RCA SP9972AW surround sound sub hums. One fuse was blown, replaced then both blown. Diode? Caps have not popped tops. Emitted typical smell of electrical burning but no signs of overheat or damage anywhere on circuit board. Schematic appreciated. Thanks, Mike
  • theprivilege Apr 16, 2009
    Replaced both fuses, but the sub still hums
osborne382
  • 306 Answers
SOURCE: Kole Q1-3000D Power Supply caps Keep blowin
you need a fuse of 300amps or higher with 1/2aut cable power supply connected to an after market altenator. also make sure the subs are wired properly.
Posted on Nov 12, 2007
robotek
  • 1512 Answers
SOURCE: Noise and popping on Sony STR-DA3ES
Sounds like its going to square wave clipping and poking a dc offset at your speakers. Happens when the amp reaches power supply ceilings. Pink noise such as "rain sound" will push the output stages and power supply to limits. If its on all channels, check power supply caps and check for dry solder joints. also look for that crappy brown hold down glue that goes conductive/corrosive. check all output stages particularly about discrete output devices that are attached to heat-sinks. They have a bad habit of dry jointing also. Good Luck
looked for a free manual on line for you
http://www.nodevice.com/manual/Sony/page139.html got heaps... but not your exact model. You may be able to cross reference one
Posted on Feb 03, 2008
bestdarngood
  • 3037 Answers
SOURCE: JBL sub PSW-D110 hums, and the fuse is blown
here is the manual, I am looking for a more detailed version
Posted on Mar 25, 2008
SOURCE: Blown Pioneer Amp
Cambia los ICs amplificadores de audio
Posted on Apr 04, 2008
SOURCE: TV will not power on
The MZ73L is a posistor, its basically 2 thermal resistors back to back. One is connected across the mains, the other one connects the deguassing loop to the mains. When the TV is 1st turned on the mains connected R is cold so its neighbour is cold, that allows a large surge of current into the degaussing coil. The mains connected one rapidly gets hot and heats up the other one, this increases the resistance of it and the current being dumped into the degauss coil fades away. As the 1st one is a heater it will get hot and you will see signs of heat on the PCB, BUT its still a very good place to start. The heat is normal, but if the 1st ceramic disk in it has died then you will short the mains and blow the fuse with it.
Posted on Apr 20, 2008
Have a JVC sub SP-PWM606 all speakers work except sub. found a blown cap on what I assume is the sub's amp replaced 2 caps- still no sub
Sub woofers are basically mono amps. It's likely that either a fuse has gone, on the sub, due to the blown caps. Or more likely the main power amp device of the device blew the caps. I suspect if you replace the IC or transistor(s) on the heatsink then the device will come back to life.
Feb 04, 2018 | JVC Audio Players & Recorders
RCA P46731AT
Do you have the number of the board
that the glass bead was on
Dec 02, 2007 | RCA P46924 46" Rear Projection Television
Why is there low humming in the receiver sub channel(only?)
Sounds like a shorted capacitor in the sub out circuit.
May 04, 2015 | RCA Audio Players & Recorders
How do i connect the sub to the amp and my flat screen
Typically there is an RCA jack on the back of the amp (assuming you have a surround sound amp) by the rest of the speaker connections. Run an RCA cable from it to the input on the sub. If you have a stereo amplifier instead of a surround sound amp you could connect it to either the left or right side of channel B, but it wont give optimal performance.
Oct 20, 2014 | Audio Players & Recorders
Surround sound doesnt work. When i switch the surround on there is a buzzing/ hum from the speakers. The sub has a hum in analog mode. I try to switch to theater, club, church etc. And still a hum was...
Back up, open the manual and set it up with test tones to verify the hardware before trying anything else. Then onboard FM. Then external sources (according to their manuals).
Hum/buzz solutions are common on the internet. Do some web searching for "audio system hum" to find somethign that matches your symptom.
Sep 01, 2011 | RCA RT2500 System
Loud Humming
Many times a "humming"sound is caused by bad signal, caused by things like, bad rca cable, bad rca ground from the radio, or even a bad ground in from the amp to the car.. Wiggle your rca cables at the input to the amp, and see if it changes the hum at all.. If not take a short peice of speaker wire, and wrap one side arrounf the outside metal at the end fo the RCA jack, and then touch the other end to ground, and see if that makes the humm go away. If the humm goes away at that point then you need to have your radio replaced, or repaired. if neither of these do anything to the hum then check for tight ground connection to the amp, and to the car..
There could also be a problem with the amp it's self, but this kind of thing is hard to diagnose over the web, so try those things, and let me know what happens..
Aug 15, 2009 | JBL Audio Players & Recorders
Not working plmv169dc
HI, the sound you herd was the noise filter and running diode. these important components have failed at this point. you will need to replace these components asap, if possible. this will fix your issue.
The Magnetron Cut-off fuse will need to be replace as well. this will blow if there is a malfunction within the unit.
Jul 22, 2009 | Frigidaire PLMV169DC Microwave Oven
Sunfire Subwoofer 110 Noise on input plugin
A few more questions-
Does the sub hum without anything plugged into it except for power? If it makes a real loud hum almost a squeal then I think the rca cable between the receiver and the sub is dead shorted and needs to be replaced. If it's more of a low level hum, then it's a ground hum caused by many things, ie........the receiver and the sub being on different power circuits in the house.......sometimes diconnecting the cable tv feed as it enters the room while the sub is connected and humming to see if it stops........the easy fix sometimes is using a 3 to 2 prong ac adapter but lifting the ground on such a powerful amp could be a fire hazard.
Sep 25, 2008 | Sunfire True Sub MK II Subwoofer
Amp Issues
1) Make sure a bridged load of no less than 4 ohms is applied.
2) make sure both the left & right channels are working.
Jan 29, 2008 | Rockford Fosgate Punch P2002 Car Audio...
Loud hum on subwoofer.
try another speaker on that channel if you get no sound or it hums then it is time to take your set to a tech your audio out put on that side is damage along with some caps.good luck.
Mar 30, 2007 | Polk Audio RT1000I Speaker
213 people viewed this question
 Grubhead
Grubhead
