Question about Mag Innovision LT776s 17" LCD Monitor
Mag LT776s monitor goes black
When i turn on the computer, it comes up like it regularly does, then it goes completely black.
    Novelist:
  • 138 Answers
Hi this is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen went black, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Posted on Mar 15, 2008
When I turn on my computer and monitor, the monitor display is on for about 30 seconds, then goes black. The computer is on, the green light is on, but nothing on the screen.
get a bright light or torch and shine it on the screem if you see any faint image then the problem lies with your backlight, sometimes connectors come loose and thats your best hope. if you have a warranty of any kind its time to use it.
Sep 28, 2009 | Mag Innovision LT776s 17" LCD Monitor
HDTV on Mag LT776s
that monitor wont produce the 1280x720 resolution. It isnt hdtv ready
Aug 07, 2008 | Mag Innovision LT776s 17" LCD Monitor
Monitor black screen
Your first step in troubleshooting this problem is to plug in another monitor to your computer. If you are having the same problem it is related to your computer. If the second monitor works fine then your original monitor is shot.
May 11, 2008 | Mag Innovision LT776s 17" LCD Monitor
17 in Widescreen Mag Innovision
Dear tfollis
Have you checked the HZ that you are using the monitor in windows ? If set at a very high level (for example 100hz) it may damage the monitor as it is not supporting it. (and maybe this explains the reason for the shutoff as a means to protect the circuitry)
17 inch TFT/LCD Widescreens monitors are ussualy optimal at 1280x800@60Hz.
Right click on Desktop-->Properties-->Settings-->Advanced-->Monitor--> At this point check the Monitor Refresh Frequency.
Check this first and if this does not solve it then we can proceed to more serious hardware troubleshooting.
Regards
EngineerGR
Apr 30, 2008 | Mag Innovision LT776s 17" LCD Monitor
Monitor Goes Black
There are defect at the main board.
Try checking the capacitors.
Apr 24, 2008 | Mag Innovision LT776s 17" LCD Monitor
Mag Innovision LT776s Model 780
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Nov 23, 2007 | Mag Innovision LT776s 17" LCD Monitor
I need this information please
Try this site. I suspect however spares are not available. http://www.fixya.com/support/mag_innovision
Jun 02, 2007 | Mag Innovision LT776s 17" LCD Monitor
Mag LT776S Monitor (Screen turns black)
This is not quite clear. You say no image at home or at school but worked at the store Did you see it working at the store? Check the cord sonnector for bent pins and or replace the cord- then come back
May 16, 2007 | Mag Innovision LT776s 17" LCD Monitor
Does a bad power supply look like this?
i suggest that you buy a new monitor coz your current monitor is too old...there's some electric component is weaken...its better to buy new than to repair the old one..
Mar 08, 2007 | Mag Innovision LT776s 17" LCD Monitor
Mag Innovision LT776s 17 in. Flat Panel LCD
I have the same problem except it usually happens after Ive left my computer idle for a while... i.e . Overnight, I usually turn off the monitor and I hit the button after I come back to turn it on. I get the same flashing light for several minutes. This has been a problem for several months, but only recenly have i gotten the same error message you mentioned. Each time ive booted the computer up cold or restarted it has worked fine but this time it took longer along with displaying the message: Top Left to Right: SH770 P001 Bottom Left to Right: AU M170EN05 Anyone else who can clear this up?
Mar 04, 2007 | Mag Innovision LT776s 17" LCD Monitor
Mag Innovision LT776s 17" LCD Monitor Logo
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
