Question about GE E1040 Digital Camera
Micro sd card says write protect when inserted what does that mean
My phone is a samsung sgh t629 and i placed my sd card that had some music in it but it asked me unrecognised format? and i press yes and it got erased so now when i try to copy a file to it it will say write protected disc what can i do?
Posted on May 18, 2008
    Master:
  • 619 Answers
Hi , means you connot delete the picture , the only remedy to erase the write protect to format the micro sd , for the next time dont click to write protect .
Posted on Mar 03, 2008
How to reset the password memory card
Transcend??
Mini SD cards, or MicroSD cards, are used in digital cameras and portable media players to house digital media files.
MicroSD cards can house anything from 2GB to 32GB of information.
A write-protection feature gives the owner the ability to lock the MicroSD card to keep their files secure.
If you have a MicroSD card that is write-protected, you can un-write-protect it with a flip of a switch.
Insert your MicroSD card into the adapter that came with it.
Put the data side of the MicroSD card into the data side of the adapter.
Look for the write-protection switch on the left side of the SD adapter.
Flip the switch to the side that reads "Off."
Remove the MicroSD card from the adapter and replace it in the device you were using it with.
or you might
Feel along the lower right and left sides of the Micro SD card to find out if it has a built in write protection switch.
Move the switch over to the "On" position to turn on the write protection feature.
Check the front ports on your computer and see if it already has a built in card reading unit.
Purchase an external card reader that plugs into a USB port if your computer does not already have an internal card reader (see below).
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=card+reader&x=0&y=0
Plug the card reader into any open USB port on the computer.
Power on the computer and let the operating system finish loading.
Insert the card into the Micro SD slot on the card reader.
Wait for a new window to appear that will ask what action you want to take with the Micro SD card.
Click on the link that says "Open a folder to view files."
Right-click on a file if there is just one specific file you want to enable write protection for.
Click on the "Properties" link from the menu that will pop up.
Navigate to the "General" tab.
Click on the box marked as "Read Only" and then close the Properties window.
Close the window and then double-click on the "My Computer" icon on your desktop if you want to enable write protection for every file on the Micro SD card.
Right-click on the name of your Micro SD card in the list of computer drives.
Click on "OK" and then close the window.
Click on "Properties" and then navigate to the "Security" tab.
Scroll down to the heading labeled as "Permissions."
Click on "Deny" under the "Write" section.
or
Slide the switch on the left-hand side of the SD card. If the switch is broken, proceed to Step 2.
Affix a small piece of tape or paper to the top half of the gap where the slider should be. Do not permanently affix the paper as of yet. 3
Try the card in your computer, using the USB converter stick.
If the items on the SD card are available, copy them to your computer as a precaution.
If that did not solve the problem, proceed to Step 4. 4
Remove the tape or paper and reattach it to the other side of the gap if you mistakenly attached it to the wrong side.
If you are actually trying to unlock a micro or mini SD card, proceed to Step 5. 5
Toggle the switch on the left side of your SD Adapter if you are trying to unlock a micro or mini SD card.
Micro and mini cards do not have switches.
Instead, insert a micro or mini card into an unlocked SD Adapter to work with stored data.
SD Adapters look very much like SD cards and the switch works the same way.
Nov 26, 2013 | PNY 1GB microSD Memory Card
Remove write protection from sd card
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Feb 17, 2013 | SanDisk Micro Sd Hc Card 16gb San Disk 16...
My Sandisk 'Wake up your phone' adapter & the micro one won't let me add music or anything else. It says that the disk is write-protected. Help?!
Micro SD write protect means there is damage to the firmware. Micro SD write protect, the data can be saved. Follow these steps:
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
After all data is secure, do the process repair micro SD.
Based on experience, the following methods can be used to repair the damage: RAW file system, used space 0 bytes, free space 0 bytes, micro SD can not be in the format, micro SD corrupt. To write protect a micro SD cases, 40% probability of success. But, you can try it. Good luck.
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, the first way
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extract.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, a second way
1. Open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - select Backup / Restore - click Restore - From filename, click Browse - Look In. Find the file initrd.img
2. If you are using Win XP, the location of the file in C: \ Program Files \ Compaq \ hpdkbu \ flash \ initrd.img - Next
3. If you are using Win Vista or Seven, the location of the file in the folder where you extract the files cp006049.exe. After the file is found, press Next
4. This process, will take a very long time, so you wait. This way you do for a capacity of 2GB. This involves when, the first way did not work. If the process runs smoothly, the chances of success, but if the process is running very slow, the possibility of failure and immediately stop the process. If you are unsure, or afraid to make mistakes, you should not do it this way.
5. After the process is complete, remove the micro SD card from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
I hope this information helps. Thank you for using FixYa!
Oct 10, 2011 | SanDisk 2GB microSD Memory Card
How do i shut off write protection
Hi, i have here a photo that will show you on how to remove write protect on a micro SD.
1. You need to insert your micro SD into an adapter. 2. Unlock the micro SD through your adapter as shown below. 3. Once done, your micro SD is no longer write protected. eibraz_16.jpg
NOTE: The lock switch doesn't lock the micro SD into the adapter; The lock switch doesn't lock the data on the micro SD; The lock switch simply tells the "user" not to write. It just says "please, don't write me."
I hope this helps.
Aug 16, 2011 | SanDisk 2GB microSD Memory Card
My micro sd card is locked how to unlock
Aug 12, 2011 | SanDisk 2GB microSD Memory Card
My micro sd card get write protected help me to retrive it...
I hope this helps.
Aug 10, 2011 | Computers & Internet
When i try to format my micro sd card system shows remove write protect how can i format it
I hope this helps.
Aug 09, 2011 | SanDisk 2GB microSD Memory Card
Sir i forgot my micro sd (memory card ) password...pl tell me how to unlock dat password
Unfortunately if you do not have the password to your micro-sd card it can't easily be unlocked. The card has built in protection for this reason.
Mar 02, 2011 | Cell Phones
Samsung micro sd memory card
THE CARD IS WRITE PROTECTED
OR THE FILES COPIED ARE WRITE PROTECTED.
SO REMOVE THE WRITE PROTECTION ITS LIKE A SMALL SWITCH WHICH SLIDES ON THE CARD .. ONLY CERTAIN CARDS HAVE IT .
NOW IF THIS DOESNT WORK
PUT THE CARD IN A PHONE AND SEE PROPERTIES OF THE DATA THERE , REMOVE WRITE PROTECTION .
Jun 08, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
GE E1040 Digital Camera Logo
118 people viewed this question
Top GE Cameras Experts
Steven Wander
Steven Wander
jjanesic
jjanesic
Level 1 Expert
Are you a GE Camera Expert? Answer questions, earn points and help others
