Question about Acer-Veriton-M410-US3800P AMD Desktop PC - AMD Sempron 2.2GHz, 1GB DDR2, 160GB SATAII, DVDRW, Gigabi
I bought a Simpletech signature mini hard drive. I plug in the USB cable to my computer and once I do that I get a message saying POWER SURGE HUB PORT, THE USB HAS EXCEEDED THE POWER LIMITS OF ITS HUB PORT. I don't know why I'm getting that message. Please help.
Your USB port is incapable of supplying the required amps of power. ALL these little 2.5" drives need up to 1000 milliamps of juice, regardless of who makes them. I have yet to find any PC that can supply more than 500ma from a single USB port (and even that is optimistic). That is precisely why several portable drive manufacturers supply a USB splitter lead to facilitate an extra 500ma of power. (But some charge extra for this lead).
SImpletech supply the splitter lead with the drive, so please try it, as it may solve the problem.
In addition, some makers, including Simpletech, provide a 5 volt auxiliary power socket on the drive case in (unacknowledged) admission that many people do not have a second spare USB port and that, even if they have, it isn't a reliable source of power anyway! Also, they don't supply the necessary PSU and they deliberately withhold the necessary specification for the needed PSU. You need a 5 volt, 1000 milliamp power adapter costing anything from $10 to $30 (ridiculous!)
These solutions should be tried before assuming the PCs USB port is faulty, because it 'probably' isn't.
Posted on Jun 23, 2008
  • 121 Answers
The portb does not support it or its faulty try a pci usb 2.0 card for around £5-10
Posted on Mar 03, 2008
3 Suggested Answers
Buschchris1
  • 474 Answers
SOURCE: ACER Veriton 5600GT how to turn off USB power after shutdown
Not likely.
What you have is power over USB which is good because it allows the hard drive to get enough power to run without a seperate power cord. This is also usefull for IPODS and other media that Charge through a USB. It means you can turn your computer off and still charge something.
If its an external hard drive, its meant to be removed. You can right click and disconnect it from the bottom right and then remove it safely.
You may have a port that doesnt provide power when turned off, maybe a front USB port, you could plug it in there.
There most likely isnt a way to change any jumpers unless your system board instructions specify that you can and how to. Dont go tinkering around because if you put jumpers on the wrong spot, you can blow some of the small components on the board.
This would render the USB completely useless.
If you want a permanent extar HDD for back up, just get a new IDE for the internal, There cheep these days. you can get a 250 gig IDE for under $60.00
Posted on Feb 03, 2009
  • 131 Answers
SOURCE: connecting speakers to Computer
It's usually the green plug that you hook up speakers to. If you look closely at the sound card area of your computer, you will see little pictures telling you which one is for the mike, line in & speaker.
Posted on Feb 15, 2009
For the last couple of months I've had to un-plug, then re-plug my EHD to get it to be recognized by my HP laptop. Today my HP says that the device is not regonized. Can the Signature Mini be re
If you have a SimpleTech SimpleDrive connected to your computer and you're experiencing problems with the external hard drive, there may be several reasons why it's malfunctioning. Troubleshooting your computer can help rule out common problems and the possibility that the hard drive may be defective. If you recently purchased the device and suspect there is something wrong with it, return the defective drive to SimpleTech or the reseller for a replacement. Incompatible USB Port Problems SimpleTech SimpleDrive plug and play options makes it easy for you to connect the device to your computer. But you may encounter problems if your computer's USB (Universal Serial Bus) ports are not compatible with the external hard drive. Make sure your ports are powerful enough to operate the drive. USB 2.0 ports are recommended, but if you're using an older computer with 1.0 ports, the hard drive will function much slower or you may receive an error message that the device is not compatible with your system. b> Missing External Drive Letter If you're unable to find the SimpleTech external hard drive's letter on your desktop after you have installed the drivers for the device, it's possible that the external drive may be assigned to another drive. Sometimes, the hard drive is assigned to a network drive and you may need to manually change the drive's letter in Disk Management. b> SimpleTech SimpleDrive Incorrectly Formatted b> SimpleTech SimpleDrive is normally pre-formatted for Windows NTFS (New Technology File System), but Mac users may need to copy the backup software and reformat the external hard drive for FAT32 or Mac OS to be able to use the external drive. If the external hard drive is not formatted correctly for your system, it may not function or work properly. b> External Hard Drive Inaccessible If you receive an error message that says "Drive Inaccessible," the SimpleTech SimpleDrive may not be able to read the service area of the platter. If the external hard drive emits a loud or abnormal sound, this could mean the device is failing.
Test the drive on another computer to see if it is working properly. Otherwise, the external hard drive's surface area may be damaged or corrupted.
Replacing a Defective Hard Drive You can return a defective hard drive that is under warranty to SimpleTech. The manufacturer will exchange the device if the seal is not broken. But if you break or tear the seal on the case, any warranty claims will not be accepted and the device will be returned back to you. SimpleTech will only accept the device if you contracted a commercial data recovery company to retrieve critical data from the external hard drive and the seal needed to be broken. Before returning the defective drive, you will need to secure a RMA (Return Merchandise Authorization) approval number from SimpleTech and furnish any invoices or documentation regarding the data recovery company's services
or if its a usb external drive you might need a usb 3 card installed on your computer your computer might not have enough usb output power USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/ these can be purchased on Ebay cheap and easy to install http://www.ebay.com.au/itm/PCI-e-PCI-Express-USB3-0-Card-new-NEC-720200AF1-chipset-/330608109325?pt=LH_DefaultDomain_0&hash=item4cf9c7670d for roughly $9 or $10free postage Hope this helps.
Jan 24, 2013 | SimpleTech Signature Mini 250GB External...
The SimpleTech 160GB ext. drive has a usb 2.0 cable with a y plug. I can only plug in one but I use the additional power supply. I get a message at times telling me to use the usb 2.0 port for faster...
You are using the correct connection, the external power supply is powering the drive, so the USB cable is just handling data. I believe the message may be telling you that you will get faster performance using a USB 2.0 connection, it is probably sensing that your computer's USB port is USB 1.1.
Feb 24, 2011 | SimpleTech Signature Mini 160GB External...
I have a mini simple tech 160gb hard drive that when I plug it in an error message about power surge on the USB port. What can I do to get the data off of the drive
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 17, 2010 | SimpleTech Signature Mini 160GB External...
External HD not recognizing USB ports as being Hi-speed ports
I have the same issue. I have 4 Simpletech Signature 250GB drives. They all worked fine at first. After about six months two of them started connecting at USB 1 speeds. It occurs on 4 different computers!!! The post about it being the computer assumes is wrong. How can it work fine for six months and then suddenly change. Also it occurs on different computers. I have submitted a tech support request with simpletech and will post the results.
Jun 14, 2009 | SimpleTech Signature Mini 160GB External...
Not detecting
hmmm..what operating system you using..
Oct 13, 2008 | SimpleTech Signature Mini 160GB External...
Acer-Veriton-M410-US3800P AMD Desktop PC - AMD Sempron 2.2GHz, 1GB DDR2, 160GB SATAII, DVDRW, Gigabi Logo
175 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
