Question about Refrigerators
Layer of ice in freezer.
I have a ET1MHKXM and notice a layer of ice build up (about an 1/8th of an inch), on the floor of the freezer, which is on the top on this model. What would cause this?
    President:
  • 1,314 Answers
A frozen defrost drain pull the back panel in the freezer section see if the drain hole is stopped up after clearing the ice
Posted on Mar 03, 2008
Bottom freezer door will not close
a) Door may be mis-aligned on the track
b) In a rare case, you may have ice layer building on the bottom floor of the freezer due to defrost drain line block. This ice layer might cause the door not to close properly.
c) May be other reasons too
Feb 21, 2015 | Refrigerators
Why do I have ice build up in my freezer
Ice build on the freezer box floor or White frost build up on the freezer box back wall (inside). Ice layer on floor means your drain line blocked. White frost layer means your machine is not going into defrost cycle.
Oct 07, 2014 | Whirlpool Refrigerators
Whirlpool dripping water from freezer drawer
See inside freezer box floor. Do you see Ice layer build up. If so then your defrost drain line is clogged.
Sep 23, 2014 | Whirlpool Refrigerators
Why is ice forming in freezer
Ice layer inside freezer box floor - Defrost drain line clogged.
Frost or ice on freezer box top - Room air leaking into the fridge from door seals.
Frost on the Freezer box back wall means unit is not defrosting properly.
Sep 04, 2014 | Whirlpool Refrigerators
Why do I have ice buildup on freezer floor of my samsung?
Check for a clogged drain line. Snake out and get some vinegar in there. Any water collecting from the defrost cycle is supposed to be led away and outside from the unit
Sep 04, 2017 | Freezers
There is layer of ice that has formed at the bottom of the freezer side. Due to this there is a leak of water that appears every two or three days. I cleaned the layer of ice once and after 2 or 3 weeks...
Sounds like the drainage hole is blocked with ice, i normally take the back cover off the freezer and at the bottom you will see a build up of ice at the bottom, turn freezer off and carefully remove as much ice as you can, then pour some boiling water over the excess ice and in the middle you will see a drain hole make sure water then freely flows down drain hole. Other than that you could try switching your freezer off for 24 hours to clear ice.
Nov 02, 2010 | Maytag MSB2654HE Side by Side Refrigerator
Leaking water on floor.
This is typically caused by the defrost drain. I have put together some instructions on how to resolve this, follow the link below and let me know if it helps.
http://www.fixya.com/support/r4686046-water_leak_from_freezer_ice_freezer
May 10, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Bottom of feezer building up ice and leaking
This just happened to me. take the panel off inside of freezer and you will see the evaporator fan this could be the problem. test it before placing.Also there is a thermostat in there too. A little round device that will kick the fan on when the temp is around 34. Both parts together are about 90 bucks if you get them yourself online. About 170. through a dealer.
Apr 10, 2009 | Refrigerators
Ice build up on floor of freezer drawer
Check the drain tray under the evaporator its probably froze over causing water to overflow in the freezer
Mar 02, 2018 | LG LRFC25750 Refrigerator French Door
Refrigerators Logo
331 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
