Question about Sony MFM-HT75W 17 in. HD-Ready LCD Television
Monitor - No Signal
Monitor not picking up signal from HP PC
I am currently working in safe mode
  • 425arts2787 Apr 22, 2008
    The tv comes on for a second then the screen goes black and then all I hear is the sound. I've checked the connection several times and the same thing happened when I hooked it up to the computer pc connection.
    Brigadier General:
  • 6,966 Answers
I am assuming that you are referring to the same monitor working only if the PC is in Safe Mode but not in Regular Mode.
This is possibly due to the Screen Resolution and/or the Refresh Rate Settings of your Video Card to way too high for the monitor. While in Safe Mode lower these settings in your Display Properties.
.Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 03, 2008
What is the problem of HP w1972a LCD monitor ?
If you have problem with your pc graphic card boot in safe mode 640 x 400 and change the settings of graphic card to 1366x768 60 hz. Then boot normal
May 06, 2014 | HP w1907 LCD Monitor
No input signal recommended settings hp vs15 monitor 1024x768 60h
old monitor 1280 x 1024
power light on?
OSD work?
if it said on the screen no input sig, then that is 100% true
the PC is not sending output.
check the video cable connections both ends
then if bad, boot PC to safe mode. does that work.
then maybe you set the PC graphic resolution too high for the monitor. use safe mode to set new , legal resolution
1280 x 1024 is max, do not exceed, the horz, vert, reso to the left here. if you do the monitor , will display, out of range. errors.
im confused, you show HP monitor then Sam.
why ?
my guess is HP question posted in SAM section.
so here is my HP answer
1280 x 768 @ 75Hz
if your PC or other device exceeds any of those. this old monitor
will go blank.
HOR, vert and refresh rates max.
to solve this riddle, set the PC to
1280 x 768
then connect monitor and bingo.
but there is a chicken and egg deal here.
if the display car is over this, as most new systems are.
then use safe mode to set the resolution to 1280 x 768
and reboot to normal mode.
boot and it F8 , safemode.
Sep 25, 2013 | Samsung SyncMaster 960BF (White) 19" LCD...
My Monitor keeps going black
Sounds like you have something overheating in the screen pull the back cover and blow it out.
Jan 20, 2013 | HP 17 1740 DVI Rotating LCD Monitor w/USB...
My Hp slimline desktop is getting a 'no signal'
more than likely it is set to to the wrong frequency. try and start the pc in safe mode and adjust the frequency to 60 hrtz. that should take care of it.
Mar 29, 2012 | HP Computers & Internet
My computer will turn on but my monitor does not get a signal and I've tried this on two working monitors and two different power chords. The lights on the keyboards don't even work. Any solution?
I was just dealing with this last night. My pc would come on, but I kept getting a "No Signal" message on my monitor. I first plugged the machine into a known working monitor. It worked fine so that eliminated the video card issue. Then I plugged the monitor into a different too worked. So I knew that the monitor was good. I then switched the cord from the faulty monitor and still didn't get a signal. I proceeded investigating the issue. I found that if you boot the machine in safe mode, it actually caught a signal. So...I figured it must be something to do with the resolution. My solution: Boot the machine in safe mode, change the resolution in the control panel and reboot the machine. If it doesnt catch the signal booting in safe mode, I suspect it is a faulty video card. You are likely to find what you are looking for online at or
May 20, 2010 | E-Machines eMachines Desktop PC
I have a blank screen on my HPf1905 monitor. I have a HPm7330n computer. How do I know if its the monitor or the video card? Monitor shows a message no input signal,then goes to sleep mode.
if the message you recieve is no input signal if only means that you have a problem with your video card, the monitor is fine but you need to have your video card check
Nov 21, 2009 | Computers & Internet
My tower wont turn off and monitor says no input signal and keyboard doesnt work
Do you have two video outputs on your PC ie. one on the motherboard adn a separately installed card maybe? If you do you need to set the BIOS so that it uses the AGP/PCIE video card and not the 'onboard'. Try the onbopard vodeo card first to see if you get a signal there.
If you do NOT have two video outputs, and you can not see a signal then you may have a prblem wiht your monitor itself. Is this a known working monitor to start with?
May 12, 2009 | HP Pavilion a1610n PC Desktop
I Have a HP Slimline S3040. When I turn it on I get a message appear on the monitor saying on G** Signal, then the monitor goes to sleep?
1. after pressing poer button repetedly press f 8 go to safe mode enable vga mode.
if that does not work
2. get a pcie, pci, or agp video less than $100.00 that should fix it unless the mobo is ging bad itself.
Oct 24, 2008 | HP Computers & Internet
Input Signal Out of Range
I have been having the same problem with my hpvs17 monitor when i start to use my web browser on linux distros. Now, for the next few days i am going to try my system on a regular crt monitor. if the monitor does not crash, than i will have to say that the hpvs17 monitor has a defect.It seems that when i go online, while i am in the middle of searching something, the monitor just shuts off and i get "input signal out of range".
Jan 31, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Sony MFM-HT75W 17 in. HD-Ready LCD Television Logo
139 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
