Question about HP OfficeJet D135 All-In-One InkJet Printer
Installing a new ink cartridge
I'm our of black ink in my Hp copy machine, model F41880. I don';t know how to put a new cartridge in. Can you help me? Thank you. Becky LaCour
After working with the copier for over an hour, my husbband discovered quite by accident where the ink cartridge was located. It is inside on the left hand side, above the try that holds paper, and is next to impossible to see. It pulls out to the middle of the tray, and the cartridge can then be changed. Thank you so much for you time.
Sincerely,
Becky LaCour
Posted on Mar 03, 2008
How do i change the cartridge ?
901 is the cartridge what is the printer model?
Jan 31, 2015 | HP Two 901 Black ink cartridges
While printing multiple copies in black the printing starts fadding after the first copy and gets worse, after 4 copies you can know longer see the printing. I thought it was the cartridge but it still...
That machine is very problematic. See reviews on Google. If your using HP ink then just save yourself the grief and replace the machine. if you have generic ink cartridges in the printer, replace them with OEM. Also, replacing the Printheads may fix the problem. Printheads and Ink cartridges both only have a 1 year shelf life. If they are out of date (date is stamped on them). Replace and retry.
Jun 25, 2010 | HP OfficeJet Pro k550 Printer
How can I get the fax and copy to print clearly?
Still sounds like a bad ink cartridge, try cleaning the bottom of the cartridge with a Kleenex and soapy water. Dry it off real good.
Look where the cartridge sits and clean the same way.
Ink jets are dead technology.
Nov 11, 2008 | HP 640 Inkjet Fax Machine
Hp officejet 6110 not printing with black ink
Hi lilacky-
Here are some HP support links that might be helpful... and a couple questions to consider.
Q: Is your new cartridge one of these listed below?
"The HP Officejet 6100 series and HP Digital Copier Printer 410 products use the print cartridges listed below:
* HP 56 black print cartridge
* HP 57 tri-color print cartridge
* HP 58 photo cartridge (replaces the HP 56 black print cartridge for six-ink photo printing)" info from: Installing a Print Cartridge
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00004340&lc=en&dlc=en&cc=us&lang=en&rule=12548&product=79477 Is your new cartridge a refilled cartridge? Some times those have special challenges. Has your cartridge been sitting a while in the box, maybe in a warm spot? Some times even new cartridges dry out a little. Was your old cartridge low or completely gone? Just as a test, if you put it back in your printer does the old cartridge work? Any printer error messages? Can you print a test page or an alignment page for your black cartridge? These might be too many questions but here are some HP support links with some How To information for getting more answers. Please let me know if any of these are helpful. see also: Slow or No Response from Printer
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?rule=11882&lc=en&dlc=en&cc=us&lang=en&product=79477 -JW
Oct 03, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Copier won't print black
Have you tried a new black cartridge?
1st I would try to clean the bottom of the black cartridge with a paper towel and some windex. Spray the windex on the paper towel, and then wipe the bottom of the cartridge so it removes any dried ink.
Then you can press the bottom of the cartridge with the paper towel for about 5-10 seconds and see if you get any ink to flow onto the paper towel.
Install the ink cartridge and run the maintenance program that HP has with their software, or just use the menu on the printer, and run the cleaning maintenance and repeat if it still doesnt work.
Worst case, replace the cartridge.
Hope this helps.
good luck.
Mac
Feb 09, 2008 | HP PSC 1210 All-In-One InkJet Printer
Printer will not copy
It Does keep asking if it fails to get it right, usually it fails to get scan of alignment page completed correctly because it fails to see one of the colours printed on its alignment page correctly,
I would guess that you should change colour cartridge as well (these I have seen deplete themselves trying print black when black ink is not present.
There is also a way of telling your printer to forget about alignment would you like to know how......Press and hold the Setup button, and then press Options (or Copy Options ).
Here is a link to how an alignment page should look and HP answers to your problem, please rate my solution for me.
Nov 21, 2007 | HP PSC 2175 All-In-One InkJet Printer
Photocopying
According to " HP Officejet R, PSC 500 and Color Copier - General Copying Issues and Solutions", under the problem heading "Black is not Black", notes that:
"The unit will perform mono (or black) copies using the color cartridge to create a composite black in Normal and Best modes. This is necessary to create the correct grayscale shades. NOTE: The HP PSC 500 all-in-one product cannot perform black copies. Scan the image in and print it out in greyscale.
The color cartridge may be out of one color of ink. Run a self-test page to verify that all the colors are there. Replace the cartridge if they are not."
In other words, the device only uses the black ink cartridge when used as a computer printer. When used as a stand-alone copier, it uses the color ink cartridge, and all three ink colors must be present and working to give a black and white copy. Perhaps you can refill the color cartridge with black ink in all chambers?
Nov 13, 2007 | HP PSC 500 All-In-One Printer
HP OfficeJet D135 All-In-One InkJet Printer Logo
47 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
