TV dont respond
Neigther the tv manually nor the remote are working and the tv is stuck on the dvd mode. What can i do?
I have a few problem with this TV/DVD combo:
1 - I have a CD stuck in the player and can't be ejected!
(i have tried ejecting with remote then the button on the TV/DVD i'v also tried twezzers but the slot is to small).
2. Now the Remote dosen't work, just the Power Botton nothing else!
(I've bought new Batteries still not working, I have bought a new Universal Remote and this Mintek TV/DVD Combo didn't have a code so i did that whole search the remote library still nothing, also did the same with a couple of other universla remotes i have for other TV's & DVD's in other rooms).
Now the function buttons on the TV/DVD itself dosen't work, just he power button and stuck on the one channel it was tuned to when the problem started!
(I have tried pressinf the Source, while pressing the power button, then the Menu, while pressing the Power button, then Both together while pressing the power button).
To this point nothing as happened still SOS! I had lost the manual and went to so many sites to try and download a manual, but they have almost every manual but the DTV-265-D!
Please HELP ME ! ! !
  • psp007 Mar 03, 2008
    Thank You Shuttle83,
    I was going to take it to Best Buy and let the Geeks fix it, i just wanted to be sure that taking it to the shop was the only thing i had left to do.
    Thanks Again!
    psp007
  • Emersan May 11, 2008
    TV/VCR works fine on manual ,but dose not work with the original remote or universal remote, even with fresh batteries.Thanks for your respond.
    Genius:
  • 1,139 Answers
Hello psp007,
I hate to be the one who tells you this, but you have one of those TV sets that are controlled by a single processor (as most combos have even LCD combos) and that processor may have gone bad. This is why you have so many problems at one time. I would suspect the the main processor board has a problem. You may want to take this to a TV repair shop, because there is so little you can do for this problem since if it is the main processor you will need equipment to troubleshoot this problem and to remove and install the component with the problem. Taking it to a shop is your best bet.
I hope this helps,
Thank you,
Shuttle83.
Posted on Mar 03, 2008
2 Suggested Answers
SOURCE: mintek dtv-265-d no pictue
I had purchased Mintek Mdtv 265D , after Reaching Home (India) Tried to switch on the syastem but Screen Doesnot get on, as Per local expert the pwer supply having some problm, The same Set purchased in Month Sep 07 from Somewhere in US
Now the same is in India , how to repair and get rid of this problm
Posted on Jun 07, 2008
Tv stuck in dvd mode
There should be an input button on the tv to allow you to switch between dvd, tv and any other device you have connected.
Aug 22, 2014 | Akai LCT3201TD 32 in. LCD Television
Can not find codes for toshiba remote for my sony dvd home theater changer nor any specifics on hooking it up properly and it has s video but no hdmi hook ups help By the way i already pd 1459.00 dollars...
To find the code for the Toshiba remote to the Sony DVD changer.
If you do not know the device code for a particular device, you can view each available code for that device mode and sample the functions to find the code that operates the target device. 1 Press a mode select button on the remote. 2 While holding down INFO button , press 8, 5, 0, 0. The remote control enters program mode. 3 Point the remote at the target device and press Power button, 1, VOL UP, CH UP or PLAY. Some keys are ignored if they are not applicable to a specific device mode. 4 If the device responds to the remote control: Press INFO button to store the device code. The mode select button blinks twice. The remote exits program mode. 5 If the device does not respond to the remote control: Press UP. Press POWER. Repeat this step until the device responds to the remote. Press INFO . Note: When a search cycle is completed, the mode select button blinks 3 times. The remote displays each available code again. If no key is pressed within 10 seconds, the remote exits program mode and returns to the previous code.
The previous section was from the manual p.86: http://www.iusermanual.com/tv/toshiba-46vx700u-tv-manual.htm
Hooking the DVD changer to the TV: The TV has composite video inputs and can accept s-video by a adapter cable as in: http://www.amazon.com/S-Video-3-RCA-Composite-Cable-Laptop/dp/B002ZKTCUM/ref=pd_cp_e_1
May 05, 2011 | Toshiba 46VX700U LCD TV
Brand new dmr-ez49veb,has worked ok on setting it up.it is now stuck in vhs mode and will not respond using remote to select tv mode.I have scart and hdmi connections to tv and have tv input selected to...
i have a panasonic dvd rcorder / video combi model DMR-EZ49VEB. I have recorded something on DVD, which is 4 hours in duration, and I want to edit the recording and split it into parts. I follow the manual, but when I press EDIT the option to split isnt even there? I am confused, it is SUCH a difficult manual to deciphre, but the only 2 options there are "Edit title name" and "Change Thumbnail". The others are not listed. the disc is not copy protected or locked and is of sufficient duration to split the contents. HELP PLEASE :(
Dec 29, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
My husband inserted a dvd into the dvd player of our insignia tv/dvd player. The player kept ejecting the dvd. Now the tv is stuck on dvd mode and will not respond to remote prompts.
#1 TRY AND UNPLUG THE UNIT. I HOPE YOU DIDNT BUY A TV/DVD COMBO.. THESE ARE WICKED $$$ to have fixed.. if it is never ever use the built in player ever again ! buy a stand alone unit from wamart for a few bucks and if it goes bad they fit well in the trash,.. so if it still isnt responding the back of the tv needs to come off WARNING if you break the screen the tv is junk, so sett it on a good flat spot , remove back, locate dvd player and un plug it from the tv.. this will take it out of the circut and with luck give you back control of the tv..
jay the pool pump whisperer.. longwood florida, buy USA made products THANKS AND VOTE if i was of help or coment...j
Nov 21, 2010 | Insignia LCDTV26 26 in. Television
Dvd stuck in conia clcd1930
To Eject the DVD, my conia clcd1930 needs to be in "DVD" mode. This Mode appears to activate power to the entire DVD module. So the Eject button will only work in this mode.
Feb 19, 2009 | Televison & Video
Toshiba 14DLV75, stuck in game mode, buttons on TV & remote
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://youtu.be/wUpnETSm6_k
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Sep 03, 2017 | Toshiba 14DLV75 14 in. TV/DVD Combo
TV dont respond
Here is the fix for that problem. I tried it and it works as I had the same problem. I used the COMPOSITE cable to make the splice rather than the COMPONENT cable since it is lighter and easier to work with and solder.
http://www.fixya.com/support/t300197-tv_w_built_in_dvd
Jan 19, 2008 | Mintek DTV-263 26 in. TV/DVD Combo
Hitachi TV
If your remote transmitter is multifunction, such sa TV; DVD; and VCR operative; You may be in the wrong mode. Press the TV function first and then try to change the volume. If you still have problems, the remote may be defective.
Nov 15, 2007 | Televison & Video
Can't Change Inputs on TV
make sure that your remote is on the tv cotrle mode rather than the dvd control mode
Nov 10, 2007 | Mintek DTV-323-D TV
Televison & Video Logo
225 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
