Question about Hoover Encore Supreme Energy U4293-930 Vacuum
Hoover Vacuum Encore Supreme
I bought one hoover Encore supreme (soft & light) at a Good will store but it needs the manual, the hoses and accesories. I would also like to buy extra bags for this vacuum. Thanks!
norma_alvarez29@msn.com
  • norma08 Mar 03, 2008
    Thanks for your very useful and Prompt reply! I really appreciate your efforts.
    Sergeant:
    Champion:
  • 281 Answers
You can try thehooverstore.com, or call a repair shop and I am sure they can order for you. Doubt that you will find a (#56511A01)manual tho. The hose part #43434268 and will sell for around $15 to $20. Dusting brush #43414145 $8 to $10. Extentsion tube #38634678 about $5. Furniture nozzle #38614029 about $5. Crevice tool #38617024 about about $5. Hope this helps.
Posted on Mar 03, 2008
    President:
  • 1,673 Answers
My Hoover Encore Supreme inhaled something through the upholstery hose that caused a big bang and then smoking.
hi helen.
that does not sound good.
you might have to open it up and have a look inside and see if anything has burned out.
or get some one to look at it for you.
Nov 17, 2017 | Hoover Vacuums
How do I change the belt on the Soft and Light Hoover Model #U4266930 Hoover send the manual through email, but apparent it is gone now...missing on my favorites list . Attempted to request second...
I have same problem, somehow take top all apart, looks like allen screws holding bag container on, remove that, get to screws right underneath top shell, then get to motor pulley from above . be careful not to pull off motor pulley when wrapping other end of belt around brush underneath, or else you'd have to take top all apart again. Good luck.
Jun 13, 2011 | Hoover Soft Light Supreme U4262-930 Bagged...
My Hoover Soft and Light Supreme upright vacuum has a model #U4264-930. The last two numbers in serial # are 05. I have no manual and need to change a burned out light bulb. Need to know two things:...
http://www.vacshopusa.com/pdf/hu4253930.pdf Use this link to download a pdfd scehmatic for your model. This link is the site I got it from. http://www.vacshopusa.com/elite_%26_elite_ii.htm You may find more info there. Just from looking at the schematic, I would guess the bulb cover would pop off (carefully) and see what type of bulb it is. Remove it, take it with you to buy a replacement.
Nov 21, 2010 | Hoover Soft Light Supreme U4262-930 Bagged...
I need instructions on how to change bag in a Hoover Soft & Light Supreme upright vacuum cleaner. Thank you.
Here is a link that will show you how to change bag (and more).
The model number of manual is not the same as yours but it will work for your machine.
http://www.hoover.com/pdfs/manuals/C1404.pdf
I hope this helps.
Feb 02, 2010 | Hoover Soft Light Supreme U4262-930 Bagged...
Loss of suction and very noisy
The most obvious and first fix would be to clean the filter. The noise is the tip-off. If your vacuum is noisier than usual the most common issue is a clogged filter, hose or bag. Check all of these. UNPLUGGED, use a straightened wire coat hanger to fish out any hoses and entry from the bag or bagless housing.
Foriegn obstruction is the main cause of noise coupled with loss of suction.
Dec 04, 2009 | Hoover Encore Supreme Energy U4293-930...
Replace belt - how do I get off the interior housing
Rather than try to explain this procedure by typing it, I'll give you a link to an online guide with pictures that show the procedure. You'll see two links on the page regarding belts , look at both and use the one that is closest to your model. Hope this helps.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
Aug 21, 2009 | Hoover Soft and Light Supreme U4266-930...
No suction for u4264-930
This link at the Hoover site is a general manual for the older uprights. It shows how to replace belt etc. Mine is a "Soft & Light" and it worked for me:
Dec 23, 2008 | Hoover Soft Light Supreme U4262-930 Bagged...
Hoover Wind tunnel supreme, loss of suction
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=40600&thid=562967
posted by bazballfan on May 01, 2008
Hello, I purchased two of these models in late 2007 and after changing the bags on each of them I have little to no suction with the vacuum. The hose is fine and I have taken them apart and there is no obstruction in the hose or in the base.
These worked so well and now they don't do anything. The bag isn't filling much and the simplest things can’t be vacuumed up
Please help me to fix this
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Hoover U5450-900 Windtunnel Supreme Vacuum
Sorry you are having a problem, it sounds lie you have done almost everything, but just in review it could be some of these problems:
Belt change – every 4 to 6 months
Are the brushes in good shape
Where does your suction drop off
Is the bottom plate securely on the bottom
Are there any gaskets that are broken or leaking
Is the bag installed securely
Did you check for any clogs or obstructions
Is the filter clean
Feel free to contact your local vac dealer in your area.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don – The Vac Man
Go Ahead. Use Us.
May 01, 2008 | Hoover U5450-900 Windtunnel Supreme Bagged...
Need to change a belt on a hoover encore supreme upright vacuum
I'm more specialized in Kenmore vacuums, but I believe there should be 2 screws at the bottom of the vacuum. You will need to remove these 2 screws to be able to remove the bottom cover. Once the bottom cover is removed, you should be able to access the belt and agitator.
Mar 07, 2008 | Vacuums
HOOVER VACUUMS
go to thehooverstore - this site lists a whole bunch of hoover machines, exploded diagrams and parts lists.
Aug 11, 2007 | Hoover Soft Light Supreme U4262-930 Bagged...
Vacuums Logo
967 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
