to turn off the printer.
    2 Firmly grasp the paper, and gently pull it out.
    3 Press to turn the printer back on.
    Is the jam in the printer? To automatically eject the paper:
    2 Press again to turn the printer back on.
    The paper automatically ejects from the printer.
    To manually remove the paper:
    If paper or specialty media misfeeds or skews, or if multiple sheets feed or stick together, try the following solutions.
    Check paper
    condition
    Check paper loading Load a smaller amount of paper into the printer.
    See “Loading various paper types” on page 21 for information about:
    Maximum loading amounts per paper type
    Specific loading instructions for supported paper and specialty media
    Troubleshooting
    68
    Remove each page as
    it is printed
    Adjust the paper
    guides
    Adjust the paper guides:
    Jul 22, 2010 | Lexmark X2500 All-In-One Printer
    While printing with OKI C5600 very often error message pops up about jammed paper though no REAL jam happened. To solve I just open and close paper tray and front door. JAM PAPER error is real pain if...
    Have you tried cleaning the paper feed roller(s)? Either soap & water OR isopropyl alchohol with a cotton ball will do, just make sure the rollers are dry before trying to print again, otherwise damage to imaging unit (drum/toner unit) could occurr. If the printer doesn't feed in the first place, the printer thinks it has a jammed paper, thus opening paper tray and front cover resets misfeed/ jam condition. Let me know your progress....Tim
    Oct 24, 2009 | OKI C5500n Printer
    My laserjet 1020 develops a paper jam after printing the first page of a multipage print instruction .I have deleted the printer and re-installed it including all drivers but problem still...
    Reinstalling the printer is related the Software.
    If the paper gets physically jammed than its the driver setting issue or hardware issue.
    Check if two sheets get jammed or only one sheet.
    If it is two sheets than printer is picking up multiple sheets and paper gets jammed.
    If the printer is jamming a single sheet than remove the Tray and look there is rubber roller inside if there are marks or lines on that rubber roller or if the roller roller is worn out than that rubber roller called as paper pickup roller need to be replaced.
    If that looks fine than try to priny using manual feed and if the problem persists from manual feed too than try another toner cartridge
    If the problem is not from Manual feed Tray that Replace the main Tray with known good Tray and check if the issue resolved.
    Jul 01, 2009 | HP LaserJet 1010 Printer
    HP paper jam
    That is usually caused by the paper feed rollers being cover with paper dust. Take a clean cotton pad and alcohol and clean the rollers :turninig each roller as you clean it. if it has a rear dor, open it to get better access to the rollers.
    Please remember to rate all users who assist you for free :)
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Sep 03, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
    Paper Misfeed Problem
    When you close the doors does the message disappear? If so then the paper pickup roller is worn. Open the cassette remove all paper apart from one sheet. Spray a alcohol based cleaned on the leading edge of the paper. Try and do a copy this will issue a jam and also clean the pickup roller. repeat a few times then clean out the cassette and dry off place new paper in the cassette and try. Also there maybe a piece of paper behind the cassette. Remove cassette and reach in and remove paper lodged at back.
    Thanks Jason
    Aug 16, 2008 | Office Equipment & Supplies
    Pohot paper jamming in Brother DCP-115C printer
    This is a common error of this printertype. Please use only paper of max. 220g. There is no problem reported with that.
    Jan 14, 2007 | Brother DCP-110C All-In-One InkJet Printer
    Canon PIXMA  MP460 All-In-One InkJet Printer Logo
    202 people viewed this question
    old marine
    old marine
