Question about M-Audio Fast Track USB (FASTTRACK) Audio Input
Audio only in one ear
When i plug in a mic (through a tubepre with phanton power) i am only getting sound out of the left ear. how can i fix this?
Apologize onerepublic
Posted on Mar 03, 2008
Ok i had the same problem wat i did is wene i record somethin i duplicate my vocal and adjust volume to the right so u well have a vocal sound comin from the left and a vocal sound comin from the right thas only whene you have you headphones connected but if you plug your speakers you well be able to hear the full they just did that so wene you plug 2 mics you be able to hear one from the left and one from the right
Posted on Jan 20, 2009
Just moved to new location and hooked up i com. Am only getting sound in left ear. Have rechecked everything and all connections seem sound???
this is an oxmoron you cant have checked every thing
left and right ear audio on CBs come from a common mono signal
so the right ear signal is missing or the headphone on the right ear piece is busted
sherlock....
Nov 27, 2014 | Icom Ptt Over Ear Mic / Ear-phone For...
I also, have a shure microflex 150 condenser mic. We use it at the pulpit of our church for 2 years at least. The mic went dead. I replaced the 185 cartioide cartridge but the mic is still dead. D
It sounds like somebody turned off the phanton power on the mixer. Bring the main volume all the way down and turn it on, that should resolve the problem.
Nov 09, 2014 | Shure MX418/S Microflex 18" Gooseneck...
What colour wire does what with Samsung in ear earphones
This is an educated guess.
You should have 4 rings around your 3.5mm connector. From the tip to the base of the connector....
#1 - left audio - Black
#2 - right audio - Red
#3 - Ground - bare copper
4# - Mic/volume - green/brown
The wires for the left and right channels (pins 1 and 2) and the ground, (pin 3) should run from the connector through the volume control, to each ear piece. The mic/volume wire should terminate at that control. although it could connect to more than one place within the control.
You may be able to open the volume control, gently, and see which wire stops there and which continue on through.
I hope this gives you enough information to complete your project.
Dennis
Apr 22, 2014 | SAMSUNG EHS64AVFWE Stereo 3.5mm White...
I have an Asus P5QL PRO Motherboard and I'm trying to connect the FP audio and I need some help on how to connect it up properly. On the heaphones lead I have 4 connectors: EAR R EAR L RETURN...
Hi
Pin arrangement for Front panel Audio is usually:
Pin 1 Left MIC-IN Pin 1 right GROUND
Pin 2 Left MIC VVC (or MIC Power, or MIC BIAS) Pin 2 Right empty
Pin 3 Left R EAR (or R OUT) Pin 3 Right R RETURN
Pin 4 Ground or Empty Pin 4 Right empty
Pin 5 Left L EAR (or L OUT) Pin 5 Right L RETURN
This arrangement should apply to both the HD AA/FP or the Standard AC'97 Headers.
I hope this helps
Aug 28, 2011 | ASUS P5QL PRO Motherboard
My turtle Beaches work work with my turbo fire 2
they are not compatable... read your booklet that came with your head set and you will see if small print that it is not compatable with datel controllers. you can get a typical head set with mic. that comes with your cell phone as i have and with the plastic clip that comes with the cell phone set clip the mic part just above the foam cover over the turtle beach mic. (also turn off the mic. part of the turtle beach unit) then put the cell phone single ear piece into your left ear and then put on the turtle beack head set. due to the small size of the cell phone ear piece you will not feel it. then plug into your datel controller the plug from the cell phone head and mic piece. you will hear thru the turtle beach all of the game sounds, etc.. and thru your cell phone set you will hear you chat. it works and will do until datel or turtle beach comes out with a fix, if ever.
Jun 30, 2011 | Datel Xbox 360 Turbo Fire 2 Wireless...
Hi, my M-audio Project mix stop to send 48V phantom power, Do you know if had a fuse protector inside? Tks Wallace
A common problem is a person will plug in an unbalanced plug into an input. this often grounds out the 48 volts. Use ONLY balanced lines like XLR and TRS connections. There is NOT likely a fuse inside as the 48 volts have fairly high impedance driving the mic leads... around 6K ohms. Verify that the 48 volt control setting has not been turned off.
Apr 23, 2011 | M-Audio 99104074200 ProjectMix I/O...
I just got a tubePre and trying to connect the micro to my computer. Can anyone help me?
pre ams is either for mic or instruments..you can try connecting stuff to it----than from output to your sound card which probably is external as well ---and than from external sound card via usb or firewire to your computer
hope this helps
peace
Aug 11, 2009 | PreSonus TubePre Amplifier
Samson C03 Microphone using with Realtek HD Audio Manager
SEU MICROFONE PRECISA DE UM RECURSO CHAMADO PHANTON POWER QUE NADA MAIS é DO QUE UMA ALIMENTAçãO DE 48 VOLTS, PORTANTO NECESSITA DE UM APARELHO INTERMEDIARIO, COMO UMA MESA DE SOM COM ESTE DISPOSITIVO OU UM ADAPTADOR PHANTON POWER COM SAIDA USB PARA O SEU PC, NO CASO DA MESA TAMBEM é NECESSARIO UMA PLACA DE AUDIO COM CONEXãO USB EXEMPLO UCA 202 DA BEHRINGER , PODES CRER Só ASSIM FUNCIONA E SOM é MUITO BOM.
Apr 06, 2008 | Samson C03 Professional Microphone
M-Audio Fast Track USB (FASTTRACK) Audio Input Logo
531 people viewed this question
Top M-Audio Televison & Video Experts
Paul Bade
Are you a M-Audio Televison and Video Expert? Answer questions, earn points and help others
