Question about Goldstar DH304 Dehumidifier
NO POWER TO MY DEHUMIDIFIER
MY GOLDSTAR DEHUMIDIFIER IS ABOUT 3 YEARS OLD AND IT JUST QUIT WORKING ONE DAY. DOESN'T APPEAR TO BE GETTING POWER TO IT. I CAN'T FIND MY OWNER'S MANUAL SO I AM HAVING TROUBLE TRYING TO SEE WHAT THE PROBLEM IS. IS THERE A RESET SWITCH OR SOMETHING TO TRY AND GET IT GOING AGAIN? CAN THIS PROBLEM BE FIXED WITHOUT BUYING A NEW DEHUMIDIFIER?
  • 6 more comments
  • Anonymous Apr 21, 2008
    ditto to that. same model, just under 3 yrs old. i hope someone can suggest a solution.
  • Anonymous May 18, 2008
    I'm equally confused & frustrated. would like to know if there's a solution.
  • Anonymous Jul 08, 2008
    My unit is under three years old. When I turned it on this season, nothing happens. I have checked the outlet, powercord, filter is clean. I feel it was a waste of money and I do not recommend this brand. I now have to contend with black mold.
  • P C Aug 23, 2008
    Same problem for me. My unit is about 3 years old. We use it only
    on the weekends we visit our getaway home in the summer. It worked
    well the last weekend, emptying the hopper about 3 or 4 times.
    This weekend it doesn't even hum. No fan, no compressor, not even the
    light indicating a missing hopper. Tested the outlets and there was
    no problem there.
    I pulled it apart and saw nothing that was obvious. It's almost like an
    internal fuse or internal circuit breaker went.
  • thebing Aug 24, 2008
    Same problem here. Is there a fuse that can be replaced?
  • korinklapp Mar 08, 2009
    my unit is only about a year old...same thing just quit working one day...doesn't respond. i too believe it to be a fuse of something of the sort.
  • Mrsgriggs21 Apr 08, 2009
    my unit is about a year old and just stopped working one day, the filter is clean as well as the coils. the red light just blinks on and off. The bucket is properly installed. I don't want to have to buy new unit..
  • bentzc May 19, 2009
    I have the exact same problem as Terry Shelly. My Goldstar humidifier is 3 years old and just quit working out of the blue.
  • 5 Answers
I took my dehumidifier apart and I found why the unit no longer would start.
First, there is a fuse inside the metal compartment that houses the control circuit board.
However, the fuse was not blown. Instead I found the relay that controls the compressor,
(circuit diagram calls it RY-COMP) was not functioning and was left in the open position.
The relay must switch the compressor on/off based on humidity, full water hopper, and
maybe other factors like temperature.
The RY-COMP is a large black plastic component on the circuit board with two
wires (blue and black) connected at the top. I tested the contacts and they remained
open when starting up the dehumidifier. Doing a small bit of rewiring so that the blue and black wire
were connected and also wired to RY-COMP terminal 3, the dehumidifier came back to life.
However, this is good for proving what broke but without an electronic control to cycle the
unit on and off and to halt when the water hopper is full it's not a valuable alternative and
it risks a burnout of the compressor from constant use.
I think the RY-COMP relay is a solid state relay which could have gone bad from a spike
in voltage when plugging the unit in or cycling on/off.
I certainly don't want to buy another unit where the circuitry is not robust enough to survive
plugging in every couple weeks. I was thinking I could try replacing the relay with a magnet relay which would probably survive spikes much better.
Posted on Sep 13, 2008
  • 828 Answers
I don't think there is any kind of a reset switch in these small units. The problem could be a broken wire or burnt off connector, bad power cord, or a bad switch. This type of problem must be traced out by someone who can use a power meter or Ohm meter.
Posted on Jun 18, 2008
It just quit.. was doing a good job and just not getting any power. no light. Have had it about 2 and a half years. Thanks
Before giving up on it. Test the outlet it was plugged into, to see if there is still power there. If not, a circuit breaker may have tripped or a loose wiring inside the outlet.
Thanks for choosing FixYa.
Aug 14, 2011 | Goldstar DH304 Dehumidifier
Had moisture on top for a few days. Then just quit running. Turned it off, let it for a day, turned it back on, it ran for a little bit and quit again and now will not run at all.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 11, 2011 | Goldstar DH304 Dehumidifier
Have a Goldstar Dehumidifier GHD30. Approximately 2 years old refurbished. The fan will run on the lowest setting but the compressor does not start. When I turn the dial to a higher setting the breaker...
doesn't sound good sounds , the compressor is bad .. you might want to check if it has a gfic. i could be bad, i would cut it out and try it without before i replaced a gfic
Jul 25, 2011 | LG DH30 GoldStar Dehumidifier
My Goldstar Dehumidifier is not collecting water. There is no air coming out the back. I have cleaned the filter.
Hi, Sounds like the fan quit....could be the board or the fan motor ...check for power at the motor...
heatman101
May 21, 2011 | Goldstar Dehumidifiers
Frost
Dehumidifiers2_bing.gif freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier2_bing.gif problem....
Dehumidifier2_bing.gif is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
May 17, 2010 | Goldstar DH304 Dehumidifier
My DH504ELY7 unit quit working.
look for A fuse probably gonna be internal or a lil breaker or a reset button
Feb 22, 2010 | Goldstar DH504EL Dehumidifier
Icing on back of coils on dehumidifier
could be dirt coils or low freon either way needs to be checked
Mar 27, 2009 | Goldstar DH3010B Dehumidifier
Gold stare dehumidifer
It sounds like there is an issue with the controller board. LG has a 5 year warranty on these models. You may want to contact them first instead of opening it up because it could void the warranty. My recommendation is to have this serviced if it is under warranty. They usually will tell you of a service center nearby which will service it free of charge since it is under warranty. If you do not live near a service center they may ship you a replacement and you send your old dehumidifier back to them. Make sure you have your reciept when you contact them so they can verify it is under 5 years old.
Jul 20, 2008 | LG Goldstar LD65EL Dehumidifier
Goldstar DH304 Dehumidifier Logo
1,178 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Michael Youngman
Michael Youngman
Jerry Greenberg
Jerry Greenberg
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
