Question about Pioneer TS-W307D4 Car Subwoofer
My subwoofer will not go
We have hooked everything up and the Amplifier is going and has power, but for some reason we cannot get the sub to go, We have changed the wiring and tried all different ways, is there something im missing? The instructions we got with it are not in english so no help to us.....
  • lucidity01 Mar 03, 2008
    the sub we have is a pioneer TS-W307D4 it has voice coils which means it has 4 terminals instead of 2 on the sub
  • lucidity01 Apr 09, 2008
    dont worry we have figured out the problem. We did have it all hooked up correctly, as i do actually know how to hook up car stereos but didnt know why this wouldnt work. we took the amp back to the place we bought it and it was infact faulty. problem solved
I hook the postive specker wire from the amp. to the positive conection on the speaker with a jump wire on the other positive conection on the same speaker did the the same with neg.wire also.I'm hooking up a JBL 600watts touring amp with two ts-w307d4. Is this the correct way of hooking up this project.
Posted on Apr 08, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 199 Answers
Is the SUB connected to both channels? I will give you detailed instructions on how to connect a sub. Check out this website.
http://www.ehow.com/how_5829_wire-car-stereo.html
Posted on Mar 03, 2008
How do hook up an amplifier and subwoofer to my car stereo?
If your stereo has preamp outputs, I would recommend connecting those to the input RCA connections on the amplifier. The connection from the amplifier to the subs is dependent on the capability of the amp and the impedance/power level of the sub.
Aug 31, 2014 | Car Audio & Video
How to hook up a dual voice coil subwoofer
The problem with dual voice coil subs is that the amplifier must be able to drive the load. I am assuming that each coil is 2Ohms each and the amplifier you are driving the subwoofer with is capable of driving that load. If this assumption (of the VC) is true your Amplifier will need to power the 2Ohms of the VC this will be "Normal". If the Amplifier is not capable of powering less than 4Ohms you will need to wire the subwoofer in "Series". If the Amplifier is capable of powering half the VC's resistance you can wire it in "Parallel". Normal wiring is going to be, Positive on the Amplifier goes to the Positive (red) side on the subwoofer and Negative on the Amplifier goes to the Negative (black) side on the subwoofer, then repeat this for the other output side of the Amplifier to the other VC, easy: This is "Series". Now if the amplifier is not capable of driving the load this gets slightly complicated. Positive from one of the positives on the amplifier goes to one positive side of the speaker. Negative goes to the opposite coils Negative side (black), now you get a short wire of your preference from the Negative that has no other input and run it to the opposite Positive side that has no other input: This is called "Parallel". If the Amplifier is capable of running a load lower than the resistance rating of the subwoofer then run the wire from Positive on the Amplifier to Positive on the subwoofer and Negative on the Amplifier to Negative on the subwoofer, and then run a short wire of your preference from the first VC to the other VC, Positive to Positive and Negative to Negative. Double check the wiring Red to Red and Black to Black in everything but "Series". Take it easy and don't wake the dead, I did that in the middle of the day they don't like being waken from their slumber.
May 02, 2014 | Re Audio Sxx12 12" 1000w Rms Sxx Car Sub...
Subs wont turn on
make sure there is correct wattage with the subwoofers and the power supply
Dec 07, 2013 | Sony Xplod XM-554ZR Car Audio Amplifier
My amps and subs are working, but my subs aren't hitting.
Try bypassing the remote wire staight to power instead of the stereo
Oct 26, 2009 | Lanzar VW12D Car Subwoofer
Hooking sub up
Hello missywarden,
According to the specifications, the amp is capable of "tri-mode" operation, that is, running normal speakers on the individual channels while also powering a subwoofer in bridged mode.
Your sub needs to be a minimum of 4ohms and should be relatively efficient. I'd look for a sub that has an RMS power range of from about 75 watts up to a maximum of 250 watts.
The sub connects to the leftmost speaker terminal (positive - right channel) and the rightmost speaker terminal (negative - left channel).
It's not going to be a really loud subwoofer. The power is 360 watts RMS which will be shared by the normal speakers and subwoofer.
Hope this helps.
Aug 05, 2009 | Power Acoustik TS620-2 Car Audio Amplifier
Sub cutting out
Check the 12v wire running from the battery to the amplifier. Also the sony explode is a garbage subwoofer compared to the Alpine.. sony (they say 1200w max but its more like 100w to power the thing) Amp could be going. Is the amplifier hot when running. If there is a burnt smell comming from the amp, its the amplifier
Mar 27, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
My sub flickers on and off in my truck!!!
could be a number of things loose wires bad ground fuse on its way out or internal problems
Feb 13, 2009 | Profile BAJA HA700M Car Audio Amplifier
Subs not hitting
remote wire turning on amplifier?
Ground for amplifier?
Gain improperly set?
Radio output crossed over above tuning freq. of enclosure?
Just suggestions. Not much info to go by.
Dec 15, 2008 | Jensen BP212 Car Subwoofer
Car system
if you have dual voice coils connect on each seporate sub negative left channel to possative right channel of the subwoofer same to other sub then conect the left possative and the right neggative to your box power terminal same to other sub then conect the two sub outs on your box left speaker positive to your positive left channel bridge then conect left speaker negative to the right speaker possative then connect your right speaker negative to your right channel negative brigdeg to your amp is single coil hook the box its self up the same way to your amp i have two dual voice cooil 12" hooked up to the same amp that way and it rocks without the power protecter turning on
Nov 09, 2008 | Pyle PLA2200 Car Audio Amplifier
Sony XM-1252GTR Amplifier
Can it power the subs? Yes.
Can it make them crank? Well, that all depends on your expectations. That amp/sub combo is going to give each sub about 125W, which isn't much. But if it's what you have, it's better than nothing. You might also consider using only one sub and bridging the amp. This would put about 340W on the one sub, which is much more reasonable.
Mar 13, 2008 | Sony XM-1252GTR Car Audio Amplifier
Pioneer TS-W307D4 Car Subwoofer Logo
138 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
