My tv keeps turning off after 5-10sec.
I have a Philips Model CCZ192AT32 television. The VCR part has been removed but when I watch TV it keeps turning off after 5-10sec. What do I need to do to fix this?
Thank you
  • Anonymous Aug 26, 2008
    What if the vcr has veen removed completely and it stills pops off?
    Genius:
  • 1,139 Answers
Hello Onna76,
Ok this is a VCR/DVD Combination TV. First of all let's look at what your description says: "The VCR part has been removed" dou you mean that the VCR mechanism has been taken out or do you mean that the VCR mechanism was removed and then put back in? The reason I ask is because on the VCR circuit board there is a position sensor which senses the position of the gears on the VCR mechanism, when the gears are positioned in a certain way the sensor tells the power supply to remain on, however if there is a misalignment the set shuts down. This is what is happening in your case. If the VCR mechanism was moved and then replaced, make sure that the sensor and gear are aligned properly. the protrusion on the sensor should go into the grove on the gear and the middle of the gear should go into the middle of the sensor. This will allow the sensor to track the gear and take care of that cutting off problem.
I hope this helps,
Thank you,
Shuttle83
Posted on Mar 03, 2008
I can't get the VCR mode off the TV screen in order to watch TV.
try looking for either "source" button on the remote or ""input" choice. also you can try using the channel changing buttons, sometimes you can get out of vcr mode by just going up or down on the channel selector
Mar 16, 2011 | Philips Magnavox 20MC4304 20 in....
Looking for user manual for philips magnavox tv. 9P6044 C104, 3911Q1716. Trying to find out how to hook up my VCR to this tv. It has s viedo, video, L audio & R audio holes on front side of tv. I want...
Barb..be sure you run a TV signal through the VCR first. And then a coaxial from the VCR to the TV. This is the easiest solution for now. And set the vcr to tv/video {channel your movie is on}hit record and hit tv/video and watch your tv for another movie!
Feb 06, 2010 | Philips 9P6044C 60" Rear Projection...
Zenith TVBR1352Z TV/VCR combo. I cannot get a code to allow my Philips/Direct TV remote to control the TV/VCR. All I really need it to do is control the volume
Turn on your TV (or other device). You will have to do this manually until you program your Philips remote control
Look for the "Setup" or "Code Search" button on the Philips remote control. Which button your remote has will depend on the exact Philips remote control you are using. This button may be a different color or may be labeled.
Hold either the "Setup" or "Code Search" button for about 10 seconds. If your remote has a light, the light should begin blinking. If there is no light, you can just count to 10 and then let go of the button.
Press the "TV" button on the remote to program the Philips remote to your television set
Find and press either the "Up" or "Down" channel button on the remote. Continue pressing either button until the television channel changes. This may take several minutes. Once the channel changes, press the "Power" button on the remote to turn off the TV. Your Philips remote will now be programmed to your television.
Jul 09, 2009 | Zenith TVBR2562Z 25 in. TV/VCR Combo
Philips 27 inch TV - Model # 27PT543S37A - Keeps going off!
if you have back ground of tv repair, remove back cover but you need tools and tester, check heater line from crt ckt board going to horizontal section.
Apr 03, 2009 | Philips Magnavox TP3285C 32" TV
VCR will not turn on.
Remove top cover of the VCR. Then look near the back where the plug-in and power supply is. There should be a little glass fuse. You should keep that fuse and take it to the store and replace it with same exact one. If your VCR can be self-repaired, than this is the only thing you can try.
Mar 11, 2009 | Philips Televison & Video
My magnavox model mwc20t6 keeps turning off after 10 to 20 secs
tv was working fine however when we moved it to another room it will not power on at all even using different plug ins
Nov 22, 2008 | Philips Magnavox 20MC4304 20 in....
DVP3345V/17 can't watch TV Programs
I would like a insturction book, as I never receiver one. I can't fine the channel on the vcr to match the channel on the tv. to tape. My Name Carol King
Address 229 Billings Ave.
Paulsboro., Nj. 08066 Thanking you
Carol King
Model #DVP3345v/17
Serial #SG1A0816014102 Make Philips VCR/DVD
Aug 16, 2008 | Philips Magnavox DVD/VCR Dual Player
Tv channels are not coming in
it seems that there is a problem with your tuner. check inside if there are cold solder especially the rf connector jack of the unit.
Jan 08, 2007 | Philips CCC130AT 13 in. TV/VCR Combo
Televison & Video Logo
910 people viewed this question
Top Televison & Video Experts
