Question about Goldstar GVR-DD1 VHS VCR
Input I bought a used TV/VCR combo to use for my business. I hooked up my surveillance camera, but can not get it to play on my TV. I had an input button on my last TV, but this one does not have one. How can I get this unit to record and play my surveillance camera
Goldstar gvc1324m will not play forward or reverse. put new belt on bottom pullley.
Posted on Sep 06, 2008
    Champion:
  • 206 Answers
Usaly there is a button on the remote for input but if you do not have that you might try changing chanels below chanel 1. Some Goldstars hide the front input down there
Posted on Mar 07, 2008
Installing a dvd. how do i swithch the signal from tv to dvd
THE COMBO WHEN YOU HIT PLAY SHOULD BE AUTOMATIC AND DISPLAY PICTURE AND SOUND ON THE SCREEN---THIS IS LISTED AS A TV-VCR COMBO SO IF dvd hooked to one of the rear inputs (some are also on front on some models) in the menu you select that input and should see the picture and hear the sound from the DVD.
Mar 19, 2012 | Sylvania SRC22134 13 in. TV/VCR Combo
I have a DVD1001 DVD VCR combo how do I hook DVD combo to my tv
Use output of combo player to input of TV. Use what ever available input you have left on you TV. HDMI or Component input is best, but others will work.
Dec 30, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
We are unable to get video (picture) on our TV, when we hook up to our new DVD/VCR combo. The combo doesn't have an S-video port and our TV does. We get perfect sound though.
Your TV should also have a regular composite video input jack (yellow) in addition to the s-video input. Use that input instead of the s-video. The video won't be quite as clear as with s-video, but you have to work with what the combo gives you.
Apr 22, 2009 | Zenith C27A24T 27" TV
Magnavox DV220mw9 won't record from Tv, hard to connect
check out this diagram, paying close attention to the audio video cable hookups.
assume the cable tv box represents the converter box
you are going to come out of the converter box audio and video outputs into the new magnavox dvd/vcr combo audio and video inputs.
Then out of the new magnavox dvd/vcr combo outputs to the inputs on the tv if it has such inputs. The TV will have to operate on the video input 1 or 2 if the tv has such a thing, use the remote for the tv to adjust the input signal to line in 1 or 2 depending on what it has.
If the tv has no coaxial input or audio video inputs then you might have to use an adapter, you can get these from radio shack.
You say it will not record from the tv, but in all actuality the dvd vcr combo is getting the signal from the converter box not the tv, do you understand what I mean here?
So the dvd vcr combo gets input from the converter box so you will have to set it to view signal from the line input you have plugged in from the converter box. line 1 or 2 or whatever the input is.
the tv will have to be set on the line input to view the signal from the dvd vcr combo.
That is as easy as I can put it. Study the diagram closely. You will see what I mean.
Mar 07, 2009 | Philips Magnavox DVD/VCR Dual Player
Need to hook up dvd/vcr combo with converter box
Connect your rabbit ears to the Insignia. Connect the Insignia to the antenna input on the "cvd/vcr combo". Now turn on the television to show the "cvd/vcr combo".
The Insignia simply goes between your antenna and your television. In your case you also have a vcr so if you want the VCR to be able to play and record digital stations you will need the Insignia between the vcr and the antenna.
Dec 28, 2008 | Insignia Digital-to-Analog Converter for...
Sound problems
TRY PUTTING A SET OF PHONO CABLES INTO THE VCR INPUT THEN TO THE ANALOG OUT PUTS ON TOUR DVD/VCR SWITCH AMP TO VCR PRESS DIGITAL INPUT BUTTON ON FRONT OF AMP UNTILL YOU GET _ _ _ SET SOUND TO PROLOGIC 2.THIS SHOULD WORK.
HOPE THIS HELPS.
CABLE GUY.
Jun 18, 2008 | Onkyo TX-SR605 Receiver
Samsung tv - switch to play a dvd player
All you should have to do is hit the TV/Video button on your remote. It also could be named AUX, or or INPUT. What this does is tells the tv to switch to the input you have the DVD player hooked up to. Otherwise it will keep drafting a signal off of your cable line.
May 31, 2008 | Samsung CXJ1352 13 in. TV/VCR Combo
Televison & Video Logo
148 people viewed this question
Top Goldstar Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Goldstar Televison and Video Expert? Answer questions, earn points and help others
