Question about Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook
When turning on my macbook pro
The screen does not open up (all black) and all i hear is the fan shishing thru the speakers.
After my macbook pro has been closed for a short time and then I open it up, the screen is black and all I can hear is the fan going.
  • Becca727 Mar 10, 2008
    There's no startup chime.  I can hear the fan going, but the screen is black.
    Scholar:
  • 163 Answers
Do you here the starup chime? First place to start.. Will tell me if The initial startup sequence is testing and more info..
Posted on Mar 10, 2008
  • Ken LaDere Mar 11, 2008
    May need the video circuit reworked and hope that the CPU isnt the cause as theyre Integrated on these models. (BGA Mount).. Big mistake as far as I'm concerned. Weve repaired a few of these..
    Problem Solver:
  • 5 Answers
Does it work with an external?
1) If it does boot through external. Your LCD, LCD inverter, or LCD cable may need replacement.
2) If it does not boot, then it may be problems with video card or motherboard problem. May need motherboard replacement.
Please let me know the follow ups of it. Thanks!
Posted on Mar 03, 2008
Black screen on startup for macbook bro
It may be a problem with your light behind the screen or the driver's that produce the energy to light it up. Sounds like a hardware problem to me.
Mar 05, 2014 | Apple MacBook Pro 15-inch Mid 2009 2.53GHz...
How do i fix my macbook pro?
Is it plugged in? Is the battery functioning? Try holding down the keys command/option/p/r while turning the power on to your mac. Let it reset a couple of times. You will know it is resseting by hearing the apple chimb several times.
Jun 25, 2013 | Apple MacBook Pro PC Notebook
Fan won't stop
Resetting the PRAM may do the trick:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
you've tried rebooting, you've reset the PRAM, you've done it all, but your Mac is still behaving strangely. What next? In certain circumstances, resetting your Mac's System Management Controller (SMC) can be a solution. This is sometimes necessary to restore normal lower level system functionality to your Mac.
Here's how to reset the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Jul 27, 2012 | Apple MacBook Air Mac Notebook
When I booted my Macbook Pro today, I could hear the hard drive being accessed, but the screen remained black. Have you heard of this problem before? Last night, it was fine and showed no symptons
yes this happens. you can try doing this: power down then power up whilst holding down command, option P and R all at the same time. press these after you hear the chime. hold until you hear the chime a second time.
May 05, 2010 | Apple MacBook Pro Notebook
Black screen, hear voices , but no picture playing?
check your screen back Light or get a working screen and test it or your screen flax is bad
Mar 31, 2017 | Mitsubishi WD-73C9 73" DLP TV
My macbook pro wont start and i can hear the noise of the starup but the screen is black
Connect to external monitor to isolate the problem. If you get a picture on external monitor, then you know your screen is fu.k.d up. Since its a MacBook Pro, it might still be under the 1 year warranty, so take it to the Apple store and have them deal with it. If you get no picture on the external monitor, then you know you got a problem with the computer.
Feb 10, 2010 | Apple MacBook Pro Laptop Computer with...
No sound at all
Go to the system preferences from by clicking the Apple->system preferences menu. check the mute option is on or not. Also check the other options
Jul 03, 2009 | Apple Mac/iMac&iPod Speakers-(Bondie-Blue)...
Macbook chip shim
Thias can also come from a dead hard drive, or a dead backlight (screen).
The best test would be to plug an external monitor to see if something shows up. If yes, that would mean that the backlight doesn't work anymore. If not, then you have an other hardware problem (motherboard, hard drive).
You can check if the hard disk is the problem by removing it. You should then see a flashing question mark and the screen on.
Keep in touch ;)
Jun 25, 2009 | Apple MacBook Pro Notebook
Please clean-up the RAM modules wiping it with a dry cloth and re-insert it back into its slot .
May 06, 2008 | Apple MacBook Pro Laptop Computer with...
About the only thing you could try is to remove one each of the ram sticks in the machine and try them one at a time.
here is a link to the apple PDF file about it (you need acrobat reader or foxit PDF reader.
http://manuals.info.apple.com/en/MacPro_MemoryDIMM_DIY.pdf
If that doesnt do it then check and see if you have Applecare warranty still and take it in for service.
Dec 24, 2007 | Apple MacBook Pro PC Notebook
Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook Logo
244 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
