Question about GE WSXH208A Front Load Washer
GE front loader washer soap inside door
I have been using Wisk high efficiency soap in all loads, yet after about 3 or 4 loads, when I open the door at the end of a wash cycle, there is a pile of liquid detergent on the rubber door seal. There is also quite a bit under the rubber seal where the water holes are as well. Any solutions?
  • sk122 Mar 13, 2008
    Wisk H.E. is for front loaders.
  • Anonymous Apr 18, 2008
    same problem here- no matter how small an amount of soap is used and even if a second rinse is used.
    President:
  • 1,294 Answers
You can try using soap powders for 'front loading' machines......
Posted on Mar 07, 2008
My 3 month old washer suddenly started leaking from underneath. There was a code displayed of a 5d, but the washer drains into a laundry sink, there are no kinks in the input line.
The washer is detecting too much soap. Make sure that you are using HE (high efficiency) soap Do a clean washer or hot cycle once a month with bleach or white vinegar with no clothes in it. Your washer only uses half the water that a regular machine does. The HE is specially designed for front loaders and these types of machines
Jul 11, 2011 | Maytag Bravos MTW6600T Top Load Washer
Door leaking
This video will show you how to change a door seal on this Bosch front loader washing machine
Dec 21, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washer is leaking
hi, Few things i can advice you:
  1. make sure the seal on the door is not damage
  2. make sure you using high efficiency soap only with your front load machine
  3. let me know if the leak is from the inside or the back.
Nov 23, 2009 | Kenmore HE2 Plus Front Load Washer
Hi We Have a ge front load washer and dryer and it seems that our clothes smell musty at times. I've tried leaving the door open on the washer when not in use. Could there be another prooblem??
Try using vinegar, baking soda, or bleach in an empty load to counteract any residues left in onboard water. Also check for debris stuck in door baffle(rubber sleeve between door and tub).
Nov 17, 2009 | GE WSXH208A Front Load Washer
Strong mildew odor in Duet washer
are you useing he detergent? if not this is your problem the washer cannot get ride of the soap so what it does is leave a layer of film in your washer and odor causeing bacteria forms in it. There is a product called AFFRESH you can buy it at SEARS it is made specifically for this. Do you leave the door open ragularly? The reason I am asking is because your washer is like your bathroom if you do not ventilate it properly it will grow mold and it needs to be cleaned. By leaving the door closed all the time it is very easy for the bacteria to grow.
So my advice is to leave the door open, make sure you are useing the correct soap (HE) high efficiancy soap, clean the washer with no clothes hot water and bleach and use the affresh or washer magic. Since you can smell the smell you are going to have to keep cleaning it abouit 2-3 times a month till it goes away. Then once a month. This is not a machanical problem or a whirlpool problem and is very commen in ALL front loader if you do not clean it regularly.
Jun 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Stinky towels
Unfortunately this problem can occur with all front loaders made by any manufacturer. The problem results from excessive soap and body oils that do not fully dissolve and/or rinse clean from inside the inner and out tubs. Front loaders are energy efficient and only use a little water so any build up between the tubs that gets higher than the water level is left behind. It is also natural that some moisture collects between the folds of the door gasket and, if not wiped out, will mildew over time.
Not to worry, a few changes in use (as compared to top load washers) can easily eliminate your current problem and keep it from returning.
First of all, make sure to ONLY use HE (high efficiency) detergent and make sure to use no more than 2-3 tablespoons per load (because too much detergent will cause oversudsing, not break down efficiently and build up between the inner and outer tubs).
To eliminate the problem you now have I highly recommend a product called Whirlout (available at Home Depot in the hot tubs section). Just one capful in an empty load with the hottest water cylce will break down the current build up and take care of any odors (a 2nd cycle if the problem is really bad).
To avoid any problems in the future, use the correct amount and type of HE detergent, wipe the door gasket dry when done with the laundry (for the day, week or however you do your laundry) and run an empty cycle once a month with a capful of Whirlout. If your machine is in a high humidity location (i.e. a basement), then leave the washer door cracked open when not in use.
Hope this helps, please rate my answer.
Jan 08, 2009 | Washing Machines
LG Washer (Mod# WM2016CW) obvious mildew smell inside
Jan 05, 2009 | LG WM-2277HW Front Load Washer
Type of detergent
You can use either but it must be "HE" or high efficiency soap for front loaders. It will be marked with an HE symbol on the container.
May 13, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Maytag Neptune Washer Door Locked
INSIDE THE SOAP LOADER THERE IS A LIME COLOR STRING PULL IT WILL UNLOCK LATCH
Apr 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
Problems
Greetings tammym545,
Generally an EFO error on a front load machine is caused by using too much soap, or the wrong type of soap. Ensure you are using HE (High Efficiency) soap in your front loader. HE soaps are specially formulated front loading units to be low sudsing, which is essential to a front loader.
Thank you,
Agent Dort
Go Ahead. Use Us.
Apr 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
GE WSXH208A Front Load Washer Logo
126 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
