Question about JVC Cybercam GR-DX95 Mini DV Digital Camcorder
No Power Good evening I believe my camera power supply is blown, I recently moved and lost the original plug, I tried several other plugs, but none worked. I later found the original one and nothing happens when I plug it in. I am in Hampton, Va and am trying to find a service center. Help!?
  • powerproblem Mar 03, 2008
    thanks I'll try that
I changed out the battery and that didn't fix it
Posted on Mar 10, 2008
  • 25 Answers
Most likely you have blown the battery probally putting too many volts into the camera and you might need to get a new battery. i had the same proble with my portabe dvd player and a new battery worked.
Posted on Mar 03, 2008
No power, even new A5 fuse slotted in
check the fuse located in the male plug of the power supply, if problem still going on, replace the power supply...
Jan 26, 2014 | Brother MFC-7820N Printer
My Sony Vaio PCG-7142L laptop will not power up. The chargers green light comes on when plugged in though it does flicker somewhat (it may have always doen this). I thought it may be the connector that...
If there is any way you can find another power supply that you know works and try it, this will be a really good troubleshooting step. If you know anyone anywhere that has a similar laptop. Or try your power supply on another computer that takes a similar power supply, to see if it works on a known good laptop. Also, try using your power supply on your laptop with the battery removed. If the battery is bad enough, it might make the laptop not boot, even though it is plugged in. If there is no other laptop or power supply available, you should at least be able to use a multimeter to test the output voltage of the power supply. The expected output voltage should be printed on the power supply.
If the plug is loose in the socket on the laptop, the socket may be broken off the motherboard. Some laptops do not have the socket soldered directly to the motherboard, but most do, requiring a motherboard replacement if the socket is broken off.
Jun 02, 2011 | Sony VAIO PCG-7142L Laptop Charger...
After start button is pushed several low buzzes is heard
Better check that power supply & where it plugs in at out. Also,make sure all the connections are plugged in tight inside. Never assume that a replaced part is good & if you went after-market for the power supply, don't go super cheap. Buy a good one with a good warranty & the same if not more juice than the original.
May 12, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Sanyo DP5747 Plasma TV no power
Found 1 of the 2 ac supply ( 8amp) fuses blown on the main pwr. supply. Replaced fuse and good so far. Looked over the ps for damaged components, none found. Checked current with ampmeter with tv on, showing 3amps. Cheers
Jan 03, 2010 | Sanyo Televison & Video
I have a gateway desktop computer. Recently moved
Before you actually replace the power supply, check some other things first:
1. Wall socket
2. Power strip/surge protector
3. Power cable
4. On the back of the computer, where the power cable plugs into, is the red switch set to 115? It should be 115.
5. Make sure that the power cable is not connected to a regular extension cord. Power cable must plug directly into a surge protector that is not daisy-chained to another power strip, surge protector, or normal (household) extension cord. Surge protector must be directly plugged into wall socket.
If none of the above solve the problem, open up the case and ensure that all power connections are secure. Also check ALL other components' connections. Any loose connections can cause problems for you.
If everything is secure and the problem persists, replace the power supply.
Nov 27, 2009 | Office Equipment & Supplies
My Canon FS200 DVC isn't transferring files
Hi mate, I had same problem as you, took the cam into store and teh guy helped me out.
Make sure you get the recharger for the camcorder, then plug it into teh camcorder and also to the wall power when you are uploading the files. It can needs an extra power boost to get the files onto your computer.
- so plug in your camcorder to computer
- also plug in the battery recharger cord to the camcorder
Should work fine!!
Jul 13, 2009 | Canon FS100 Flash Media Camcorder
EMachine will not turn on.
Sounds like the power supply is faulty. Power supplies are very dangerous to try and repair, even for qualified technicians. I would also suggest not trying to plug it in or turn it on until the new power supply is in place. Faulty power supplies have been known to cause motherboards to permanently malfunction. Note: researching your issue, I came across several forum posts with complaints about emachines and their power supplies. The best way to solve this problem is to purchase a new power supply. If shopping online, and are two places that specialize in PC hardware. A 400-watt power supply would probably more than do the trick for you. The cheapest one I found was $18.00. Make sure the power supply is compatible with your motherboard before you buy.
Dec 27, 2008 | E-Machines eMachines Desktop PC
No power/RCA ctc187cl
Check for 5 volts present at pins of EEPROM IC. ( 8 pin-center
front) = no 5 volts = Re-check power supply components such as AC in resistor 2.7 Ohm ?....Or 5 volts ok,then suspect EEPROM corrupted........part # 223957 ( install 8-pin socket,then re-plug in original, if that doesn't clear it, plug in
new part) Use pre-programmed after-market replacement,if you
can get it.....Let me know....T.
Oct 30, 2007 | RCA F32450 32" TV
Sharp AR-207
sounds to me that the power supply has blown, or fuse onthe power supply. If you remove the left side cover you will see the power supply. Please unplug the machine first. check fuses if they are good, the power supply is bad.Let me know if you need more help.
Oct 26, 2007 | Office Equipment & Supplies
Firstly try another battery to remove this as a possible issue. After this check the contacts in the battery compartment are clean and dry (moisture will kill a camera dead quick) If this is good then try plugging in the USB cable. This will sometimes kick the camera back to life. failing this some cameras are eqipped with a dc cord, try plugging it into the wall using the supplied transformer) If none of this helps then give it a light (light) tap against a hard surface and see if anything flickers (make sure there is power) Failing all of this there is little hope I'm afraid. Electronics these days are indeed disposable (not cheap yet still disposable) I will think up some more trys if none of this works.
Jul 05, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
JVC Cybercam GR-DX95 Mini DV Digital Camcorder Logo
48 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
