Question about Philips 26PF5521D 26 in. HD-Ready LCD Television
Philips 26 I have a philips 26" LCD purchased last year. Recently my DVD player broke, which was ran through S-Video cable. When out purchased a new one which could only be hooked up by using the component AV's red blue green. Turned on DVD player and see light distortion with the picture on both the movie and intro screen. Tried several movies same results went out bought new cables same result. Tried different AV outputs same result. I am really puzzled, could this mean all of my AV outlets are bad and how and how much can something cost to get fixed?
  • tlaram01 Mar 03, 2008
    Thanks for the info, but I tried the different inputs and outputs and different cables.
    Problem Solver:
  • 5 Answers
There is an input imbalance. Either try connecting your cables to different inputs on your TV, or try connecting to different outputs on your DVD player. (Only worry about the yellow video cable bit initially). Alternatively, try a different cable type; you'll have some ins and outs that don't use RCA connectors.
Posted on Mar 03, 2008
  • Raym0nd Mar 03, 2008
    Then look at the menu for your DVD. There might be a way of changing the output on (for example) AV1 to RGB or Composite. If not, there may be a similar option on the TV for changing the INCOMING signal type on, for example, the TV's AV1 input (or whatever). It's definitely an incompatible signal flowing down the cable, and it's got to be 'balanced' at the DVD or TV end by setting the spec. for the signal.
Crosley projection tv
Sounds like one is not recognizing the other, By you not being to get into the set up menu means it is not seeing your blue ray player. Are you sure they are compatible? If so then if there is another way to hook it up, like with RCA cables then try that. Also make sure that there is not more than one S-video option on it.
Mar 12, 2014 | Televison & Video
My phillips dvp5140/37. video player ,stops
Does the player ask for a password?
If it does look in the manual or contact Philips on their website.
This helped me a lot once.
Jun 13, 2010 | Philips DVP5140/37 DVD Player
Connecting samsung dvd to Philips 47PFL6704D LCD TV
Hook up your cables from your DVD player to these input on the back of your TV. 6131e0b.jpg The group of ports should be labeled as video 1 input. Use the Yellow, Red and White on the back of both DVD Player and TV. Then, change the input on the TV remote to input or video 1 to watch the DVD Player.
Sep 28, 2009 | Philips 47PFL6704D LCD TV
Philips 32TA2800
The Way Im understanding your problem is,
it seems like you need to hook your rcas directly to the tv and switch the surround to aux or something similar to that.
Jun 14, 2009 | Philips 32PF7421D 32 in. LCD HDTV
Broken lcd screen - PET704
You will find it is better to buy a new player. The cost of the part and repair will be about the same or more. You can still use the player with the a/v output to another monitor or television. Just use the supplied cables or purchase some for the connections. I hope this information helps you with your problem.
Apr 23, 2009 | Philips PET710 Portable DVD Player
Cannot view tv program while recording on VCR
Hi and welcome to FixYa,
Initially, pls set the Samsung LCD TV to the Source selection as if watching a playback evgen if you are going to do a recording.
If that does not work, pls postback manner of connection (cabling) from Cox digital cable system to Philips DVD/VCR to Samsung LCD TV LN-T3253HX/XAA .
Good luck and Thank you for using FixYa. Happy Holidays.
Nov 15, 2008 | Philips DVP3345V/17 DVD Player/VCR
Philips 26PF5521D 26 in. HD-Ready LCD Television Logo
181 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
