Question about GE Spacemaker JVM1640SJ Microwave Oven
Leaking microwave oven???
While cooking micro popcorn I noticed steam coming out of oven while door shut and oven operating. necer saw that before, dangerous???
  • William Miller
    William Miller May 11, 2010
    It's normal for steam (from boiling water inside the popcorn kernels) to come out of the vents.
    But just to be safe, where did the steam come from specifically?
  • Anonymous Mar 15, 2014
    Every time we use the Microwave oven it causes our wireless TV signal to go out. It is frustrating when watching a Hulu or Netflex movie. However, we are most concerned that the microwave may be leaking dangerous amounts of radiation. Otherwise it works fine. Are we in any danger or should we be fine to continue using it?
    kirsen2001
  • 492 Answers
The steam is perfectly safe, as with any other oven it has vents. Just as long as the door is shut and intact your safe.
Posted on Mar 11, 2008
My GE Microwave Model JKP90SP4SS will not shut off, even with no time programmed and cooking is done. The only way to stop operation is to open the door or shut off the breaker.
This kind problem is usually associated with the door micro switches. What happens is the switches are supposed to prevent operation when the door is open and other things. When one fails, often the oven will run with the door open or closed. There are a number of these micro switches inside and they protect the user from certain unintended actions or combinations of actions. This usually happens with well used ovens. There are extremely dangerous voltages inside a microwave over, even when not connected to power. Find a tech who knows these things.
Jan 07, 2017 | GE Microwave Ovens
Ge microwave je2160sf03
From the description one of the door switches is defective, or a more serious problem has developed.
Jun 02, 2012 | GE Spacemaker Over-the-Range Microwave
Over heating and shuting off
I am not surprised! Cloth of anysort is not recommended to be placed in a microwave oven!
That includes undies and socks which many try to speed the drying time of.
Regarding the popcorn.. The oven is overheating due to a possible containment in a hutch, where insufficient airflow is available to lower the temperature. Pull the unit away from the wall to allow more airflow, clean the vents and help it breathe.
Please rate my help++++Thanks for using FIXYA
Mar 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
When I put a bag of popcorn in the microwave, it started but noticed it was making a funny noise so I stopped it and opened the door and there was a little bit of smoke coming from the side wall and it...
The first thing I would do is thoroughly clean the inside. Take particular care when cleaning around the upper left side. Sometimes a buildup of food steam or spray can cause the problem you are having. Never spray anything into the microwave, in an attempt to clean it.
Hope this helps.
Jan 20, 2010 | Bosch HMB402 Microwave Oven
Popcorn Castastrophy !!!
You would have to remove the top cover and check to see if the main fuse is blown. Usually a 20 amp slo-blow. There are thermal cut out devices, they will reset when the unit cools, so plug it in the next day and see if the clock and power is back up. good luck, Dale
Aug 06, 2009 | Magic Chef Microwave Ovens
GE XL1800 Micro fan won't shut off after light burned out
The problem appears, at least in part, to the door latch circuitry which cannot be serviced by the owner. If the unit is still in warranty, call GE customer care. If not, replacing the unit is your best bet. I just bought a new GE 1100 watt oven with great features for less than $100 If the door dosen't latch correctly, you could be exposed to dangerous microwave energy.
Ray
Nov 15, 2008 | GE XL1800 1100 Watts Microwave Oven
Oven turns off
You are running the risk of damaging the Magnatron by doing this.
Check the packets you are using, you will have to reduce your power output.
This is because microwaves act by being absorbed by water. There is very little in popcorn and in fat. Once this has been evaporated, the microwave energy builds up (as it is still being produced - but not absorbed), and ends up cooking the magnatron itself.
I have seen countless posts on here after cooking popcorn!
More fun on the hob anyway - and cheaper to buy in bulk!
Jun 21, 2008 | Magic Chef MCD1311ST Microwave Oven
Oven turns on by itself when boiling water on stove!
Sounds like a mis-aligined, or defective door switch. I would suspect defective.
Jan 22, 2008 | LG LMV1650ST Microwave Oven
Magic chef microwave shuts down
We had the same problem with our brand new Magic Chef. Before going through the trouble of taking it back I called Home Depot. After talking to a Home Depot Rep I am told that the overheat sensor is under the glass plate directly beneath the popcorn bag. Popcorn gets very hot and the heat of the popcorn causes the sensor to shut the machine down. I would imagine this would be the same for a baked potato.
Very poor design.
I was told to put a microwave safe plate down and put the popcorn bag on it. This should help to reduce the heat and not trip the sensor.
A safety sensor is great, but not if it keeps tripping the machine and shutting down!
Sep 02, 2007 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
526 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
