Question about Graco Quattro Tour Travel System
Headrest pice (attached to the top of the back rest of stroller) has become unattached
The pin that snaps the small headrest piece to the backrest of the stroller has unsnapped so the headrest has become unattached. Can I fix this on my own?
The pin kind of looks like this" [__________
Thanks for any help!!
s:)
  • Anonymous Sep 08, 2008
    I have the same problem. Do you actually need to use the head rest cushion to have it secure correctly or can I leave it off?
  • Anonymous May 21, 2009
    Love the first answer - would just change
    It takes a little force(or a flat head screwdriver) to push that bar back
    to
    It takes a fair amount of force(or a flat head screwdriver) to push that bar back
    Thanks!
We just fixed this issue tonight! We had to realign the bar (the silver bar you described) into the correct slots. One curve sits in the headrest piece, and the other curve slides into the seat back. If you hold the headrest in position, you should be able to see the slot at the same location as where the curve hits the seat back. Slide that curve into the slot from the side of the seat back.
Then align the 4 or 5 headrest tabs BEHIND the seat back, and the bar should position itself across all the "hinges". It takes a little force (or a flat head screwdriver) to push that bar back into the the "hinges", but once in it should work just fine.
g'luck!
Posted on May 12, 2008
    Novelist:
  • 126 Answers
Graco Children's Products Inc.
Product Instructions
LINK: http://www.gracobaby.com/customerservice/instructions.aspx
Telephone
Graco Customer Service is available Monday through Friday, 8am to 5pm Eastern Time.
1-800-345-4109 (US)
Postal Address
Attn: Graco Store Consumer Services
150 Oaklands Boulevard
Exton, PA 19341
OR
replacement parts
LINK: http://www.gracobaby.com/store/order/default.asp?N=10418+10413+10421&Ne=11
Telephone
1-800-345-4109 (US)
Postal Address
Exton, PA 19341
Posted on Apr 28, 2008
How to remove headrest in holden vs caprice
Hi David Should be a button one side need to press in and possibly a small hole the other side a small drill should be placed in hole and pushed against a small plunger when doing this lift headrest upwards till it comes out of backrest.
Dec 03, 2017 | Holden Cars & Trucks
Backrest of power seat goes back won't come up
I dont the vechile or type, but there is a small button on the plastic piece on the posts that hold the headrest. Push on it an lift headrest. Other vechile you have to pull up on the side lever to raise the headrest. Different on different vechiles
Jul 02, 2015 | Seat Cars & Trucks
How to remove headrests on 2001 volvo s80?
On the earlier 1999 & 2000 model V70s & S70s there are some plastic tabs further down the front backrest (vertically down from each headrest post) that you feel around for and actually snap them with pressure from your thumbs. The way to find them is to poke small dressmaking pins into the leather (leaves a tiny hole) to find the tabs which are perforated at their seams. The measure is around 140mm down from the top of the seat.
Aug 24, 2014 | 2001 Volvo S80
Clip for pushchair broke
Hi Kurina
We're in touch with you via e-mail about this and have a solution to your situation :)
Jul 06, 2013 | Quinny Senzz Stroller Lagoon
2006 Jeep Comander.....second row headrest
I have a dealer with some traditional values.Rang up to ask about booking in - could always cancel if fixed - and he said "lift the fabric at the base of the seat where it meets the backrest. In there there is a cable like a bicycle brake cable. Give it a prod, fold down the back rest and then fold up again. This cable makes the headrest move and sometimes it gets stuck". Well, tried it just now - headrest fixed. Total time to implement fix ~1 minute. Great Dealer! Could have ripped me of for loads of money and I would have never known.
Apr 18, 2012 | Cars & Trucks
How do you remove the head rest ina pontiac g6
If there is no visible button try this. Raise the headrest to it's highest position. At the backrest end of the headrest there should be a slot in the mounting hole insert. Insert a flat blade screwdriver, wriggle the screwdriver and the headrest and it should slide up and out. This image is only a rough guide from a g5.
May 25, 2010 | 2006 Pontiac G6
How do you remove the headrest on a 1998 daewoo
hi normally you can do this by...pulling the headrest top its maximum height , at the bottom you should see two black plastic rings, on either side of these rings are little partitions push these inward and pull the headrest at the same it can be a bit awkward but if you do one side at a time or get someone to pull the headrest while you push the clips in can be very helpfull...hope this helps please vote thanks
May 11, 2010 | 1999 Daewoo Lanos
Cannot get adjustable head rest off the seat
On the plastic pieces surrounding the insertion hole on top of the seat back,there is a very very tiny hole on the side of this piece of plastic. You need to insert a rigid piece of wire or a very fine nail of some kind into this small hole and push until you feel it give, then pull up on the headrest. it should come out. You have to do this on each of the two insertion holes. It's easier with two people.
May 11, 2009 | Chevrolet Silverado 2500HD Cars & Trucks
Love the Venezia stroller but can't figure out how lower back res
On the back of the backrest there is a **** in the fabric with a metal handle/lever. Pull up on this lever to adjust the backrest in numerous positions, including laying flat.
Jan 12, 2009 | Peg Perego Venezia Single MT Blu Moon...
Hot to remove backseat head rest?
Hi, On my 96 Passat there is a little black plastic plate, flush with the top of the backrest, which I push sideways in towards the headrest - it then lefts out.
Hope this helps, D.
Jul 08, 2008 | 1994 Volkswagen Jetta
Graco Quattro Tour Travel System Logo
477 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
