Open the dryer door. There should be approximately three screws that hold the hinges on there on the right side (as you said yours currently is a left to right opening). Remove the screws that hold the door on. As you hold the dryer door removed from the dryer, turn it counter clockwise so that the handle is now on the opposite side. Lay it on the floor. Now, remove the screw hole covers from the opposite side of the dryer opening ( the left side) (these can be removed with a fingernail or a thin flat tipped screw driver to pry them out). This will expose the screw holes on the opposite (left)side of the dryer. Take the removed covers and place them in the original screw holes on the right side. Now simply reinstall the door hinges in the newly exposed screw holes on the left side. This will only work if your dryer is designed to have both types of openings. Good Luck!
