Question about Dell DJ MP3 Player
Dell dj gen 20
When i turn my dell dj on it goes straight to rescue mode. i try to reboot it n it just says hard disk problems.ive clicked on everything on the screen ,it just wont fix n play songs like it use to.please help me
my dell dj will not turn on i have tryed charging it but it wont charge
  • Anonymous Apr 24, 2008
    I have the same problem and it isn't the battery cable
  • Ashes90 May 25, 2008
    my jukebox is charged but i get the rescue mode and it just keeps telling me i have a hard disk problem is there any way to fix this or am i just screwed
  • 3 Answers
It is possible the the battery cable is unpluged
Posted on Mar 25, 2008
Firmware error
Try going into rescue mode by pressing the Play button while inserting the end of a thin object such as a straightened paper clip into the reset at the same time, then hold the Play button until your Dell Pocket DJ turns on.
Scroll to "clean up" and select. This just defragments your players hard drive, you won't lose any data.
If that doesn't fix it try replacing the firmware. Download the most current firmware from Dell's support website. Scroll to and select "reload firmware" in rescue mode. Connect to pc with usb cable and power on player. Double click the firmware file on your pc and let it do it's thing. This won't affect your saved data either.
If neither of those work you may need to reformat the players hard drive. This will wipe out anything you had on the player. Scroll to and select "format all" while in rescue mode. Select "yes" then just watch the progress bar. Good luck!
Feb 17, 2010 | Dell DJ MP3 Player
Dell Digital Jukebox
Anything unusual happen to the player before the problem started? Dropped it or perhaps unplugged it from pc while synchronising? The most likely fixable problem is a loose connector on the HDD/main board cable, or a failing battery/power adaptor giving the HDD a voltage too low. unfortunately however the HDD on these players is a bit vulnerable to rough treatment. When you connect it to a computer, does it still appear as normal or is it not recognised etc. What operating system PC are you using - perhaps formatting from the PC first before trying to install the firmware will help. Are you using the latest firmware from Dell or are you using a cd that came with the player? Is your player still under warranty or do you want to try and open it up and have a check yourself. Let me know more info and what you wish to try :)
Aug 17, 2007 | Dell DJ MP3 Player
Tip
Dell Harddisk problem...solved...
I dropped my Dell DJ 20g Mp3 player today at work, and it would not reboot out of "rescue" mode. I tried to performe all of the options on the rescue page and recieved the "harddisk error" response everytime. So... i took the back off, removed the battery pack, pulled out the hard drive and examined it. seeing nothing visibly wrong i replaced the hard drive and pluged the batt pack back in, still able to view the HD. when i turned the unit on i could hear it start to scan then suddenly stop and then start to skip, a kind of clicking sound (i could also hear this sound while the unit was still intact) With the battery pack plugged in, i lifted the HD up (still connedted) and gave it a few thumps with my screwdriver. i looked back at the screen and it was playing a song ;] I have no idea why the unit started to work again, just dumb luck, nor do i think this will work all the time (let alone again for anyone), but i thought i would share my story and maybe help someone who has lost all hope. So if you get as pissed off as i did, take it apart and beat the crap out of it ;] you might save some money.
on Aug 18, 2007 | Dell DJ MP3 Player
The solution to many random problems is to simply reset your Dell DJ. This can be done by using a small, thin object (such as the tip of an ink pen) to press the reset button that is on the bottom-left side of the DJ. -or- Hold down the play/pause button while it's off, insert a paperclip into the reset button, take it out, and then let go of the play/pause. The DJ should open to a rescue mode, then run disc clean-up.
Dell Jukebox is stuck in Rescue Mode
did any of this stuff actualy work?? because i am having the same problem with mine the only thing is as long as i've had mine i didn't even know where the reset button was.
Mar 23, 2009 | Dell DJ MP3 Player
Did you get your dell dj fixed
its broken dude unfixable. sorry..... your just going to have to get a new mp3. I've tried everything and just threw that stupid piece of technology away.... couldn't even salvage the other parts to fix a cd player
Jul 07, 2008 | Dell DJ MP3 Player
Please Please help
If it kept going to recovery mode that means your device firmware is corrupted...in that case what you can do is to contact dell so they can provide you with the firmare upgrade or you can follow the link below and that should solve the problems you are having...
http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R96127&formatcnt=1&libid=0&fileid=124571
If that doesnt solve it you can format your player inside windows media player..NOT MY COMPUTER...and then that should reset the firmware as well..
Thank You
Computerrep
**Please rate accordingly...**
Jan 19, 2008 | Dell DJ MP3 Player
My Dell DJ
there is a tiny hole on the bottom of the player this is a reset button. push a pin or something into the hole and hold it there for a few seconds to reset the player(you shouldn't lose anything from the hard drive)
Nov 13, 2007 | Dell DJ MP3 Player
Dell DJ won't reload or reboot
I would first suggest reformatting the DJ from Rescue Mode, and then try reloading the firmware from here: http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R107735&SystemID=PDA_MP3_DJ_2&servicetag=&os=WW1&osl=en&deviceid=9420&devlib=0&typecnt=0&vercnt=3&catid=-1&impid=-1&formatcnt=1&libid=31&fileid=139674 If neither of those work, it may be time to look into some repair options. John Dell Customer Advocate
Aug 06, 2007 | Dell DJ MP3 Player
Dell DJ MP3 Player Logo
112 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
