Question about EPoX EP-4PLAI Motherboard
Cant run an you give me an idea how to fix my pc problem?its difficult to me to understand because my pc have a long beep again even i clean the memory and connect it again in the slot1 and slot 2 but when i tried to clean my memory and video card with eraser of a pencil sometimes i heard a long beep and sometimes it have no beep but no appearance on the screen?pls help me to solve this my memory is tested by memtest and no error was detected and is new with warranty
  • enigma pulp Mar 03, 2008
    Problem Solver:
  • 17 Answers
Kindly check the placement of your memory card if it is place correctly. it should fixed firmly and tightly. If there is an error again, try to check your video card if there something damage or anything there. and if there is no other way, clean it again and try to dry them up with hair dryier but check the temperature for safety.
me reynald from philippinse..tnx
Posted on Mar 03, 2008
  • 113 Answers
Find an old graphics card (maybe the swapmeet) and try that. When installing the devices hold cards from both ends and push in evenly. The problem is most likely installation.
Count the beeps and which ones are long and short.
For example: two long beeps and three short ones.
Then in google lookup your bios beep codes.
For example: Award beep codes
There you will get a definite answer to what is ailing your machine.
2 Suggested Answers
SkullyFox
  • 93 Answers
SOURCE: help!!!!!!
if ram is ok, check processor and PCI devices, if these are all ok chances are your motherboard is dead
Posted on Apr 02, 2008
My m/b is Compaq BL30G and recently i had to reinstall winXP and it automatically installed audio driver (intel(r) 82801BA/BAM AC`97) but now it gives a continues "beep" sound. I even tried...
First of all open your chassis and then reconnect all the connection and remove hard drive. If you have two RAM in your PC then remove one RAM Now plug the power supply and ON the machine. If it is giving beep sound then press esc again and again untill the beep sound could be stopped. If it is continuous then remove the RAM and fix the other one then ON the machine And if it is giving beep sound the press esc again and again. Before fixing the RAM you have to clean the RAM with a soft cloth smoothly. I hope this can work for you ! and beep sound is stopped then attach your HDD then ON the PC
Sep 14, 2011 | Abit BL7-RAID Motherboard
Acer aspire T180 wont start screen says no signal input computer is beeping cant tell beep code possibly 2 long beeps repeated or just one long beep repeated
Remove the side panel and remove the RAM.
Clean the RAM slot with dry brush or cloth.
Clean the RAM.
Fix the RAM back in the slot.
Close the cover and Start the PC
If you feel that my answers have helped you getting solution to your problems then please give a vote.
Thanks.
Jul 13, 2011 | Acer Aspire™ T180 PC Desktop
My Dell Inspiron E1705 PC Notebook two light just blinks and doesnot boot
make sure the ram is properly installed just remove ram and check it give the beeps if it gives the beep that means board is ok clean the ram with pencil eraser and fix it again.
Have a nice day and do not forget to rate please...!
Dec 27, 2010 | Dell Inspiron E1705 Notebook
My e-machines etower 633is won't boot up. The beginning black screen comes up then the E-machines screen and that's as far as it will go. It gets stuck there. Can you give me some idea what is causing...
I cant really seem to understand but if the computer beeps then you should take the RAM out and clean it and re-insert it. and try again. Sometimes the processor can give that kind of problem if it is faulty.But if after cleaning the RAM it still doesnt work please take it to the tech department.
I hope this solution is helpful.
Sep 26, 2010 | E-Machines etower 633is PC Desktop
Hp tower will not reboot
Sorry to hear you're having problems.
As simple as it sounds - remove the cover and blow out the system.
I hear that Best Buy and Staples are giving free check ups. I would check with them for the freebee and not tell them it isn't booting. Just an idea - sneaky in a way but I have had pc's not boot and them after a cleaning boot right up.
This isn't a permanent fix you understand.
Best of it
Rice
Mar 28, 2010 | HP Compaq dx2300 Microtower - RT950UTABA...
I AM GETTING AN ERROR MESSAGE E01 CAN'T MAKE IT QUIT BEEPING
Hi. If it is a Casio, it means you haven't finished what you were doing in the previous mode before you turned the key. You need to turn the key back to where it stops giving the error, then finish in that mode. otherwise, let me know the brand and model
Dec 18, 2009 | Casio Parts Cash Register PC Desktop
Computer dead and beeping
If it beeps and not boot then it is the post routine telling you there is a problem. The post routine is run when you turn the power on to ensure the computer hardware is ok to run. The manufacturer of the bios routine can tell what is wrong by the type, number and duration of the beeps. Look up the code meanings and it will indicate the problem. If this sounds like nonsense to you then give the make and model of your machine and what the beeps sound like. ( beep beep beep delay beep beep beep) etc. and I'll look it up for you.
Aug 10, 2009 | Computers & Internet
Acer Aspire T180 wouldn't turn on...
Hi again.
It's the memory thats the problem, continuous beeps indicate a memory failure, take the system memory out and clean the contacts and the slots with a dry, clean paintbrush. Re-seat the memory and re-start the machine. If you still get beeps post back.
Good luck!!
Feb 15, 2009 | Acer Aspire™ T180 PC Desktop
Beeps on startup
plz check with the RAM...
open the cabinet... and try taking out the ram and clean it with a smooth cloth... fix it back again...and start your computer...
this should resolve your problem...
Jan 13, 2009 | Microsoft CyberpowerPC Gamer Infinity 7511...
Help!!!!!!
hi jake_ponce,
first step: just check the ram with ur friend pc if he has good pc if the ram starts in ur friend pc it means ur pc does not support ram of high speed
second steps; beep is coming again the problem will be in a motherboard
third steps : beep is coming again remove ur cmos battery & try again if again beep is coming than ur ram is burn
Fourth steps:beep is coming thantake it to the shop & tell him is not working
Fifth steps: it has a warranty the shopkeeper will replaced it
regards
shailesh
Mar 02, 2008 | EPoX EP-4PLAI Motherboard
EPoX EP-4PLAI Motherboard Logo
106 people viewed this question
Top EPoX Computers & Internet Experts
Marvin
Marvin
David
David
Steven Wander
Steven Wander
Are you an EPoX Computer and Internet Expert? Answer questions, earn points and help others
