Question about Kodak EASYSHARE 5100 All-In-One Printer
5100 ink error
My 5100 was working fine until the frist time I needed to replace the color ink. It reads that there is no colored ink after I tried replacing the cartridge. Kodak sent me a new print head and it still showed the same problem. Kodak then replaced the printer with a refurbished printer and I still get the same thing. The light for the replace color ink is on and the green light is flashing. I have tried to calibrate the system to no avail. Any help would be wonderful.
  • 1 more comment
  • flumixed May 06, 2008
    I purchased on of the printers and used up my first ink cartridges. When I put in totally new cartridges I was quickly told that they were empty. What's going on here? I thought this was supposed to be long lasting, not instantly gone.
    Also my printer will not communicate with my computer properly since it first "ran out of ink" And my computer keeps reporting voltage errors on the USB port.
    Should I return the printer and purchase some other brand with out this error?
    My home email is javanhoy@yahoo.com
    Is the ink cartridge related to the lack of communication to the computer?
    Is the printer to cause of the USB voltage error or is it more serious and I need to take my computer into the shop?
  • Anonymous May 18, 2008
    My ink is saying it is empty but I just replaced it.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 41 Answers
When Kodak sent you the new printer did they send you new ink tanks as well? There was a known issue that when the printer runs out of ink and you replace the ink cartridge the printer writes the "ink tank empty" error to the new ink tank. So if your trying to use the same ink tanks from the original printer you will still see the problem.
To fix the issue. remove the ink tanks. The are all worthless now throw them out. No go to this link and download the new firmware
http://www.kodak.com/global/en/service/downloads/dln_ekn033539.jhtml?downloadStep=s2&selectedDownload=dln00182&operatingSystem=windows_xp&selectedLanguage=en&downloadLanguage=en
With the printer on and connected to the PC (with no ink cartirges installed) run the firmware updater exe
Now sorry to say you need to get new ink cartridges.
If its worth your time call Kodak and tell them you purchaced one of their printers and it had a version of firmware that was bad, and that it wrote the out of ink error to new ink tanks that you put in and you would like some free Ink cartridges to replace the one you bought and maybe a few extra for your time.
Kodak should be thankfull that you did not just return the printer and by a differernt brand. Dont get me wrong, once you got one of these kodak printers that is set up with good firmware and software they are awsome they print good photos and the ink is cheep.
I hope this helps!
SDtester
Posted on Mar 07, 2008
Both printer ligh flash red yet both cartridges are new and full.
I have removed printer head and swiched of printer for 15min as suggested by Kodak but the red light still flash.
Please can you help.
Kind Regards - Patrick
Posted on Mar 04, 2008
I have a PIXMA MP 110 CANON and when i go to print it says CARTRIDGE IS JAMMED PRESS OK. The computer says it is a ERROR 5100 problem and press OK AND IT SHOULD WORK .but it doesn,t. The cartridges are...
You are facing e5 error which cannot be solved.
For Canon printer, if you refill about 4~5 times, especially color, the printer does not read that particular cartridge.
Well for solution? You need to replace the cartridge with new one.
Just blame Canon....
If you would like to save money, try refill kit by "ROADINK".
At least you can easily save $100 for color cartridge (facing e5 error after 4~5 times of refill)
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
Apr 19, 2011 | Office Equipment & Supplies
I'm getting a 5100 "check printer" error on my
Reseat (remove / reinstall) the ink cartridges if an error appears. Removing Ink Cartridges:
  1. After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.
  2. Press down on the semi-circular tab to release the cartridge and then remove it.
    Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
  3. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
    Note: Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
Installing ink cartridges:
    Note: After confirming that the scanning unit support is fixed into position, release your hands.
  2. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
    *One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
  3. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
  4. Confirm that the ink cartridges are installed properly.
    <1> The ink cartridge is not installed properly.
    <2> The ink cartridge is installed properly.
  5. Fold the scanning unit support and close the scanning unit (printer cover).
  6. Wait until the preparatory operation is complete; it takes about one to two minutes.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 23, 2010 | Canon PIXMA MP180 All-In-One InkJet...
Kodak 5350 Color Ink Error Problem Solved
Yes the cartridges of all newer printers have chip that indicates the cart ink level, when the cart is empty the chip self destructs.
May 04, 2017 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5100 Needs Both Cartridges To Print?
Unfortunately, you cannot used the printer if one of the ink cartridge is empty., compare to the other printers you can print a black text or gray scale if the color is empty or one of the cartridge is empty.
All kodak printers work the same both cartridges should have ink on ink before you can use It.
Nov 04, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Error message 5100 on Canon MX300 printer
If the ink cartridges are stuck you can manually slide them back to their default position and check for paper or junk which may have slipped down the paper chute and is blocking the ink cartridges.
Remove the blockage
Reset Printer
Done
I just had this problem and it was easy to fix.
If this not help, buy another printer! Cheaper than service...
Oct 22, 2009 | Canon MX300 Office All-In-One Printer
Will not print. color ink cartridge light keeps
..."Open the ink supply andgently move the ink cartridges to the left. Then reach in to the rightside and you'll find a small (1/2 x 1 inch) sponge. Push it down andoff/on the machine. try it now. or ...go to where I found out more than I should know about Canon's and where I got my quote...http://www.fixyourownprinter.com/forums/inkjet/39177 good luck.
Oct 21, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Service Error 5100 on Canon MP150
i need a mp145 cartridge reseter pls give me a link to download. tnx!
Oct 12, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Error check ink cartridge
Hi ,
As per the information provided by you it seems to be a hardware issue however u cvan try these steps .
Steps >
Take out the ink cartridges from the printer > without turning off the printer unplug the power cord > press # and 6 key together , now without releasing the keys plug in the power cord .
keep on holding the keys down until the machine turns off automatically .
after the unit turns on again it would do the allignment give a msg for insert ink cartridges . insert the cartridges at that time . and see how it works out .
Thanks
MAC.
May 24, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Service error 5100 on canon pixma mp130
When this happened to me, I beat my head against the wall until I finally figured out that the waste ink absorber on the right side (spongy looking thing), was overflowing, and clogging the nozzles. I took a piece of paper towel and absorbed some of the ink. Make sure to wipe the colored ink absorber as well.
Neal Moilanen
AAA Virtual Assistants
http://www.aaava.net
Jan 24, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Kodak EASYSHARE 5100 All-In-One Printer Logo
182 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
