Question about iLO (2 GB) MP3 Player
Need help My device will flash when I turn it on and then it will turn itself off. I've already changed the batteries and the problem remains the same.
  • Anonymous Mar 05, 2008
    I have basically the same problem. I have even removed the battery to see if it will re-set itself but it still shuts down when I turn it on.
  • 63901 Mar 05, 2008
    I have basically the same problem. I have removed the battery for a couple of hours to let it reset itself but that didn't help.
  • 8,596 Answers
1) Disconnect from computer, turn it off, hold in volume + button and reconnect it to your computer - continue holding volume + until the Found Hardware Wizard comes up.
2)
REFORMAT FOR WINDOWS MEDIA PLAYER - Erases Everything: Connect your iLo player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "ILO 2GB" (wording may vary slightly), and then select "Format." - this should erase everything, and give you a fresh start.
Posted on Mar 19, 2008
4x4 light flashes red whilst driving
You need to take this car to a mechanic to get it checked ASAP. Could be a serious problem with the car.
Apr 28, 2014 | 2001 Mitsubishi Montero
SD CARD reader error: Insert removable disk into drive F:/
One of two I was say is the issue.
  • When you improperly ejected the card you messed up the MFT (master file table) on the card. You will want to format the card.
  • You could have hosed the drivers. In Device manager look under the driver details there should be some files listed. You will probably need to delete these and replace them. Since they may be system files you would need to replace them in a live boot environment such as a linux live boot cd (ubuntu.com) would be the easiest. Get the drivers it has listed copy them to a thumb drive. Boot the computer to the live CD, delete the driver files and replace with the new ones.
Dec 18, 2012 | Electronics - Others
Can't turn on my mp3 player. I have tried to hold the volume buttom but it does not turn on at all.
what type of mp3 player ?
Charge your MP3 player.
The battery might just be dead, in which case letting it charge for a few hours corrects the problem.
Plug the USB data cable into the USB port on the MP3 player and insert the other end into one of the USB ports on your computer.
In a moment, the computer states that it has detected the removable device.
Sometimes the MP3 player needs to update itself, and it can only do so while connected to a computer.
When the MP3 player detects the computer, it attempts to connect to the Internet and retrieve any system updates available for the device.
Replace the battery.
The battery is usually the first part of the MP3 player to go (especially after excessive use). Although you can manually change the battery on most MP3 players, you need to send your
Apple products (iPod, iPod Nano, iPod Touch, iPhone) into the company so they can change the battery for you.
Purchase a new MP3 player.
If your MP3 player has received any sort ofwater damage, it is not going to turn on at all and there is nothing you can do to fix the issue.
hope this helps
Sep 27, 2012 | Audio Players & Recorders
My guitar keeps flashing blue. I've already tried changing the batteries and syncing it. The USB is already plugged in, but my guitar is wireless so it wouldn't do any good anyway. Please help!!
ok....is your wii softmodded?....if it is this is a common issue until you install certain ios's 222,202 etc....try googling it....hope this helps
May 31, 2011 | Nintendo Wii Rock Band Guitar for Wii
Hello sir. when i go through my nokia e52 to control pannel - setting - connection - destinations : i got a message "system error " please give me a solution
From you end, you can try resetting the phone to it's default value, means "Factory Default". Open Menu, go to settings, navigate around and locate Factory Default. The steps should be like this.. Menu > Ctrl. panel > Settings and General > Factory Settings.. Open the Factory Settings, press ok and then enter 12345 when you are prompted to enter the security code. I hope you haven't changed the code yet, if you've changed it, enter the code you've already changed. Once it's confirmed, the phone will restart itself. You'll loose nothing by doing this, but all settings will be restored to it's default value. This is the basic and in most cases, this fixes minor issues. If this doesn't help you, you may likely need to update your phone software or you may need to flash your phone, to do these, you'll need to visit a Nokia Care or a Local mobile repair shop.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Apr 15, 2011 | Computers & Internet
How to disable the light on the remote itself need to change the battery's every month
There is no way to turn off the light on the remote control. The light works as an infra red beam that relays messages to the television or any device it operates. I will advice you take out the battery once you are not operating the unit or you can get some rechargeable batteries that can be charged once the batteries are running down easily. You can get 4. So while you are using 2, you will be able to charge the remaining 2, while it is not in use.
I hope this information helped you.
Take care and good luck
Jan 05, 2011 | Samsung Ak59-00104k Remote Control
My Canon S3IS shuts down during zooming. What's the solution ?
It could be the batteries running low. The mechanical zoom consumes battery power and at a certain point the camera will turn itself off. If you wait a minute and turn it back on it seems OK, until you try the zoom again. If you are using non-Canon batteries the camera doesn't always detect the battery level accurately and may flash "low battery" when there is still power remaining, or just turn itself off without warning. So I suggest changing the batteries and check that the battery terminals are not dirty or loose.
Mar 25, 2010 | Canon Cameras
My TI-84 Plus calculator won't work. It won't switch off by itself. When the batteries are reinserted, it says that all RAM has been cleared. When i press the 'ON' button again, the screen clears. but...
The Ram cleared message is normal after you change batteries. When you see this message you press the CLEAR button to erase it. You do not press the ON button again because the calculator is already ON. If you want to turn calculator OFF you press [2nd][ON] (OFF).
On certain calculators, pressing the ON button when calculator is already ON is interpreted as INTERRUPT the current command.
Jan 04, 2010 | Texas Instruments TI-84 Plus Calculator
My Samsung Juke will not turn on.
There might be a problem with the phone itself, you already did the best thing to do but still having the same issues. The phone is already experiencing hardware failure that you need to go to a technician to evaluate the phone's overall functions.
Jul 06, 2009 | Samsung SCH-U470 Juke Cellular Phone
iLO (2 GB) MP3 Player Logo
21 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
