Question about Amana 16.8 cu. ft. / 476 liter Upright Freezer Deepfreeze AFU1705B
Door seal when closing door it is not vacum sealing like it use to?
    President:
  • Amana Master
  • 2,651 Answers
I wouldn't worry about vacuum seal. door gaskets contain a low powered magnet around the entire face for "contact" seal, id look into perhaps something placed on one of the shelves or door blocking the door from closing as tightly as you remembered. if you have a problem with that gasket. it would have to be physically ripped and where it didn't make contact you would have an influx of warm air resulting in ice balls forming inside door liner adjacent to seal
Posted on Mar 03, 2008
Can I replace insulation in door only?
Hi - I understand that you recently had something heavy drop on top of your Frigidaire Freezer door. From my experience the condensation does typically indicate poor door seal. When cold air and warm air outside is entering into the freezer it causes condensation. Try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then I suggest contacting your manufacturer and see who they recommend to repair the unit. Hope this helps! JK
Oct 21, 2015 | Frigidaire 5 cu. ft. / 142 liter Chest...
Condensation on top of freezer. It got something very heavy dropped on it. Dented the top corner. Door seal gasket IS sealing properly. is there a way to re-insulate just the door?
Hi - I understand that you recently had something heavy drop ontop of your freezer door. From my experience the condensation does typically indicate poor door seal. When cold air and warm air outside is entering into the freezer it causes condensation. Try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then I suggest contacting your manufacturer and see who they recommend to repair the unit. Hope this helps! JK
Oct 21, 2015 | Frigidaire 13 cu. ft. / 368 liter Chest...
Why is water leaking from door seals
the seal itself may be bad. coat the seal lightly with lipstick (your choice of color) close door GENTLY then open and check coverage and evenness of lipstick. any gaps will show lack of seal.
Aug 27, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Door will not stay shut, nothing is blocking it, no suction sound when it closes
1. Check entire condition of seal, even the bottom section and make sure it is not damaged.
2.Check the seal on the side of the door the hinges are on, they may be catching on the cabinet when closing, if so, use petrolium gel and rub it on the face of the seal, this will allow lubrication of the seal.
3.Also check that the seal has not swelled , if so, you can rectify this by using a hair dryer and starting on the sides the hinges are on, carefully heat the outside of the entire seal on that side, then close the door and hold firmly closed till cool, then move to the other side, top, then bottom doing the same process each time, this usually works a treat.
I hope that has been of some help for you and it works.
Please dont forget to vote, thankyou. regards Russ
Mar 09, 2011 | Sub-Zero 19.3 cu. ft. / 547 liter Upright...
I have 20 cf Whirlpool model #evl202nxtn freezer,I can feel cold air from the top of the door seal.Anyway to stop this with out replacing the seal.The freezer 18 mth old.Thanks
oh wow . i have the same freezer with same exact problem. i bought it brand new. i can definately see the seal on top is not installed properly. i always thought it was only my freezer but i guess its a manufacturing issue.
Sep 24, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Door won't close stay closed or seal
check gromets on hinges for wear. check weight on doors is it causing the door to droop? are the gaskets cracked? more information is needed if possible.
Feb 01, 2010 | Kenmore Freezers
My fridge door doesn't seem to close completely - No suction?
if you peel back the seal from inside out you should find some screws. losen the screws and replace the part that came out. to set the seal just heat it with a hair dryer with the door closed and hold the seal with a putty knife until it cools
Aug 11, 2009 | Frigidaire 14 cu. ft. / 396 liter Upright...
Freezer door of electrlux freezer keeps coming
Try cleaning along seal and seal itself. If it does not work get new seal. The seal do go bad after a while.. If under warranty call dealer you purchased from for them to replace.
Jul 06, 2009 | Freezers
Door doesn't close properly, leaks water
If the door seals are still pliable and intact there are two possible causes.
1/ The upper door hinge on the top of freezer unit has two adjusting screws under a plastic cover/cap which allows the upper hinge to be set forward or back altering/adjusting the spacing of the door seal to the freezer body. Moving the hinge outward at the top will cause the door to seal tighter at the bottom and lessen escaping cold air and condensation to form (water droplets). Adjust carefully so as not to create a weak seal (air gap) along other sealing edges of the door frame.
2/ Many United Refrigeration Commercial Freezers are manual defrosting. Moisture from inside the freezer can condense between the inner molded door panel (door shelves) and the exterior metal door. Usually ice buildup will occur in this space, but when defrosting or during high ambient temps the ice will melt and drip out along the bottom door edge/seal. Screws alomg the door frame (hidden by the door seal) hold the seal in place and also the inner molded door panel. The inner panel can be removed to replace the seal or to remove the ice buildup.
Jun 04, 2009 | Freezers
Freezer vaccum seal not working
check the gasket and make sure that it it not pinched and letting in air whe the door closes. primaryly around where the hinges are.;
Dec 27, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Amana 16.8 cu. ft. / 476 liter Upright Freezer Deepfreeze AFU1705B Logo
341 people viewed this question
Top Amana Freezers Experts
Victor Nwachukwu
Victor Nwachukwu
Charles T Nevin
Charles T Nevin
Sal De
Are you an Amana Freezer Expert? Answer questions, earn points and help others
