Brother MFC 490cw Color Inkjet Multi-Function Printer Logo
Anonymous Posted on Feb 27, 2010
Problem paper jam printer brother no mfc-490cw
Clive
Level 3:
  • Master 4,362 Answers
  • Posted on Feb 27, 2010
Clive
Master
Level 3:
Answers
4362
Questions
0
Helped
1813937
Points
14613
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
1helpful
What does error 73 mean? the display keeps giving that error... i have a brother mfc490cw
It is my pleasure to guide you.
The machine does not work due to a paper jam or some sensor problem.
Quote
Clear the paper jam. (Please refer to "FAQs & Troubleshooting" for information on the Paper Feed Problem.) If the problem still continues after clearing the paper jam, please contact Brother Customer Service from "Contact Us" http://www.brother-usa.com/support/CustServ.aspx.
FAQs & Troubleshooting http://welcome.solutions.brother.com/bsc/public/link.aspx?faqid=faq000495
UNQuote
Good luck and please post back that you are successful or that I can be more helpful.
Printer was jamed paper removed now saying unable to print 34
Try restarting your printer, it might not recognize that the printer is no longer jammed till it is restarted.
What is unable to print 70?
You would need to remove jammed paper by opening the back cover.
Please rate this solution as FixYa if found useful.
Thanks,
What cause a error report Unable to print 70? and how do I solve problem. Many thanks Susan
These mean the machine does not work due to a paper jam or some sensor problem. try to clear the paper jam. If the problem still continues after clearing the paper jam, try to clean the encoder strip (clear strip of plastic) located behind the head.
18helpful
Error message is causing me fits - won't print
Make sure the top cover is closed as well, Brother has a one year warranty, so it can be repaired at no charge
Norman Weimar
Norman Weimar
k24674
