Question about Kenmore 62622 Microwave Oven
Kenmore microwave 1000 watts
Second one in 6 months, keeps cutting out or won't run, but light goes on and timer counts down.
  • ranger22 Mar 27, 2008
    I believe I have the same problem. My 1999 GE profile micro light comes on and cook time will count down but no sound no heat ect... help
  • Anonymous Mar 25, 2014
    microwave will click when i put the time in and then press start. The timer does count done.
  • Kenmore Master
  • 9,086 Answers
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If it's under a year old, Sears should cover it under warranty, as long as they don't suspect abuse or improper operation..
If instead you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383 or http://www.searspartsdirect.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 07, 2008
Door will not open 1999 model
The unit needs to be shut down by cutting power to the oven by either pulling the 110VAC plug from the receptacle or flipping the toggle on the house circuit breakers.
Dec 31, 2013 | Kenmore 63673 1000 Watts Convection /...
Sharp Carousel R530BK microwave won't cook unless light pressure is kept on the door button.
There are door switches and one of them is evidently out of adjustment or the little actuator arm on it is.
Nov 27, 2013 | Sharp R530EWT Countertop Microwave Oven...
GE JVM1850 turns on but turn table doesn't rotate & light doesn't come on even though timer counts down. Doesn't heat & has low hum noise. Is it worth fixing or should I buy new? It is 8 yrs old.
if you like your micro fixe it, becouse even do new micros look better when it comes to work they suck they hardly last the warranty period thats if you are lucky...
Oct 19, 2013 | GE JVM1850 1000 Watts Microwave Oven
My microwave keeps running....meaning when i close the microwave door it will automatically run.
The timer control has the problem so it need to be replace. But be sure you do not program the microwave to auto run when the door is close some microwave have that feature.
Hope my advice help you.
Apr 04, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
MY KENMORE 1000 WATT LITERALLY WORKED FINE ONE MINUTE THEN NOTHING THE NEXT. I HAVE NO IDEA WHAT HAPPENED.
Most likely the circuit breaker tripped or the fuse blew. A 1000 watt microwave is using 2/3 of the power available on a typical household circuit of 1500 watts. If anything else is plugged into that circuit u can have a problem. Just reset the breaker or replace the fuse and u will be up and running. if it happens alot you should consider a dedicated circuit for your microwave only.
Apr 21, 2009 | Kenmore 62622 Microwave Oven
Microwave runs but does not heat
could be door switches could be pcb could be mag, cap or hv transformer.. Its really just a guessing game but one of the above is defo the cause best to get a tech in to have a look or get it replaced whichevers best for yourself
Nov 02, 2008 | GE JVM1650 1000 Watts Microwave Oven
WHEN SWITCHED ON MICROWAVE RUNS FOR 22 SECS AND THEN CUTS OUT ....
possibly a self-diagnostic service that detects a non-functioning magnetron
May 28, 2007 | Siemens HF26066GB 1000 Watts Microwave...
Kenmore 62622 Microwave Oven Logo
37 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
