Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
Whirlpool Gold Mod GU2500XTPQ1
Top shelf does not clean at all. Bottom shelf only does a satisfactory job not a good job. Dishwasher is only 3 years old.
    President:
  • Whirlpool Master
  • 2,651 Answers
Sound like a low water level and or pressure issue. Start machine on normal cycle after filling open door and ck water level. should be up toJUST below heater assy.. assumiong htats good set hte wash arms to a set positon so you can watch for rotation. close the door adn after a few secs open rapidly and look for middle arm to be spinning, even the top 3rd row arm if present, should be spinning spinning . if not its possible that the motor/sumo assy is blocked w/ foriegn debris. remove the lower spray arm (hold the nut and spin arm)then remove 4 or 5 torx 15 screws. probly pretty glogged under there. if not id look into replacing motor sump assy/seals worn and not throwing water where it should go
Posted on Mar 03, 2008
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
My whirlpool gold dishwasher is about 11 years old now and is'nt cleaning my dishes at all...they are still dirty both top and bottom. Any ideas??
Make sure the water sprayers are not clogged. It may just be a good idea to get new sprayers and they are easy to install.
Aug 16, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
My dishwasher doesn't clean my dishes anymore and sometimes it doesnt dry them. it is a quiet partner 1 and it is about 2 years old.
It sounds like the water pump on the dish washer has gone out. A dish washer works (much like a clothes washer) by filling up the washer with a set amount of water, then through circulation, pumps the water up through the various spray nozzels. If the water pump is worn and not making enough pressure, the spray won't get the job done. Depending upon make/model, it may be cheaper to replace the water pump.
Run an empty dishwasher load with a bowl of white vinegar on the bottom shelf. As the dishwasher runs the cycle, the vinegar is slowly disbursed and cleans the dishwasher.
Mar 02, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
The clips that hold the top shelf in my dishwasher are broke
call an appliance parts and service store and tell them the make year and model of your dishwasher..And they should be able to help you or steer you to an appropriate appliance shop they should be able to tell you how to remove and replace as well
Dec 29, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
The dishes on the top shelf does not seem to get clean. Does not appear water is coming out of the top spinning module.
Take out the top spinner and clean it thoroughly with descaler and degreaser / very hot soapy water. Soak it for a while and it will work wonders. Put it back in the machine and it will work like new.
Sep 10, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool Gold dishwasher
Either:
  1. not enough water gets into the dishwasher. check water valve, water level float and water pressure.
  2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
Good luck,
Vlad
First Choice Appliance
Mar 21, 2009 | Whirlpool GU2700XTSB / GU2700XTSQ /...
Dishwasher does not clean items on top shelf.
Check the upper spray arm holes for debris that may be plugging up the spray arm. If clean remove the lower spray arm and filter screen and clean out any debris in the sump.
Feb 03, 2009 | Whirlpool 24 in. GU1200XT Built-in...
My Whirlpool dishwasher is only 2 years old and I started having the same problems. I dismantled everything I could and washed and scrubbed the entire unit with EVERYTHING..to no avail, dirty dishes!! But I discovered a remedy! Try using Lemi-Shine for about a week with your regular wash-soap. If you are using the tablet form of soap, stop and try the powdered form. Follow the instructions on the Lemi-Shine container. You can find it just about anywhere for around $3.50. I was within "5 seconds" of replacing my 2 year old Whirlpool dishwasher when this caught my eye and I figured why not try it too? After the first wash I noticed a big difference the cleanliness of the dishes..and now it is running GREAT after 2 weeks!
Sep 22, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
357 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
