Question about Printronix Line Matrix P5210 Printer
Printronix P7210 Ribbon problem
Model P7210
Serial # 480639348998 Folks, I am having difficulty with my printer not accepting new printer ribbons. When the last ribbon ran out, which worked fine, the P7210 tells me the barcodes on the ribbon spools are damaged. I have tried rotating the ribbons, cleaning the top of the reading laser/light, adjusted the platen, and tried 4 new unopened ribbons, all with the same result. When I put the old ribbon back inside, the printer accepted it until it ran completely out, and the new ribbons were rejected (all due to barcode damage). I inspected the barcodes, and if there were some of the black bars incomplete, I took a dark marker to fill in the scratched surfaces of the black areas. Still, with no success.
Call 800-854-3181 to talk to a LIVE tech support which is located in the US.
Posted on Mar 03, 2008
    Problem Solver:
  • 6 Answers
If bar code is damaged than printer will give the error, pl. use the
new ribbon .
upadhyay
Posted on May 12, 2008
Printer given barcode missing install new ribbon
There are two styles of P7000 a spool ribbon style and a cartridge ribbon style. You are getting a barcode error then your printer is looking for a ribbon spool not a ribbon cartridge.
Cartridge Ribbon:
PRINTRONIX 255048 402 P7000 EXT LIFE CARTRIDGE RIBBON New
Spool Ribbon:
PRINTRONIX 179499 001 ULTRA CAPACITY RIBBON 6 PACK New
Jan 03, 2016 | Printronix Office Equipment & Supplies
I have wep printronix p7500 line printer. I haven't uses the printer since last 24-30 month. when i print a text file using edit.exe. it print quality is very fade. I brought a new ribbon for this printer....
I'm guessing the carrier solvent for the ink has evaporated. (Ribbon is old and dried out - even the new one) In the past, i have sprayed WD40 on unspooled ribbons and rewound them to bring ribbons back to life but that can be messy with spotty results. Suggest you buy direct fro Printronix.....
Oct 01, 2017 | Printronix Office Equipment & Supplies
15v ctl fail assy
Bad main board. Get the number off the board as there are 2 different kinds.
Sep 16, 2013 | Printronix LineJet® P7210 Printer
Need to change font on Printronix P7210, but don't know how.
get the user's manual try to check if it is a manual on how to change the font size, if not..search it to internet.
Sep 16, 2011 | Printronix P7210 Matrix Printer
My Printronix P5005B says "RIBBON STALL" what
Remove the ribbon and check for play when turning the plastic ribbon hub by hand. If it is loose try tightening with a torx bit. But it is probably cracked and needs to be replaced.
Dec 07, 2010 | Printronix Line Matrix P5005B Printer
I HAVE PRINTRONIX P5005B PRINTER, RIBBON IS NOT MOVING
Check to see if the plastic ribbon hub is loose on the ribbon motor shaft. The plastic hubs will crack and while the motor shaft turns, the hub will not. If so, replace plastic ribbon hub.
Nov 27, 2010 | Printronix Line Matrix P5005B Printer
Printronix Line Matrix P5210 Printer Logo
542 people viewed this question
Top Printronix Office Equipment & Supplies Experts
Chinmay Joshi
Chinmay Joshi
Cliff
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
