Question about SanDisk Sansa E280 MP3 Player
Recharging Does anybody know whether you can recharge these in Europe using a wall charger with a converter/adapter kit? I've heard that you should never charge electronics using a converter, but I've also heard that you can charge ipods using an adapter only...I don't know if sansa players are like ipods or not.
    Problem Solver:
  • 15 Answers
You should be able to just make sure the voltage or w/e matches the req. or you could try the sansa chargers that are made for travelling.
Posted on Mar 04, 2008
My Kobo Aura is not recharging. The charging unit seems "dead". Can the charger be replaced?
it can
Kobo Aura / Aura HD compatible Advanced Rapid Wall AC Charger ...
https://www.amazon.ca/Kobo-compatible-Advanced-Rapid-Charger/.../B00GNB08JS
Gomadic Powerful High Wattage wall charger for home or travel use. Customized circuit design is based on the latest in power regulation and is tailored to the ...
Kobo Aura One Charger, BoxWave® [Wall Charger Direct] Wall Plug ...
https://www.amazon.ca/Kobo-Charger-BoxWave®-Direct-Touch/dp/B01MA3NLF8 Pwr+ 6.7 Ft 2A AC Adapter Rapid Charger for Kobo VOX eReader; Kobo Arc 7 10 HD; Kobo Touch Glo Mini Aura Hd Ebook Tablet.... ... HQRP Micro USB Charger / AC Adapter for Kobo Arc / Arc 7 / Arc 7HD / Arc 10HD / Mini / Glo / Touch / Aura / Aura HD / Vox.... ... Pwr+ 6.7 Ft 2A AC Adapter Rapid ...
Kobo eReader Glo USB Cable - Micro USB: Amazon.ca: Cell Phones ...
https://www.amazon.ca/Kobo-eReader-Glo-USB-Cable/dp/B00AXZVE48 Rating: 4.7 - ‎11 reviews
Kobo eReader Glo USB Cable - Micro USB: Amazon.ca: Cell Phones & Accessories. ... Cable for Kobo eReader Kobo Mini, Kobo Touch, Kobo Aura & Aura HD... ... Pwr+ 6.7 Ft 2A AC Adapter Rapid Charger for Kobo VOX eReader; Kobo Arc ...
Chargers & Cables - Electronics: 146 products available ' chapters ...
https://www.chapters.indigo.ca/en-ca/electronics/chargers-cables/500151-cat.html Results 1 - 24 of 146 - Shop Online at Chapters.Indigo.ca for a wide selection of chargers & cables products, 146 items available. Enjoy free shipping on orders ...
kobo aura charger Google Search
Sep 24, 2017 | Tablets & eReaders
HOW TO RECHARGE THE INBUILT BATTERY FOR THIS PRODUCT?
It is hard to help find a solution for you without more specific info on this. It says you have purchased this(what?) product in the 60w version and it(what?) came with no manual. I would help you figure out how to connect the battery charger(what type?) to the back(of what?) or to the wall socket. Do you turn on or off the switch on the back(of what?) while charging. AND you WOULD APPRECIATE a CORRECT answer. Please< I need you to help me understand what you are asking before I can help you. I am here to help. If it uses a backup battery like a pc, you don't charge it. If it(whatever it is) uses a battery for power, you probably plug it into the wall overnight without turning it on to charge.
Mar 09, 2013 | Music
I purchased the Easy Share M580 Digital Camera with the battery charger for the KLIC-7006 battery-also included. I am taking a trip to Europe starting in Stockholm, Sweden - cruising the Baltic Sea to...
The charger should be 110 v ~ 220 v (it should be in the fine print on the charger itself). If it includes 220 v then you will not need a converter. If it only states 110 v, without stating 220v, then you will need a converter. In either case, you should have no issue finding the adapter or the converter in any ma and pa hardware store after arriving to the country you're visiting.
The battery life depends on the amount you're using the camera. It should last you a few days each full recharge.
Mar 01, 2011 | Kodak Easyshare M580 Digital Camera
My bluetooth earpiece will not recharge, it has the american powerplug is there anyway that i can get a charger for germany recharging
1, USA chargers are usually 120volts ac in germany its 230volts so you have to check the charger to see if you can change the voltage.
2, if the voltage is ok and the plug is not part of the body of the charger you should be able to use a standard travel adapter.
3 another alternative you may try is a electric shaver adapter (some come with a built in 120/230 transformer. the bluetooth charger will not use much electricity so a shaver charger should be able to be used without any problem.
Feb 24, 2011 | Motorola Computers & Internet
My vehicle was at rest for about 10 days with the switch at start position. Now following troubles are occurring: 1. Do not start when key is switched to ignition 2.A noisy sound is heard when switch is...
The battery is dead. Recharging (or replacing) the battery will remedy those symptoms you describe. Recharging the battery is a lot cheaper if you have access to a charger or can remove the battery and can take it to a service station for recharging.
Charlie
Jan 12, 2011 | 2004 Toyota ECHO
I am in Europe and need to recharge my Norelco shaver 5861. Will it damage the batteries if I use an adaptor and plug the shaver into a 220v outlet?
Model 5861 has worldwide voltage capability and can be charged from 100-240V without requiring a voltage converter. If your shaver cord has an American plug, you will need a simple adapter to fit European wall outlets. You will find this item at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/international-plug-adapter-for-use-in-continental-europe-p-408.html
Sep 28, 2010 | Norelco Reflex 5861 XL Electric Shaver
Need recharging lead for a Philips shaver
You willfind a replacement at shaveroutlet.com. See link below. Note that this is an American version and you will need a simple adapter to fit your wall outlet. Adapters are also available at shaveroutlet.com
http://shaveroutlet.com/norelco-philips-shaver-wall-charger-transformer-cord-p-270.html
May 04, 2010 | Health & Beauty
I am from Israel and our main supply here is 240volt . I bought a BOSCH 36volt drill kit from USA and I am interested to make changes in the charger in order to fit our supply .
look for a travel converter or 240v to 110/120v converter usually the adapter will plug into ur outlet and the charger[or whatever] plugs into the adapter and can convert the power down to the lower i have used mine every time i go to europe the adapters cost between 10 and 15 dollars mine is a one piece multi-use 8 different outlet designs- its easier than rewiring the charger
Feb 01, 2010 | Bosch 18V Compact Litheon Drill/Driver...
Recharging with out computer
yes there are car chargers for apple check out walmart.com
Feb 26, 2009 | GPX MW3837 MP3 Player
Battery not recharging.
Look on the charger itself & it will have the correct output voltage & polarity stamped on the charger. Then get a volt meter to verify if the correct output voltage is present. If the volt meter reads less than what is stamped on the charger, then I would recommend replacing the charger at that point.
Nov 20, 2008 | IBM ThinkPad T41 Notebook
SanDisk Sansa E280 MP3 Player Logo
65 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
