Fantom drive doesn't work on my Dell Precision 650 USB ports
The drive doesn't work on my Dell Precision 650 but, works fine on another computer that I have. No idea how to trouble shoot this problem.
  • mrockwell Mar 03, 2008
  • mrockwell Mar 07, 2008
    It turned out to be a problem with the chord that I was using. I tried the drive with a different chord and it worked fine.
    Problem Solver:
  • 8 Answers
I am not sure, but it might be a patch, try the Microsoft Website: www.microsoft.com to find a patch for your Dell P. 650. Might be peripheral patch or something
Brentic
Posted on Mar 05, 2008
  • Brent Riseborough Mar 05, 2008
    Yes, it worked on my Dell P. 650, i tested it for you. But you will have to ring up the Microsoft Help Line (Which is what i done) because i forgot to wrte the name of the patch for you, sorry.
    Brentic
Usb ports in front on the PC are not working in windows 7
Hello try the vista driver from here:
http://www.dell.com/support/drivers/us/en/19/Product/precision-490-dt
You are probably needing the chipset driver, so the usb function will work again.
You can also visit intel here:
http://downloadcenter.intel.com/
And run the driver update utility, by installing a bit of software.
Make also sure there are no missing drivers in the device manager.
Hope this will help you
Mar 21, 2013 | Dell Precision 490 Workstation Xeon 5140...
My computer doesn't show the external drive
Try plugging the hard drive to a different usb port, if that doesnt work its possible that you may need to update the usb drivers.
Dec 11, 2011 | Fantom Computers & Internet
I bought a brand new fantom drive externl hard drive used it once and now it wont show up when i plug it into a usb port
Try to plug the external hard drive to a different port. if its not working try to use other usb device like ipod, or thumb drive and if the other usb device works it means the problem is the external hard drive it self. If the problem still the same the problem is the usb ports probably the motherbaord
Sep 03, 2011 | Fantom Computers & Internet
Drive is not switched on
check the input power switch on the rear of the unit...
It should be on 240V. Turn off the computer, then move the switch back and forth a couple of times... set to 240V. this assures the coorect input power to the external drive.
Secondly, move the USB port to another USB port on your computer. If it works fine, then it is a bad USB port.
Third, check the device driver in device manager on your software. try updating the driver... This solves a potential driver issue.
Good Luck,
Jeff
Sep 13, 2009 | Fantom Titanium II (TFD500C16) 500 GB USB...
Drive not being recognized
Have you tried this in another PC with, say, WinXP? If it worked then it may be 1 of 2 problems:
1) Driver Issue- you may use a compatible driver and not necessarily a "Fantom" driver. WinME needs drivers for these devices unlike WinXP
2) The USB port is not giving enough power to the drive for it to run (a problem common in older PCs). I have an external USB harddisk that needs to use 2 USB ports in my old Dell laptop since 1 USB port can't supply the power it needs. The cable should have a dual-USB jack on one end, this is so you could use the power from the other USB port.
Hope this helps
Jan 20, 2008 | Fantom Titanium II (TFD500C16) 500 GB USB...
Drive Not Ready
typical of external drives overheating.
i sell external case with fan at my store.
Nov 03, 2007 | Fantom Titanium Hard Drive
Drive Not Ready
Sounds like the enclosure is failing, the drive has bad sector/blocks or there may have been a breif dip in power which has effected the opration, locking up the drive and the computer while it was attached. Hope this helps.
Sep 23, 2007 | Fantom Titanium II (TFD500C16) 500 GB USB...
Fantom Drive TFDU16072A Error
2009 06 30 - I just had a similar problem. The Fantom external drive was working fine, but I had to shut down due to a thunderstorm. When I restarted the PC, the drive was not showing up. WHAT I FOUND: First, I didn't find this solution anywhere - everything seemed to point to a new install (or at least how to reformat and start over.) BUT, I right clicked on Computer, Manage, Disk Management - it still didn't show. On the right, under More Actions, I clicked 'rescan disks'. Now it shows up! And all of my data is right there. Whew!
Mar 20, 2007 | MicroNet Technology Titanium (TFDU16072A)...
Computers & Internet Logo
205 people viewed this question
Alun Cox
David Payne
David Payne
