My tv started having a blue band "bowtie" with double exposure on the pictures and typeface this morning. I've left it on for some time and it does not seem to change
  • 103 Answers
It sounds like you have bad conv.ic's.Need model of unit
Posted on Mar 03, 2008
Sony KDL32W4000 TV - grey band keeps appearing
I found a manual for your TV, I don't have the time to read it all but thought you might find your answer in there. http://pdf.crse.com/manuals/3298243431.pdf
I hope this helps you. Good luck and sorry I can't help you more.
Jun 17, 2012 | Sony Televison & Video
I have a new 580EXII mounted to my Canon 7D. I do not seem to getting the "double flash" (not sure what the technical term is) that I expect and pictures are coming out dark. I'm think...
Holly, I believe you are referring to the pre flash for the ETTL function. both flashes happen so so fast that it looks like one flash. If your pictures seem dark make sure your flash is set to ETTL (press the MODE button unlit ETTL is displayed) this way the flash output is automatic. If it is still too dark you can change the flash output by adjusting the FEL (flash exposure composition) by pressing the button in the center of the dial until +/- is displayed the turn the wheel to select a + exposure (you can adjust this in 1/3 stop increments) then press the center button again. This can be found on pg 14 of the manual
Hope this helps.
May 24, 2011 | Canon Speedlite 580EX II (1946B002)
The left side of the picture is distorted with a double image. The right side is fine. As things such as the stock symbols on CNBC scroll across from right to left on the screen, they start out looking...
It's a convergence issue. Go into the main TV menu under video settings and look for convergence. If it has an auto convergence select that and wait a minute the TV will adjust itself and give you a clear picture.
If the TV does not have an auto convergence and just regular convergence than select this. It will give you a grid pattern on your TV and you have to move the cursor (using TV remote) and adjust each "point" so that each line is perfectly white. If you notice red or blue anywhere on that "line" then you have to adjust using the up, down, left and right arrow keys to "line up the red and blue lines with the nearest white line. It takes time and patience to do, but when completed, all lines on the grid pattern should be pure white and you will have a great looking picture.
You have to do this will all TV inputs (Video1, Video2 and so on) the reason Zoom looks good, is because you never used that screen as much and so the lenses didn't have a chance to get out of synch.
RPTV's are made of the three lenses (red, Blue and Green) and as you watch TV, these lenses slowly get out of alignment. So you should do a convergence about twice a year to make sure nothing is out of whack.
You can pay somebody to do it, but may cost you like 100.00 or do it yourself, it is very easy just tedious and time consuming. If you have the auto convergence than your golden because this is the easiest way to "reset" the TV.
Hope this will help in solving the problem....
Jan 12, 2011 | Hitachi 51GWX20B 51" Rear Projection...
I have a Sharp 36F-630 36" TV. Recently, it started getting a "band" across the top of the screen. It gets smaller as the tv warms up. It used to go away completely. Now it goes from...
You have a swollen capacitors in the vertical section try to replace all the leaky capacitors, you will notice that there is a liquid leaking out in the buttom of the capacitor.It is like an oil spill.
Dec 06, 2010 | Sharp 36F-630 36" TV
The picture looks like a bowtie and red blue and
TURN YOUR COLOR OFF.IF YOU SEE THE RED,BLUE AND GREEN AROUND THE EDGES EX.SOMEONES FACE YOU CONVERGANTS IS OUT NEEDS RE LINEMENT.
Apr 24, 2010 | RCA Televison & Video
Blue splotches on screen
sorry but u have a bad optical block price $450 - 600 dollar part
May 08, 2009 | Hitachi UltraVision 60V715 TV
My sony KP51WS510 Too blue or red, double exposure
This type of fault is harder to locate since the I cannot see the picture my self.
It could be a convergence problem or G2 problem. Either way U should take to a service center.
I don't think this is just a do it ur self kind of fault
Sorry. I can't be of any more help
Rifaa
Nov 15, 2008 | Sony KP-51WS510 51" Rear Projection...
Forget how to take double pictures.
Hey xplaur,
To take a multiexposure photograph you should first expose the film, and then push the multiexposure button which is on the front of the camera on the top left when you are looking at the front of the camera. After you press this button advance the winding lever to set the shutter, and since the multiexposure button was pressed this shouldn't wind the film to the next frame. Now take your second exposure, and if you want to make another exposure on the same frame repeat the process. Keep in mind that every time you expose a single frame after the initial exposure you will be doubling the exposure on the frame. I usually under expose each exposure by one third on a double exposed frame. If you do more than two exposures I would underexpose each exposure by even more. Multi exposures are fun but tricky, and I would suggest you experiment and have fun with it. I will also say that black and white film is much more controllable and forgiving when it comes to this than color film. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 31, 2008 | Vivitar V3800N 35mm SLR Camera
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
