Question about Motorola Mobility MD781 Phone (51877400100)
Help with MD781 phone problem
I have the MD781 phone with 4 MD70 bases. Starting today, I have 3 bases that say "out of range" but the main base and one MD70 base still work. I cannot dial out of the phones that say "out of range". What can I do?
    Problem Solver:
  • 14 Answers
On the phone that says, 'out of range' you need to select MENU then scroll down to the option that says REGISTER and select that. Then go to your BASE UNIT and push and hold the PAGE button until the 'bad' phone synch's up again. .... I called into motorola support and they stepped me through this.
Posted on Jun 25, 2008
What is meant when screen says out of range
You will need to take your handset closer to the base because the signal is weak and out of range. Try locating the charging base in a more central location. If this doesn't work try this.
You can first try a Basic Reset.
A reset is done by following the below steps:
1. Disconnect the battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect battery into handset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base
For more info go to this site
Customer Support
Feb 27, 2015 | Uniden Dect6.0 Digital Answering Syst W...
Just purchased the phones yesterday. Today both phones say: Searching and then Handset out of Range. I can't get a dial tone!!!! They were charged all night.
Try changing the phone cord from the main base to the wall outlet, If that fails take it back to the store for exchange, because it is evident the main base is the problem.
Jan 15, 2011 | Uniden Lands Phones
I have uniden cordless phone model dxa15588-2, how do I register handset on base?
1-Press the hangup key (represented by a red phone) and the "#" key at the same time for at least five seconds.
2-Select "Deregister hs." Choose the handset and press the "Select" key (which also shows an envelope for messages).
3- Choose "Yes" to confirm deregistration. The phone clears its registration information from the base and deletes the link from its memory. The message "Handset not registered -- place handset on base to register. See owner's manual for help" now shows on the display. If you are out of range of the base, "Out of range" shows.
4-Place the handset in the base charging cradle. The phone automatically selects a new security code from those stored in the base.
5-Make sure your phone is working again after "Registration Complete" shows on the display
Hope this will Help. Thank you for using Fixya !!!
Nov 17, 2010 | Uniden Cordless Phone
Uniden powermax 24 out of range
Check the line comming into the main handset base. Make sure it is not cracked or your cat hasn't chewed through it.LOL This sounds like the most likley solution. Try hooking the main phone line to an ordinary old fashioned touch tone phone with a wired handset and if that is working then the problem lies in the main base of your new phone. It could be as simple as reprogramming the base.
Jul 24, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Hello, yesterday, I purchased an AT&T 3 Handset phone set with the model no. of EL52309 and I came home and read the directions that said the phones needed to be charged for at least 16 hours and so...
is the base in range of the other two bases, have you set each phone in the main base so they get aquainted., are you shure all plugins are snug? try a different telephone wire to hook up to the base from the wall (might be a bad wire) if that persists, try relocating the base, and test it their, if you are still without dialtone use a cell phone and call your tsp say it randomly stopped working and that you changed nothing... they will send someone out :P
Jul 08, 2009 | AT&T 1717 Digital Answering Machine
Out of range message
We've been having this problem for a while. I used to think the hand-held needed charging. But just today I tried pushing all the plugs firmly into the back of the base. It turned out that the main power pin, on the back right, had been pried loose which must be a problem with being gradually turned in its socket and rotating against a cuff which wedges it loose. This seems to easy and obvious a fix but both hand helds have stopped reporting out of range -after they reajusted them selves to the base.
Aug 25, 2008 | GE 25865 Cordless Phone
Probelm with registering additional headset for the philpsse 7450
OK here it is leave the additional hand set base plugged in & take the hand set with you to the main phone & base. 1. unplug the main base.
2. with the main base unplugged hold the find handset button on the base.
3.with your finger still on the find hand set button plug the base back into the power.
4.charge light on main base should be flashing.
5.while the light is flashing press & hold the hash # button on the additional hand set only until it says registration complete & its all done.
May 02, 2008 | Lands Phones
Registering handset problem
worked for us AFTER plugging/unplugging the base unit. thank you!
Feb 11, 2007 | Motorola Mobility MD761 Cordless Phone
Lands Phones Logo
301 people viewed this question
Top Motorola Mobility Lands Phones Experts
John Donghia Jr.
John Donghia Jr.
Level 1 Expert
Eric Sutherland
Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
