Question about Bosch Benvenuto B20 Espresso & Coffee Maker
Cleaning products where can I purchase the Bosch tablets for descaling the machine, and also the cleaning tablets too not to mention the water filter cartridge
I just ordered everything I needed for my Bosch Benvenuto B20 from wholelattelove.com.  It was easier than my previous purchase from Bosch to find knowledgeable people.  I purchased Super Auto Cleaning Tabs, Cleancaf by Urnex, and Claris water filters online.  Just call them if you're not sure what to buy.
Posted on Mar 26, 2008
  • Anonymous Mar 15, 2011
    nice
    "viagra-test-123"
My Keurig only brews a part cup
Most likely you need to change the filter and descale it as well.
I use a CleanCup once a month:
https://www.amazon.com/CleanCup-Single-Machine-Cleaning-Capsules/dp/B00E0QAS34/ref=sr_1_1?ie=UTF8&qid=1480095410&sr=8-1&keywords=keurig+cleaner+cup
I change the filter once every 3 months:
http://www.keurig.com/Accessories/6-Pack-Keurig%C2%AE-Water-Filter-Cartridge-Refills/p/Water-Filter-Cartridges
And I descale it every time I change the filter using this:
http://www.keurig.com/Accessories/Keurig%C2%AE-Descaling-Solution/p/Keurig-Descaling-Solution
Otherwise, the tubing is going to get clogged up in your machine and produce smaller and smaller cups of coffee, not to mention, when you keep your machine clean, your coffee will always taste its best!
Hope this helps!
Nov 25, 2016 | Keurig Coffee Makers & Espresso Machines
I cleaned my Jura Capresso with a tablet, but the message "Clean Machine/Ready" won't switch back to "Ready". Any suggestions?
Fortunately the problem you describe is not model specific. All Jura machines in the series C, E, F, J, S & Z models have the same problem. The Jura recommended maintenance is insufficient or erroneous. Here is how it occurs:
1- When new machine is set up, the instructions advice the owner to set up OK for use of Filter cartridges. This set helps only to display reminders for replacing the filter.
2- The initial set up instruction also advises that with regular use of Filter, descaling the machine will not be needed. That is really not accurate. Consequently, the reminders for descaling are delayed for over one year or more. This causes serious consequence with accumulation of Calcium deposits in the entire hydraulic and coffee system.
3- Use of Filters alone does not prevent Calcium deposits. Cleaning tables recommended & sold by Jura do not remove Calcium deposits in the coffee/water passages. The automatic descaling method recommended by Jura leaves the coffee side of the machine unclean. The error message in your machine is due to Calcium deposits in the Brew group, coffee outlet & the faucet dispensing coffee in the cup. I suggest all Jura machine owners should manually descale machine. Manually descaling includes use of 6 to 10 rinse cycles with descaling solution in the water tank. The error message "Clean Machine" is accurate. This error message is pointing to descale the Brew group, coffee outlet tube and coffee dispensing faucet by using rinse cycles.
After the rinse cycles are complete, refill Descaling solution in the water tank & continue descaling the rest of the machine by using hot water dispensing function, ½ cup at a time until the tank is empty. Finally, give a final flushing of machine to flush out remaining descaling solution inside the machine.
Services Unlimited Inc Parts Guru Since 1988
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Oct 06, 2016 | Jura Capresso Impressa Coffee Makers &...
How much bicarb of soda do i use to descale my bosch tassimo
Sodium bicarbonate is not a descaling product. It makes a nice minimally abrasive cleaning agent when mixed as a paste. Sodium ions will exchange with calcium in a water softener when the calcium is dissolved in water. Once the calcium salt (calcium carbonate) forms, it doesn't go back into solution in a neutral or basic environment. A bicarbonate solution will be basic.
Descaling requires an acid. The Tassimo products say "Do not use vinegar" (acetic acid). I suspect they use citric acid in their descaling product. You can try the lemon-flavored Kool-aid (the version packaged in the envelopes that needs a sweetener added when it's a drink). Mix 1 tablespoon of the powder in 1 pint of water. However, you'll need to make more than a pint of the solution since you need 500 ml of liquid per cleaning cycle. (1 pint is ~473 ml.)
I hope this helps.
Apr 24, 2012 | Bosch Tassimo TAS4011GB Coffee Maker
The machine says to descale _ How do I do that???!!
THIS INSTRUCTIONS ARE FOR THE MIELE CVA 615,
The coffee system must be descaled regularly. The time period depends on
the water hardness set. The appliance will display a reminder message and
will eventually lock if not descaled. The message window will first display:
"DESCALE AFTER COFFEES: 100".
This message will appear until the appliance is descaled or locks. When
the count is down to zero, the appliance will lock and the message
window displays: The appliance can only be used again
once descaling has been performed. Let the machine cool before
descaling. Remove the sleeve of the steam nozzle to avoid damage from
the descaling agent. Only use the enclosed descaling tablets for descaling.
The descaling tablets are specially designed for descaling this coffee
system. Other agents may damage the machine and affect the taste of
the coffee and hot water. The descaling tablets can be purchased
from Miele.
To prevent damage to the exterior of the machine wipe up any descaling
solution spills immediately! Add 2 liters of water to the water tank. Dissolve two of the enclosed
descaling tablets in the water.
^ Close the water tank and insert into position.
^ Close the door. The descaling will take place in the
automatic descaling program.
Automatic descaling
^ Turn the program selector
counterclockwise to the "Program
mode" position.Press e, to select "Descaling" with the asterisk. Press ENTER.
Jan 17, 2011 | Miele Coffee Makers & Espresso Machines
DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine My Magnificant machine is displaying Descale. Where i can buy some tablets to make a service and i need instruction.
Hello, you can buy descaling tablets at your local Starbucks. There is also a liquid descaling solution (small bottles) you can buy anywhere.
At the moment I'm using Jura brand descaling tablets I purchased at Starbucks. For instructions on how to descale (quite simple really), see here on p-17 at:
http://www.starbucksstore.com/images/products/pdf/DeLonghi_Magnifica.pdf
Hope this helps.
Jan 08, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
A red light is on and I think its the descaler light...what do I do?
Purchase some citric acid based descaling tablets,
Fill the water tank to the very top and add the tablet to the water
Insert the cleaning disc
Press and hold the button to start the descaling program
Continue to refil the watertank as necessary until the descaling light goes off (This can take over an hour on a Bosch machine - or about 20-40 mins on a Bruan).
Oct 29, 2009 | Braun Tassimo Espresso Machine/Coffee...
My tassimo brewer is by Bosch and it has a filter with it, will I still need to descale also?
definately, follow the mfg suggested cleaning in you booklet. the filter will not filter out hard water particles.
Oct 04, 2009 | Braun Tassimo Coffee Maker
Ordering cleaning tablets
I just called Bosch and they had them available. The product number is 310575
Oct 16, 2008 | Bosch Benvenuto B20 Espresso & Coffee...
Bosch Benvenuto B30
The cleaning program is different from the descaling program.
The machine is now wanting you to descale the machine. Get some descaling powder or tablets, desolve in water and let the machine run through the descale program.
May 31, 2008 | Bosch Benvenuto B30 Espresso/Coffee Maker
Descaling
No, you can not use vinegar. It will dissolve scale into chunks and block the water heating circuit.
Jan 07, 2008 | Braun Tassimo Espresso Machine/Coffee...
Bosch Benvenuto B20 Espresso & Coffee Maker Logo
563 people viewed this question
Top Bosch Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Donald Currie III
Level 1 Expert
ray gallant
Are you a Bosch Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
