Question about Refrigerators
Over under refrigerator
Top freezer - freezer is toooooo cold. even dialed back to 1 it is too cold.
we are guessing that the defrost thermostat on the freezer is failing. might you agree?
    President:
  • Refrigerators Master
  • 2,651 Answers
No , actually a bad defrost thermostat would not allow the unit to defrost, too much ice would build and you would be losing refrigeration/ freezer capabilities. a faulty cold control would cause refig to contstantly runf( never cycle off and sened verything intoa deep freeze, regardless of setting, so i'd look towards control fro your problem description
Posted on Mar 03, 2008
Hss25gfpd freezer not freezing
when you had the back wall off how did the evaporator coil look?was the frost pattern even all over the coil or just on the top or bottom,if it didn't have an even frost pattern covering the whole coil you have a freon leak and will have to replace the machine.it will just keep getting warmer
Jul 08, 2012 | Hotpoint HSS25GFP Side by Side...
Model number HTR16ABSERWW
You have a bad defrost timer .
The defrost timer is a timer dial you turn to bring compressor on.
Get model and serial number of freezer/fridge and buy a new defrost timer and install and everything should be fine
Jun 01, 2017 | Hotpoint HTR16ABSR Top Freezer...
Beko CDA751FW/1 mostly on all the time - fridge 4 degC, freezer -30degC
there is no thermostat in cda751fw/1. apparently the pcb controls fridge temperature. which pcb, the main one or the one behind the temp dial I dont know which.
Apr 11, 2012 | Refrigerators
My Roper refrigerator stopped getting cold, although the refrigerator lights and the fan in the freezer works. What is the problem?
If the freezers warm, possible defrost timer bad, if freezers cold, set to middle setttings on both dials, the 1-10 OFF dial operates the compressor, the COLDER/WARMER dial operates the flapper door that regulates freezer air into the reefer box, if set to max cold that makes cold freezer, not reefer.
Nov 01, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
GE Hotpoint Top-Freezer model - freezer works but the rest of the refrigerator is not cold - even when we turn the cold dial up to 9. Model - CTX14C1TGLWH
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 01, 2010 | GE Hotpoint Top-Freezer Refrigerator
Bad defrost timer/ thermostat???
It definitely sounds like you have a bad defrost timer, that is the reason the coils are icing up on you. The next issue, which may or may not be related is the freezing of items in the refrigerator. Usually the cold air is transferred, through a vent with a damper, from the freezer and into the refrigerated section. The "thermostat" for this section is actually usually just a lever to adjust the position of the damper. That being said, usually when you have a problem such as you are having, it is either a stuck or broken damper (or damper component). Hope this helps
Nov 16, 2009 | Kenmore 21.9 cu. ft. Bottom Freezer...
Freezer on bottom, cold, fridge not cold,ice on
Probably the difusser door that allows cold air from the freezer into the fridge portion, either stuck or control dial faulty
Aug 22, 2009 | Refrigerators
Our compact refrigerator doesn't get very cold,
One is the coldest. Post a model number and I may can help more. If it's a manual defrost then defrost it. If it's auto defrost- If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 11, 2009 | Refrigerators
Kenmore elite 596 73503201 no cooling in top compartment
if the freezer is getting cold the problem is due to the cold air from the freezer not getting into the refrigerator. There are several things that can cause this problem. The coils in the freezer icing up and not defrosting properly is one of the things that can cause the refrigerator not to get cold enough. Another problem is the fan that blows the cold air from the freezer compartment into the refrigerator, not working. When the compressor is running open the refrigerator's door and push the switch that makes the light go out. You should hear the fan blowing the cold air from the freezer into the refrigerator, when this switch is pushed in. If the fan is working then you will need to find what is blocking the air flow. Iced up coils are a common problem. The icing problem can be due to a defective defrost timer or something defective in the defrost circuit. Click here for more information. Check for these problems and let me know what you have found.
REFRIGERATOR TROUBLESHOOTING
#1 Refrigerator side getting warm Freezer still cold
Evaporator fan motor not running.
Defective defrost timer. See Defrost Diagnosis Procedure
Defrost heater defective. See Defrost Diagnosis Procedure
Defrost thermostat defective. See Defrost Diagnosis Procedure
Airflow blocked from freezer compartment.
Freezer control turned to "coldest" setting blocking air flow to refrigerator side. On most refrigerator/freezers, the freezer control closes a baffle when turned to coldest setting, and this blocks off the air flow to the fresh food compartment.
Fan blade broken.
Defective door switch on older models.
Light staying on with door closed.
2 Refrigerator & freezer compartments both are getting warm
Make sure refrigerator is plugged in and has power.
Condenser fan motor on bottom under refrigerator not running.
Condenser coil clogged.
Defective defrost heater. See Defrost Diagnosis Procedure
Defective defrost thermostat. See Defrost Diagnosis Procedure
Cold control defective.
Compressor overload defective.
Compressor relay defective.
Compressor defective.
Low on refrigerant. #3 Freezer compartment getting hot.
Defrost timer stuck in defrost cycle.(replace)
Defrost thermostat stuck.(replace)
Ice maker stuck in harvest cycle
Light staying on with door closed. 4 Ice maker not making ice
Defective inlet water valve.
Freezer temperature not cold enough. (see problem # 2 & 3 above)
Defective thermostat in ice maker.
Defective drive motor.
Water inlet tube clogged with ice.
Defective module in newer style icemaker. 5 Refrigerator sweating around door edges
Door gaskets leaking air.
Defective case heaters.
Energy saver switch not set to reduce exterior moisture
also if require more help click the link http://www.applianceaid.com/refrigerator.html please do rate the solution .thanks in advance.thank you for using fixya.
Mar 27, 2009 | Refrigerators
REFRIGERATOR
Sounds like a defrost problem or a plugged drain... to get it to work temporary defrost the freezer. Unplug the refrigerator, open the door and get a blow dryer and warm up the freezer. wait until the water stop dripping out or about 12 to 24 hours and then you can plug it back in . it will work for 2 to 3 weeks. To unplug the drain.defrost the freezer .remove the back cover. Use a pipe cleaner to clear the drain. pour a few cups of hot water down the drain. The defrost systems is:
HEATER-DEFROST
THERMOSTAT-DEFROST
TIMER-DEFROST
Start with the timer. It is just under the front kick plate. there is a knob you can turn it slowly.until it clicks off the compressor. then open the freezer and listen . You should hear the heater come on .. it will sizzle when it comes on ...
You will have to remove the back panel of the freezer to check the heater for and thermostat for continuity. Heater are the lease likely part to go bad... I always change thermostat and timers together.
let me know if this helps or we can chat if you need more help.
Aug 10, 2008 | Refrigerators
Refrigerators Logo
71 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
