Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
Dishwasher Our Maytag eq plus diswaher will not drain what do we need to do?
  • Anonymous Mar 17, 2014
    maytag jetcleam eq plus model mdb9100awq stops after one minute
    Problem Solver:
  • 44 Answers
If you installed a new garbadge disposal at the same time have you popped the factory drain plug on the disposal where the dishwasher drain tube connects to the disposal. The plug is inside the disposal dishwasher connection tube . You cant see it . Just drive a screw driver through it with a hammer.Itt will pop out and then the dishwasher will drain.Just a thought.I forgot to do this to mine.
Posted on Mar 17, 2008
Maytag jetclean dishwasher eq plus
The best dishwasher soap we have found is Finish Quantum and they have good rinse aid too
Jan 24, 2014 | Dishwashers
You need to pull it out and use a wet and dry vacuum to remove any water. then check the hoses to the drain and the pump and its housing.
May 27, 2013 | Dishwashers
Maytag eq plus dishwasher- how to disassemble bottom spray arm?
its probably leaving water in it and is clogged in the elecric pum or drain hose. somethins the pump has a rubber flap that will become lodged in the outlet port. this will cause dirty water to be left in the machine because of a slow drain. start by looking at the volume of water coming into garbage disposal where drain hose hooks up.
Aug 01, 2010 | Maytag Dishwashers
Maytag Jetclean Dishwasher EQ Plus - Lights flashing
either the control board or the control panel needs replacement. Most likely the latter. There is a possibility that both parts failed also. Usually water gets inside the touchpad, corroding and shorting the touchpad. Good luck
Mar 03, 2010 | Dishwashers
Maytag eq plus, not cleaning properly, seems the
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
h
Feb 28, 2010 | Maytag MDB7100AWB Dishwasher
Dishwasher makes a grinding sound and the armature does not seem to spin. Maytag Jett Clean Dishwasher-EQ Plus
you have stripped the emacorator clip from the motor stem
you can replace this with 20 mins and a t-20 nut driver, a 1/4 in nut driver
send the model number in a testimonial and ill send you the part number
Oct 03, 2009 | Maytag Dishwashers
Control panel lights blinking
I have the same dishwasher with the same problem, try pushing the delay/resume button, then the drain/off button. When the lights go off start your wash cycle.
Sep 17, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Maytag Jetclean Dishwasher EQ Plus MDB7100AWB
the door seal has gone better change the door surround seal also. check for case damage and obstructions aswell.
Mar 14, 2009 | Maytag MDB7100AWB Dishwasher
Panel lights all flashing when trying to start a load
Try pressing delay/resume then drain/off. In some cases you might need to do delay/resume then drain/off twice.
Dec 03, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Maytag dishwasher jet clean eq plus water not filling with water
My Maytag Jetclean Flexiload is 4 years old. Upon choosing a program the timer counts down but little action is heard. Near the end of the cycle an Error message comes up. The dishes are stiil uncleaned.
Apr 23, 2008 | Dishwashers
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
439 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
