Question about Maytag Neptune MLE2000A Front Load Stacked Washer / Dryer
MLE200AYW washer does not spin
Sporadic at first, but now will not spin at all, there is water in bleach & softener trays. Occasionally will spin on the extra spin, but not on the regular spin. If we turn the drum you can hear water sloshing around.
Repair man said we were using to much soap - made adjustments - didn't help - came back said we were filling it to full - whether it is one item or 10 items - didn't help - came back said we were not using like kind clothes (towels with underwear), come on!!! Replace the motor - didn't help - put old motor back in, replaced computer board on top - hasn't helped. He is coming back tomorrow and we are at a frustration mode - - I'll fix it myself if someone will tell me how. HELP
  • 2 more comments
  • ndnil Mar 19, 2008
    Washer worked fine until I cleaned the bleach and softner containers now the door locks and the cycled gets completed but it will not spin and the clothes and dripping.
  • hofmanr Aug 18, 2008
    same problem
    Our second repairman said pull plug -wait five minutes plug in and it works - yep! It worked for a hile. Each time we do this it becomes more problematic,
  • badbug2020 Nov 11, 2008
    After wash water still in drum
  • Anonymous Dec 21, 2008
    I have the same problem,
    I unsamble the washer but the water is inside of the plastic ring of the drum, it supose to be sealed, but the water got into. I was thinking to make a couple hole with so the the water will drain
    President:
  • Maytag Master
  • 2,651 Answers
Lets start with the basics, Door lock indicator coming on?? is door actually locking?? if not, i would lean toward the top board AS WELL as wax motor and door switch,.. assuming all lights are functioning correctly then head toward lower Motor control board. depending on age of machine, you would replace both motor and control board as a kit.NEPTUNE REPAIR KIT (very rarly an issue with motor)..next would be a possible out-of-balance swithc located around the tub(if one of them faults out then the tub will not spin either. theres 3 things i check, and when in doubt i call the maytag techline for further help troubleshooting. As long as servicer is a maytag autherized repair co. he can call as well
Posted on Mar 03, 2008
Softener tray won't fill with water; although it fills the bleach side tray just fine. No error codes, just an empty bleach tray but full softener tray.
I suggest there may be hard water mineral deposits in the hose or orifice to the tray. Try soaking it with some Coke (yes I mean the soft drink) overnight and see if the flow improves. Either that or you can try some CLR but Coke should be enough to gently remove any deposits there are in the tray, hose or line.
Dec 02, 2014 | Maytag Neptune MAH5500B Front Load Washer
Fabric softener premature release
In my case it was simply a matter of cleaning the nozzles that spray the water into the MAIN DETERGENT compartment. Turns our that when the washer was filling up, some nozzles were partially clogged and were directing water to the side where the softener compartment was, causing the fluid level to rise and therefore releasing the softener early. The washer was NOT spraying water in the softener side, what happens is that the dispenser tray is configured in a way that when the fluid reaches a certain max level in the softener/bleach trays, it completely drains. A way to test for this problem would be to completely dry the softener tray and start the wash cycle like you normally would (including detergent), only without adding any softener to the tray and see if after filling there is any water in the softener tray, this would prove that the water is coming from the other side.
Apr 13, 2012 | Whirlpool GHW9400 Front Load Washer
The fabric softener and bleach trays will no longer feed into the washer they stay full. Any ideas?
Just wondering by taking the top off & cleaning it would this solution be the same if the fabric softener tray has water in it after washing a load of clothes?
Jun 27, 2010 | Frigidaire ATF6000ES Front Load Washer
Water left in bleach tray as well as bleach
There are multiple soleoid valves which run water through this tray. The valve connected to the bleach compartment is not functioning properly.
You can see these valves on back top of machine after raising the lid.
More info, let me know.
Charlie
Aug 27, 2009 | LG WM-2277HW Front Load Washer
Fridgidaire front load will not empty fabric
Hello, W/D here.
There are a couple of reasons why the fabric softener will not dispense. If everything else dispenses properly (detergent and bleach), then I would suspect a bit of plugging. If the softener remains in the dispenser, the water valve above the tray may be sticking. You'll have to get the top up to check it. If there is water in the tray, or some water/softener, then you'll need to look at the overflow cap. Here's how that works: Your dispensing trays for bleach and softener have a raised tube built into them, and each is covered with a loose fitting cap. When water is let into the tray, the level rises under the cap until it overflows, creating a syphon. The softener is literally pulled from the tray, and chased by the water. When the water stops, the tray level continues to drop, until air gets into the cap, breaking the syphon. The cap can be removed and cleaned. Sometimes the tray has to be removed first. Theres a catch towards the rear of the tray.
Best regards, W/D
Aug 17, 2009 | Frigidaire ATF6000ES Front Load Washer
The fabric softener and bleach tray won't drain
clean the caps sometimes they get clogged and cannot syphone
Jun 14, 2009 | Frigidaire ATF6000ES Front Load Washer
We have a Maytag front load washer Model MAH 4000 AWW
tHE PROBLEM IS YOU NEED TO CLEAN YOUR SOAP, SOFTENER AND BLEACH DISPENSER, REMOVE THE BLEACH AND SOFTENER DISPENSER TRAY, AND YOU WILL FIND THAT IF YOU HAVE BEEN USING LIQUID SOFTENER, THAT IT HAS GUMMED UP AND CLOG THAT AREA AND IS CAUSING SPILL OVER. WHEN THE WATER IS POURED INTO THE TRAYS TO DISPENSE THE BLEACH AND OR SOFTENER.
Mar 18, 2009 | Maytag Neptune MAH7500A Front Load Washer
Water Softner Dispense wont empty - Kenmore Elite Quiet Pak 4 HE3t
I'm sure you heard a small motor running from time to time during a cycle. That moves an "arm" which sends water to the different chambers during a cycle. Fabric softener is dispensed when water goes to that chamber and dilutes the fabric softener. That chamber then empties by a siphoning action.
If you want to narrow down the problem a little to help trouble shoot -- put some wet rags in and run the Rinse and Spin cycle with some fabric softener. If the softener is not dispensed, then you know that the water isn't being sent to that chamber properly.
If you are intrepid enough to take the top off your washer, do that and see if the arm appears to be moving during a normal cycle. Maybe the arm got dislodged or broken during the move.
If water isn't being diverted properly, I think this calls for a real repair person.
Jan 27, 2008 | Kenmore Elite 45986 Front Load Washer
Maytag Neptune MLE2000A Front Load Stacked Washer / Dryer Logo
533 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
