Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
Kitchen aid refrigerator model KSRS22Q
How do i know if my unit has a filter for the water dispenser? When I try to get water, it comes out very slow.
  • wnahhas Jul 02, 2008
    I assume my fridge has a filter, but I do not know where it is or how to change it.Of course I do not know where to get the replacement filter. Can you help?
  • 1,314 Answers
It should be on the bottom where the kick plate is and will be a round piece that you turn and remove
Posted on Mar 03, 2008
Kitchen aid kscs25 with a small but ongoing dripping from water dispenser
Try removing the filter and reinserting it to make sure the seal on the filter is fitting flush with the filter housing assembly.
Apr 22, 2012 | KitchenAid KSCS25FKSS Side by Side...
Does Kitcheaid Model KSRS22Q contain SO2?
Hello, Welcome to FixYa. To answer your question in a word, No there is no sulfer dioxide in any modern refrigerators that I know of. They pretty much all use a refrigerant called R134a which has been the standard for 15yrs. or so...depending in what country you reside of course, this applies to North America. You may want to contact Whirlpool (manufacturer of Kitchen Aid appliances) for more info if outside of North America. Hope that answers your question. Thank you for choosing FixYa today. Please take moment to rate the info provided. Regards, Macmarkus :)
Apr 01, 2011 | KitchenAid (KSRD22FKST) Side by Side...
Kitchen Aid water dispenser makes a hammering sound when in use.
this is a pressure problem . some times caused by line size . but generaly changing the water valve will correct this problem . ****
Jan 06, 2010 | Whirlpool GS6NBEXR Side by Side...
Water not flowing from Kitchen Aid Refrigerator. I've switched the filter and it has not resolved the problem. the unit is one year old, was working properly. 2 days ago, water leaked from spout and that...
water maybe frozen somewhere in the system. may need to disconnect water connections at various points and retry to narrow down where freeze up is at.
Jan 06, 2010 | KitchenAid Refrigerators
Kitchen Aid Fridge KSRIZ6DSALYO Water no longer dispensing from door. Can a filter get too old and get clogged or should Iook at something else?
the filter can become clogged and restrict the water flow to the water dispenser and icemaker (i.e. water dispenses slow or small/hollow ice cubes). if the filter doesn't fix it then you either have a water supply problem or a faulty water valve. take the filter out and see if the water pressure increases out of the dispenser. if it does, you know its the filter. hope this helps.
Oct 22, 2009 | KitchenAid Refrigerators
Water Dispenser not working
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad.
Aug 27, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchen aid refrigerator water dispenser does not dispense water. the ice will dispense, and there is no filter for the water, so i would assume no clogging is the issue. But any ideas would be appreciated...
could be a few things. fist, when you call for water, listen for a very faint "hum" noise, if you do hear that, it is either the solonoid on the valve, or the reserve tank in the frige froze. easy way to check. pull the frige out and un-plug from power. on the back of the unit is a cover on the bottom, remove cover. the valve is on the far right as your looking at it. it has 2 solonoids on it. there are two plastic water lines on the bottom of the valve, i believe the one on the left is for ice maker, and the right one goes to door dispenser. remove the water line going to the door dispenser and put a cup under the valve. plug in frige and call for water at the door for couple seconds, check to see if water came out of valve into cup in back. if it did, the valve is ok, if no water, replace valve. they run about $50. if you didnt hear the hum i talked about, and the valve is ok, let me know and i can walk you through checking and replacing the switch in the dispenser. good luck, shane
Aug 24, 2009 | Refrigerators
I have a kitchen aid refrigerator freezer. The
the supply line of the ice maker might be blocked please check it.
Aug 18, 2009 | Refrigerators
Water filter
I don't think this model has a filter, I checked under the kickplate, no filter there.
Mar 26, 2008 | KitchenAid (KSRD22FKST) Side by Side...
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
1,120 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
