My printer is saying it is not connected to the computer
    Problem Solver:
  • 12 Answers
That could mean a couple of things.uninstall the softwear.reinstall it.see what happens
Posted on Mar 03, 2008
My printer says offline and won't print
Is your printer turned on?
Connected to the computer?
Showing an error message on the printer?
Typically, your computer will set a printer offline when it can't talk to it, so we do the above testing first...
If your printer is indeed on, and it's connected to the computer, there are things to try:
change connection wire.
change which port it's connected to on the computer
test on another computer
Jun 09, 2015 | Office Equipment & Supplies
I want to scan a copy to my computer. the error messae on my printer says no computer found.how do i connnect my printer to my computer
uninstall the printer driver then connect it with computer if computer detect the printer then install it and print the documents.
if computer not detect the printer then connection media like USB cable or wireless connectivity setting
Apr 17, 2015 | HP Photosmart 5510 Wireless e-All-in-One...
My printer says it is offline I have a MacBook
Most printers you go into your computer where your printer is listed, find the printer right click mouse or pad, and you may see a line that says off line, click on it and many times it puts it back on line...
May 07, 2014 | Lexmark X7675 Wireless All-in-One Printer
I get a message that my HP 5500 is not connected to my new iMac but the printer says it is connected. How to solve?
The printer says that it is connected correctly to the router because the router is aware of it and has assigned to it an IP address on the network.
The computer on the other hand does not know that there is a printer. Not finding one (or not knowing where to look for it) the computer reports that the printer is offline.
You must install the printer drivers on the computer.
May 25, 2012 | Apple Computers & Internet
Printer keeps saying busy printing another document
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Feb 10, 2012 | Lexmark X4580 InkJet Printer
Changed the ink cartridge and now the printer doesn't recognize the computer.It says the printer is idle. What do I do?
  4. Reboot computer.
Jan 29, 2012 | Lexmark X4650 InkJet Printer
Printer says there is no commputer connection
Try reinstall the drivers first or change the usb cable.If this not help your printer need service.
Oct 26, 2009 | HP Officejet 5610 All-In-One InkJet...
Computer says printer is offline
If you are using a network connection and it says the printer is offline, do the following:
1) Make sure the printer is connected to the network
2) Get the IP address of the printer from within the printer menu
3) Update your IP address on your computer
a. Open up your Control Panel,
b. then open Printers,
c. select the printer in question
d. right click and select Properties
e. select the tab that says "Ports"
f. make sure the TCP/IP port you are trying to use is selected
g. click on "Configure Port"
h. re-type the correct IP address i nteh field lablelled "Printer Name or IP Address:"
i. click "OK"
j. then click "Close"
Within about 2 minutes, your printer status should update.
Aug 20, 2009 | Office Equipment & Supplies
Printer has no connection to computer
Check all the connections from the computer to the printer
You may have to replace the cable going from the printer to the computer
Apr 29, 2009 | Office Equipment & Supplies
Scanning
please help I can't get the scanner to connect between computer and pc
Nov 05, 2008 | HP PSC 950 All-In-One InkJet Printer
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
