Question about Nikon D50 Digital Camera
The flash unit for my D50 doesn't pop up automatically
Oddly enough, when I put my d50 on auto flash, the flash does go out, but the flash unit doesn't pop out, I need to detach it manually, and i can feel that the cam doesn't like that.
Any clue ?
  • 1 more comment
  • 9det Mar 28, 2008
    Thanks for the feedback.
    I'm going to the local Nikkon retailer in my town to ask for a full check up.
  • siobhanc32 May 22, 2008
    My D50 flash worked fine with a flash until I used an external flash recently at some wrestling meets. After this, although the meter is working, the flash itself is not popping open to work. Does this mean I need to take it into a repair store, and if so, how long does it normally take and what is approx cost?
  • 9det Oct 07, 2008
    I'll give it a quick try, thanks buddy !
  • 3 Answers
I HAVE YOUR ANSWER!!
Do you still hear the CLICK like you always do? If so this will work;
It is not a cam, but a hook release like a trigger group on a gun.
There is an adjustment for the flash POP-UP release.
But, to get at it you must first release the flash by moving this trigger release arm manually.
With the camera pointed forward (away from you, as in use) Slide a stiff, but not too thick piece of paper into the flash crease on the left side and move from rear to front.
Once it is up and released, you'll see the trigger hook. Look on the now released upper flash assembly.
There is a hex screw (use an allen key) next to the hole for this hook. That screw adjusts the height of the catch. Play with that, in and out, untill it releases on it's own.
Posted on Oct 07, 2008
    Scholar:
  • 105 Answers
The flash is spring-loaded and always "trying" to spring up. It is held down by a small lever that should disengage automatically when the flash is instructed to pop up either manually or in automatic mode. It sounds like the small lever has broken on the inside and will not release. The camera must be opened in order to repair this, and this should only be done by a qualified technician.
Posted on Mar 28, 2008
\my D50 is not following through when I press the shutter release on auto focus-am able to take a pic on manual. When pressed, the camera makes a whirring noise but does not finish
Your lens might have an issue caused by some sort of shock or impact. Before anything just try to gently turn the focus ring on the lens while on auto focus to see if it pops back into place. Sometimes this actually takes care of the issue. Just DON'T FORCE IT. If this doesn't solve your issue then contact a Nikon authorized service center because your lens is going to need repairs. Hope this helps!
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
Jul 07, 2011 | Nikon D50 Digital Camera with 18-55mm and...
How do you install a flash bracket to a nikon d50?
Most flash brackets screw into the tripod socket on the base of the camera. If your doesn't, please feel free to reply to this post, giving the make and model of your bracket.
Jun 17, 2011 | Nikon D50 Digital Camera with 18-55mm and...
The flashgun doesn't pop up when it should. It remains jammed.
Ok
Its not clear how you are using the camera.
Check the settings on the left. Some settings (Landscape for example will not allow the use of flash)
Set the camera to P,S,A OR M and it will. In Auto it will pop up if it needs it. It It still won't work Look at the menu settings for Flash Mode two settings 1) TTL and the other Manual. I have my D50 set to TTL using the built in flash and manual when using an external flash mounted in the shoe.
Hope this helps
Dec 12, 2009 | Nikon D50 Digital Camera
Nikon D50 -flash won't fire
Try pushing the flash forward just a tiny bit. this model of Nikon has a built in problem with the flash popping up too hard. You can also try to "soften" the pop-up action with your finger instead of just letting it snap up into position.
Sep 12, 2009 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon D50 : how do I ensure the flash will fire on day shots?
Auto mode only allows for "Auto Flash", "Auto Flash with red eye" or "Forced Flash Off". Forced, flash "ON" does not exist in Auto.
Put it into "P" for programmable mode. Then press the flash button on the left-face. The flash will pop-up. While holding the button, turn the selector dial to select what you want the flash to do - the little flash icons will display on the top panel as you do this.
Cheers.
Jun 08, 2009 | Nikon D50 Digital Camera
Flash on Nikon D50 will not latch down
If you have a fine screwdriver, remove the two screws underneath the pop up flash housing and remove the upper housing. BE VERY CAREFUL OF THE 300V at wires under the cover. You can see where the latch catches on a disk with steps - rotate the disk to a lower step and it will catch. Otherwise, an independent repair shop can probably do it while you wait for less than $40 USD.
Nov 25, 2008 | Nikon D50 Digital Camera
Flash
It may be broken/blown, but there is a way to toggle the flash. There is a button located on the left-front of the camera , just left of the flash and above the lens. Hold it while scrolling the wheel on the right.
Best way to find out if it's broke or not: put your camera on Auto, go into a dark room, and take a photo. If the flash pops up and takes a shot w/o firing, you know it's broke. If it doesn't pop up at ALL, you've probably got a bigger problem
Aug 03, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
Built in Flash
I have the same problem on my D50. I found this forum, which sounds like it may fix that problem. I am going to try it out. http://forums.dpreview.com/forums/read.asp?forum=1034&message=22761542
Sep 25, 2006 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon D50 Digital Camera Logo
304 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
