Question about Energry Speakers Energy Speakers S8.3 Subwoofer
Fuse keeps blowing?
The fuse in the amp part of the sub keeps blowing. The light will go blue when you plug it in with a new fuse and in a couple seconds it blows again. No sound can come out while it goes blue or nothing. How can i get it to be powered so the fuse will stop blowing and sound will come out of the sub. I'm using a 1.5 amp fuse.
    New Friend:
  • 60 Answers
The amp is the issue - we fix them - Edwards Electronics - Ebay - Check us out - Thanks.
Posted on Sep 21, 2012
  • 54 Answers
The fuse is a protective device. Fuses dont blow unless the amp ( in your case ) is drawing too much current. DO NOT put a bigger fuse in. Obviously, there is a problem with the amplifier inside the sub. If the sub is under warranty, send it in for repair to an authorized warranty depot. If not it's not under warranty, then take it to the authorized warranty depot anyway. Why ? because they will have the schematics ( electrical diagrams ) to troubleshoot the unit quickly and it may be a common problem. If it is a common problem, the factory may have released a modification and possibly it could be covered under warranty under a factory 'goodwill' program. Good luck. Rob
Posted on Mar 03, 2008
Why does my Definitive Pro Sub 1000 keep blowing fuses the second I put them in?
Sounds like the amp is shoot.
Never power on the amp without speaker connected.
May 24, 2014 | Definitive Audio Players & Recorders
Brack lights wont light up on my 1988 ford ranger we keep blowing fuse and put in new brake switch
If you keep blowing the brake fuse than you have a short in the system. Unplug the brake switch. Install a new fuse. If it did not blow than the problem is after the brake switch. Next unplug the turn signal switch, then plug the stop light switch back in and press the brake pedal. Did the fuse blow. If not than the wiring is good in between the two switches. With the turn signal switch disconnected use a jumper wire in between the light green wire (power from the brake switch) and the orange with light blue wire (power to the right brake lamp). If the fuse blows than there is a short in the right side brake circuit between the plug in and the rear socket assembly. If the fuse does not blow than jump from the light green wire to the Light green with orange wire (power to the left brake lamp). If the fuse blows than the problem is in the left hand brake wiring circuit.
Sep 04, 2013 | Cars & Trucks
Car keeps stalling, fuel pump fuse blows
Aftermarket Stereo installed wrong?
Disconnect that & see what happens
If a fuse blows- you found the circuit with
the fault,so why has'nt that part of the problem
been resolved
Mar 13, 2013 | Cars & Trucks
I have a 2010 harley ultra that i wish to tap into the brake, running light & ground. how & where do i do this?
All these wires are on a sub-harness. Follow the wires up and tap on in the plug if you can. Keep in mind that this circuit is protected by a fuse. If you add other lights and stuff to the circuit, you may start blowing a fuse. If you simply put a larger fuse in the slot, you give up the protection of the wiring that the fuse is designed to deliver. If you ever get a short, you're wiring will burn before the fuse blows.
Good Luck
May 27, 2011 | Harley Davidson FLHTCUI Electra Glide...
It keeps blowing my fuse for my stock radio. Pushing a 10" sub.. Fuse on my amp is good. In-line fuse is good. But it keeps blowing the radio fuse in my panel.. ? Please help.. Thanks Ryan
Check the amp turn-on wire. It's a blue/white wire running from the radio to the amp. It's probably label REM at the amp. This wire sends a switched 12 volts from the radio to the amp. It is probably shorting out somewhere between the radio and the amp.
Nov 28, 2010 | Alpine MRP-T220 Car Audio Amplifier
Mission m-cube sub fuse keeps blowing
If you have replaced with the correct rating and the fuse blows off then you will need to check for higher current drain in the sub woofer or the network. After replacing the fuse load up the subwoofer slowly, reduce the bass and as you increase check at the point the fuse blows off. Now we need to analyse if the rating of the amplifier you are using is rated for the subwoofer. If your subwoofer has a higher rating you can increase the rating by about 25% and check again. Some amplifiers give a very higher voltage on full bass which could result in such a condition. Moderate this and check again. If the fuse stays Ok you can continue with this new rating.Otherwise the output of the amp at higher volume needs a confirmation. Hope this helps. Good day
Jul 20, 2010 | Mission M-CUBE System
Fuse blows
Both 3 or 4 amp slow blow fuses are suitable replacements for the 3.125 amp subwoofer fuse.
It could be that the subwoofer is blowing the fuse because the one you installed was not slow blow.
But, more likely is the subwoofer has a short in the power supply which is causing the fuse to blow.
May 31, 2009 | JBL PB10 Subwoofer
Klipsch ksw subwoofer wont power on
The power supply switching transistors are likely fried. Dangerous high voltages involved. I would remove the plate and send it to Klipsch for repair.
Jan 16, 2009 | Gem Sound SUB-650M Speaker
No sound
good day, check your spkr impedance, if 4oms use a posive spkr dividing network. if stills blows up replace a higher amperage of your fuse. ex.4A raise it up to 5A. the your amps consume higier current if more spkr wattage.
May 29, 2008 | Kenwood KAC-5203 Car Audio Amplifier
No LED light on PSB Alpha Subzero-i and keeps blowing fuses.
Others have had similar problems with the amp on this model. There is probably a circuit design error which causes some components to blow and as far as I've read, fixing it (or replacing the fuse) won't make the problem go away for long. Try contacting PSB or the retailer.
Dec 02, 2007 | PSB Alpha Sub Zero Subwoofer
Energry Speakers Energy Speakers S8.3 Subwoofer Logo
1,021 people viewed this question
Top Energry Speakers Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
Tom Chichester
Are you an Energry Speakers Audio Player and Recorder Expert? Answer questions, earn points and help others
