Quasar 33 inch tv model number sp3136k
Tv was moved across the living room now the picture is all
wavy the remote wont work none of the buttons will work
the volume is is very loud and wont turn down.
    Scholar:
  • 52 Answers
You more than likely have a cold solder joint, and moving the tv caused the hair line joint to crack open just enough to prevent current from flowing. But before you start soldering, give it a good inspection inside for a loose connector and/or wire. If no luck, take a solder gun and lightly hit the largest joints first, which are part of the largest component on the circuit board. It has a thick red wire coming out of it that goes to the tube. (Do NOT touch this red wire or disconnect it from the tube. It can still shock you, EVEN WITH THE TV OFF. This is a very high voltage with low current and probabliy will not kill you, but it will hurt very badly, so just be careful and stay away from the big red wire coming out of the tube.) Then resolder all the larger chips, transistors, and capacitors. If still no luck, then resolder the hundreds of smaller joints.
Posted on Mar 04, 2008
Why did my Quasar TV (1993) picture go out again, blue line across the screen? We had it repaired, 3 months later no picture, same blue line.
Sounds to me like something else is causing those parts to fail. It should be under warranty but depends on the repair shop. Why not just buy a new one.
Here are some choices for a new one:
RCA 42 LED42C45RQ Class LED 1080p 60Hz 3 4 ultra slim HDTV
Why did my Quasar TV 1993 picture go out again blue line across the screen...
LG 24 Class 23 6 Diag LED 720p HDTV Black
RCA LED32G30RQ 32 720p 60Hz Class LED HDTV Walmart com
May 29, 2016 | Quasar Televison & Video
I HAVE A QUASAR VV2008 TV/VCR COMBO AND I DONT HAVE REMOTE AND CANT GET TO NO CHANNELS EXCEPT 60 AND LINE
The remote model number for the Quasar VV2008 is VSQS1570 and can be ordered from Panasonic at 1-800-221-7262 or Go to a Family Dollar store and purchase the grey RCA universal remote for $6.00 about 6 inches in length. When you are ready to program it for the Quasar VV2008 push the code search button then the VCR button and enter 0162 then push enter. The red light should go off and the remote should turn the TV/VCR off and on. It worked for me 4/19/2013
Apr 12, 2011 | Quasar VV-2002 20 in. TV/VCR Combo
My unviersal remote wont work on my quasar it just works for the volume, i need the input button to work to swith my tv to dvd or video channel. is there a special code for this?
No,all universal remotes have it limited and difference troubles in each of tvs it uses.Try website like Remotes.com to buy an original remote.
Feb 14, 2011 | Quasar SP-2725 27" TV
I have a Quasar tv/vcr combo, model VV2007, I have no remote and bought a RCA universal remote and none of the 3 codes work, the most I can get out of it is channel and volume, I need to add channels but...
Sometimes the universal remotes do not compromise fully with certain models especially with combo models.
So you might a different type of universal type to connect with the Quasar codes, but it is ideal if there is the model mentioned in the manual of the remote.
Volume and channel working is what is most important and should be considered good enough.
Sep 14, 2010 | Quasar VV2007 20 in. Combo
Toshiba television and universal remote problems
Hi, as the sets get older the codes for older models get deleted to make room in the remotes memory chip for the newer models, this is probably why none of the universals will work for you, post the model number found on the back cover of your tv & I`ll look it up to see if theres a sub or the original is still available, video-tek
Jun 05, 2009 | Televison & Video
Need code for Living Solutions tv,vcr,dvd combination remote control. the TV is a quasar
the codes are
quasar tv---018,007,048
if you dont no to put in contact us
Apr 02, 2009 | Big Button TV Universal Remote
20 year old Quasar colour TV (no remote)
That is because the switches of the front panel buttons are stuck or defective.
Try first unplugging power for ten minutes, this probably wont work.
To fix this the TV must be taken apart from an expert, and front panel replaced.
You can enquiry here for parts.
What you can do at home, is getting a replacement remote and using TV with a remote, or buying a freeview box, and watching and changing channels through the box.
You can get a replacement remote here: Replacement Remote Control orReplacement Remotes
My suggestion, if it is supported in your area, get a set top box with 30 channels : Freeview - digital TV from Argos.
Oct 11, 2008 | Quasar SP-2723 27" TV
MY TV HAVE LOCK UP
I just fixed my celera k12b-c11 tv. All you do is hold the f button and the mute button in for 3o seconds, and your tv will unlock itself.
Sep 26, 2008 | Quasar SP-3235 32" TV
Tv is locked
I have a Quasar Model AM 51760221 WP 3915YW 13 inch TV made in 1985. I am using cable and none of the codes work published by Comcast work to make the TV work with my black box. They are unable to help at Comcast. I did get an updated remote from them, but still unable to turn off the TV to use the remote/black box.
May 19, 2008 | JVC AV-27430 27" TV
Astar ltv 19bs lcd
If you still have the TV, the remote has to be re-set. Hold the Enter button down approximately 10-seconds. It should re-set itself.
Jan 23, 2008 | Astar LTV-19BS 19 in. LCD Television
Televison & Video Logo
318 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
