Malfunctioning Maytag Washer
Washer leaves the clothes with detergent in them regardless of number of rinses.
    Sergeant:
  • 351 Answers
Advise to use less soap and shorter wash time
Posted on Mar 03, 2008
Put detergent
MLG2000A - Maytag Neptune Super Stack SL-3
1 - Select Wash/Rinse Water Temperature
2 - Select Options (Max Extract, Extra Rinse, Signa)
3 - Select Cycle
4 - Load the Clothes Washer (add detergent on top of the load in the tub, and additives [fabric softener, bleach] in their dispensers).
5 - Start the washer.
This is according to the owner's manual I have. Has worked for 14 years for me.
Jan 14, 2014 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag Neptune MAH5500B Front Load Washer keeps leaving bleach speckles on my clothes. How can I fix this?
Possible that the rinse cycle is not adequate and so does not wash off the detergent that is dozed upon. Check the water level or sett it a little higher. Make sure the belt is tight and fitting and the motor RPM is correct. Choose another program to confirm
Jul 05, 2012 | Maytag Neptune MAH5500B Front Load Washer
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    Maytag Auto Load-Sensing Washer does not fill with enough water to wash the clothes. How do I get around this?
    Did you ever get an answer - all I see are ads :-(
    We have the same problem. Not enough water to rinse - even with extra rinse selected. Even our laundry comes out the color of the laundry detergent. I'm sure this is a result of government regulations to reduce water usage. We'll contact Maytag tomorrow.
    Sep 07, 2010 | Maytag PAV2300 Top Load Washer
    Our towels and clothes have a mildew/musty smell. when I spin the stainless drum inside, i can hear water sloshing around.
    Towel mildew odor is transferred from the washer to towels and clothes. The washer must be cleaned first. After cleaning the washer and towels washing habits must change to stop mold smell from returning.
    Washing machine mold / mildew is caused by:
    #1 cause is overuse of detergents. Detergent companies are notorious for instructing to use too much detergent. Especially with soft water or when using liquid detergent no more than 1 tbsp of any detergent should be used.
    #2 most common cause is using fabric softener because it's dispensed in the rinse cycle and will coat the inside of the outer tub with residue that is a food source for mold to grow.
    #3 using only cold water for washing is fine but makes preventative maintenance very important. A weekly hot soak will dissolve odor-causing residue from inside your washer.
    #4 not using the washer. If the clothes washer isn't used very often maintenance is especially important. If leaving for a vacation it's a good idea to clean your washer. Do a search to "remove washer odor" to read just how big the problem is. There are all natural washer cleaners that will also remove mildew odor from towels and clothing after the washer has been cleaned.
    Oct 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
    My washer has a really bad smell like musty if i leave the doors closed or if I leave clothes in for a couple of hours is this a probem with them
    hi there,
    the musty smell is from the door boot or gasket. deposit from clothes and detergent get trapped in there and have nowhere else to go. i would recommend purchasing Washerfresh tables to get rid of the deposits. they are available all over.
    Dec 04, 2008 | Frigidaire ATF6000ES Front Load Washer
    Neptune stackable washer...
    You put the detergent directly on top of the clothes.
    Jul 31, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
    Soap left in clothes
    hope you are using he detergents (high effeciency low suds) also if you have soft water oversudsing can occur even with he ..try reducing amount ..also have been told tide he detergent tends to suds more so may try switching detergent brands try runing washer with no soap no clothes begore next load to flush out any detergent that may remain ..be sure to run washer with bleach no clothes on short cycle peroidically to avoid mold/mildew odors that front loads tend to acquire after a few months use and leave door open if possible between uses..let me know about detergent thanks
    Jul 15, 2008 | Kenmore 44102 Front Load Washer
    Detergent goes where?
    3 - Select Cycle
    This is according to the owner's manual I have. Has worked for 9 years for me.
    Jun 28, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
    Washing Machines Logo
    Top Washing Machines Experts
    Marvin
    Marvin
