Question about Jensen VM9510 Car DVD Player
Jensen VM9311/ UV7i wont turn on!!?
I got my uv7i for Christmas and installed it, worked fine for a while, then i had to unhook my amp and hooked it back up. Then i went to turn the radio on to test everything out, the head unit turned on for about two seconds then it turned off with the red power light coming on. I pressed the power button and it beeps like it is working fine but the red light stays on and nothing happens.
I pulled out the head unit to check the inline fuse, pulled the fuse, it was not blown, waited a few minutes and put the fuse back in. As i put the fuse back in the radio beeps as it does when you first hook up the power. So i turn the key to see if resetting it did anything, but again it turned on for 2 seconds and did the same thing.
Any guesses on this one?
  • 1 more comment
  • Anonymous Mar 21, 2008
    when i try to turn on a red light just comes on and it keeps beeping every thime i hit power
  • Anonymous Apr 18, 2009
    t hat **** does not work u dumb **** ***** i tryed it
  • Anonymous Mar 26, 2014
    tried in stalling it but still wont boot up
I have the same problem. Any fix or solution for this yet?
Posted on Jul 11, 2010
Yo, I've got the perfect solution to your problem. Pull out the head unit from your dash. Then, remove the wiring harness carefully from the unit. Now, push in the yellow power wire (even jiggle it a little) making sure it's tightly snug the small port of the wiring harness. Then, plug the harness back into the unit and try turning it on. I've found that the wires come lose easily on this unit. hit me back up at Darkintel74@aol.com.
Posted on Mar 28, 2008
2 Suggested Answers
avstuff
SOURCE: Jensen UV7i Need internal amplifier
I own a shop either get me the PN off the IC. I will either have it in stock or, can order for you. Audiovox will not sell parts for this unit. But, they will service this unit for you. Call us @ 727-530-5221, Radioactive Car Audio #1 in Tampa Bay area since 1987.
Posted on Jan 14, 2010
My UV7i just opens and closes as it pleases
Some loose connection on the LCD panel to the device, or inside the LCD, by a certain vibration the monitor seems to get like a christmas lights one on/off..
you better bring it to a certain service technician to provide through test on your device.
thanks
Feb 23, 2008 | Phase Linear UDV9010 Car DVD Player
Jensen UV7I Problem when i push my clutch in its mutes the sound.
i would check to see if a wire is touching the clutch pedal ,when its depressed.either its grounding out on the clutch arm or its a loose connection that is being moved by the clutch arm.
Mar 10, 2009 | Jensen Car Audio & Video
Dec 10, 2008 | Car Audio & Video
Wiring uv7i
you can use the deck without a remote, the only thing is you cant go into the system without the codes. there is a sequence code you must enter to disable it. there are a couple of videos on youtube but none for the uv7i. trust me, i 've been there on and off since the summertime. i am not sure if the sequence works due to me not hooking it up to external monitors but you can disable the blue screen with a on/off switch...only problem is, you'll have to do it everytime you turn your car on. here's what you do....
buy a on/off switch(radio shack $3)
hook the pink wire to one part of the switch-the other to the negative ground
put a dvd in(from what i hear, it must be store brought), wait unntil the blue screen comes up
turn the switch off...wait two seconds/turn on...wait two seconds/turn off...wait two seconds and turn back on. the blue screen is gone and video is on. ifyou still need the diagram, i'll scan mine for you.
Nov 09, 2008 | Phase Linear UDV9010 Car DVD Player
Jensen VM9311TS
try pressing the reset button.
Sep 07, 2008 | Jensen's VM9312 Car DVD Player
Jensen uv7i
did you try resetting the unit?
May 29, 2008 | Jensen VM9510 Car DVD Player
Phase linear uv7i
RUN A TOGGLE SWITCH FROM THE PINK WIRE AND THE OTHER END GROUND IT PUT DVD IN FLIP SWITCH 2OR3 TIMES YOU SHOULD BE ALL GOOD
Dec 28, 2007 | Alpine CDA 7893 CD Player
UV7i Jensen Audiovox In Dash DVD
Run a Lens cleaner kit on it. That is one of those Discs with a coth like material that can be lightly soaked with a cleaning fluid. You can get them at WalMart or Game Stop
Nov 29, 2007 | Jensen VM9510 Car DVD Player
Jensen VM9510 Car DVD Player Logo
845 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
