Question about Toshiba 55H70 55" Rear Projection Television
Rec convergence will not work
The red convergence can not be adjusted. It is too far outside, left and right
  • Toshiba Master
  • 8,617 Answers
Replace the conversion amp ICs both of them, also check the resisitors right next to the ICs for discoloration in the middle of the resistors. If discolored replace those resistors also.
Posted on Mar 03, 2008
    Sergeant:
    Champion:
  • 250 Answers
Your IC's likely need to be replaced. Also check your resistors that corrispond with the IC's. Here is more info on this.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
My screen looks like its 3D.
Your tv has a problem with the convergence, adjust it using the original remote go to the setting's menu then go to the convergence section. Adjust the convergence color red and blue the green color is your guide you cannot move this green color, then you should move the red and the blue in all direction left to right, up and down. If you cannot move the red and the blue far enough the convergence IC is defective it must be replace in order to align this convergence. Feel free to send feed back good day and best regards.
Aug 14, 2011 | RCA HD56W66 56" HDTV
Convergence
did u do a repair in recent days
by replacing the convergence ICs?
Jun 18, 2008 | Toshiba 43A10 43" Rear Projection...
I have a Sony KDP-57WS550 TV that has a convergence problem. Based on the symptoms, I'm not sure whether to indict the convergence ICs. In the convergence mode, I can move the red (and blue) crosses,...
With your TV in setup Use a small magnet to "move" the non converged Red, Blue, or, Green color lines "crosses" (each CRT will need to be adjusted in turn) by moving the magnet close to the offending Red, Blue or,Green color CRT yoke or, tube while observing the movement of the CRT color line "cross" in a mirror ( try several places near the tube and, several strengths of magnets:) a refrigerator sheet magnet works well (you can cut these with a scissors to make a better fit or, apply less magnetic "pull." by making them smaller (you may need more than one magnet per tube to fix each CRT's convergence) When you have each CRT tube's convergence right, apply some clear silicone adhesive to the magnet and, permanently affix the magnet to the now "fixed" CRT tube exactly where you placed the magnet to obtain the best convergence on the CRT.
(Do not adjust the "Green" CRT unless you must, as it is used as the color line to adjust other lines to)
Jun 30, 2011 | Sony Grand WEGA KDP-57WS550 57" Rear...
Convergence issue; red 3D effect. In grid convergence mode blue will converge w/green fixed lines and red horizontal will but the verticle red will not adjust far enough left to converge. has ajustment...
Convergence is dead.Must know how to solders?Must replaced ICS and all of it resistors.Tries Tv repair World.com,Tvrepairkits.com for a convergence kit.The shop will cost u $300 for parts and labors.
Jan 24, 2010 | Hitachi 43FDX01B TV
I have a problem with my convergence. I cannot get the cannons to adjust with the remote. I have red shadowing around the picture and the adjustment for convergence around the outside of ghe screen wont...
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jan 17, 2010 | Pioneer SD-P50A5-K 50" Rear Projection...
The images on my TW40X81 have a RED halo on their left side (viewers right side) I have done the electronic convergence but the red will not adjust left, to the "Merge" cross hairs. it will move right,up...
If Red will not move far enough you have one of three things wrong----if the two convergence chips have never been replaced--they are Q751 & Q752 and are black in color---
About 2 1/2 inches wide X 1 1/2 inches tall and mounted side (ON LARGE METAL HEAT SINKS WITH FINS) and they will have the STK-392-110 PRINTED ON THEM IN WHITE.
Either one of them is bad, or one of the 1.8 ohm resistors around them is damaged and off value OR you have a problem in the digital convergence unit--it stores and controls all the convergence adjustments.
I suspect based on your description one of the two chips damaged one of the protect resistors---
You can if you are able to do the repair yourself buy a pair of the chips on Ebay for about 12 dollars plus shipping--I do this for a living and have repaired hundreds of sets with convergence problems.
Let me know if you have questions or need advice--I am here to help people.
If this information helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 20, 2009 | Toshiba TW40X81 40" Rear Projection...
Hitachi 50FX20B 50 inch: Blue Convergence --will not adjust
You need to change convergence amplifiers. Should be no problem for a professional
Apr 08, 2009 | Hitachi 50FX20B 50" Rear Projection...
Convergence issue
try fixing the convergence 2 after your've aligned the convergence 1 - the second (accessed via the set up control) let's you adjust on 9 different axis to align the red and blue tubes to the green. you select which + sign you want to adust by pressing the corresponding number for the + ie 1 for the top left, and 9 for the lower right corner.
good luck (note - you cant change the green only the red and blue, if the whole edge is a mess try moving the image (you need to be in zoom mode, and then access the position adjustment via the pitcure set up screen.
Nov 05, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Blue Convergence
Blue convergence IC is bad, but change both as red wont be far behind they are cheap about 10.00 ea at the following link.
http://electronix.com/
Jan 14, 2008 | Toshiba TN55X81 55" Rear Projection...
Hitachi 50" - 50GX30B
You will need to replace the convergence IC inside the TV set.
Aug 12, 2007 | Hitachi 50GX30B 50". Rear Projection...
Toshiba 55H70 55" Rear Projection Television Logo
52 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
