Question about GoVideo VR3845 DVD Recorder/VCR
Go video dvd recorder vhs combo vr3845 - won't read discs - says unknown disc
Hi, all of a sudden my go video dvd recorder/vhs combo won't read movies anymore. it says "unknown disc" and then ejects them.
these are not recorded movies. real movies bought or rented from netflix. i sent my last movie back to netflix thinking that there was a problem with the movie, but i just got 2 more and it won't read these either.
any ideas on how to fix this? thanks. mary
  • 1 more comment
  • sahaj1407 Sep 15, 2008
    I have the same problem too, but in addition, I copied all my old VHS onto DVD, and the DVD's will only play in my GoVideo machine?
  • scineman Nov 26, 2008
    Did you ever find a solution?  I've cleaned mine a million times and still most dvd's won't play.  Even tried the hack to make it a multiregion machine (press set up on your remote, scroll down to the padlock and press 0000 on the remote) My problem is with mailed blockbuster DVD's.  80% won't play.  From what I gather, there is a firmware update (vr3845a.iso) that could possibly fix this, but since GoVideo is no more, I can't find it anywhere (not even on limewire or any other P2P).  Are Lite On DVD recorders the same?  If so, which Lite On model is the equivalent of  the GoVideo 3845?  Any help would be appreciated as I would love to watch my DVD's with my surround sound system instead of only in stereo from an old DVD player.  Are there any other combo units that have a composite out for both the DVD and VCR like the GoVideo?   New machines still don't seem to upconvert the VCR to composite or HDMI and require you to use RCA out, so what's the point in getting a combo unit when you still have to make 2 connections out to your tv?
  • Anonymous Mar 31, 2014
    Movies keep stopping and reloading through out the movie
  • 4 Answers
FIRST UNPLUG THE UNIT FROM POWER !!!!! The problem is dirt/dust/****/crud/stuff on the tiny, little ***** laser lens. Remove the case screws ( 2 on each side, some in the back) with a correct size driver. The cover must be pulled open at the bottom, side to side a tiny bit ( use a hand on each side) to allow the cover to lift up at the rear, it must come up quite a bit as if it is hinged at the front and THEN pulled back out of the front panel. Set the cover to the side. The DVD reader/Burner is covered with a small black cover, it is held on with two TINY screws, STOP!!!! Get yourself the CORRECT size driver at Fry's or Radio Shack, DO NOT get cheap here!!! Remove the two screws and find the two plastic grip tabs, push them to release and lift the cover. There is the laser! It is a tiny blue lens about the same diameter as the tiny screws. find a very, very well washed CLEAN 100% cotton T-shirt. The softer the better, get 70% or higher rubbing alcohol, pull the fabric over the tip of the finger and wet with the alcohol. VERY GENTLY wipe the lens 4 to 5 wipes and the 3 wipes with a dry spot. That should clean the lens. USE NOTHING ELSE!!!!!! The lens tracks back and forth on two tiny bars. The stuff I use is WD-40 wet on a Q-tip swab. Go to a safe place to spray the WD-40 on the Q-tip. The lube should drip. With the Q-tip apply the lube to the tiny bars at the ponts of rider contacts and wipe the bars too. Put the top of the burner back> BE CAREFUL!! Use a magnet driver and then repower and try to read a known good dvd. You will have to do this more in the future, you understand, dist dirt etc in the air. Put the top back on. Enjoy.
Posted on Sep 26, 2008
Trying to record to disc from VHS After recirding 8 copies, it now reads "Unknown disc, Please check disc" This is a Go-Video VR3845 Unit.
I answered this question previously and the solution remains the same;
how long have you been using the player and has it ever accept blank DVD-R discs in the past.
The problem might be as a result of weak laser (lens) or the blank discs inserted might not be compatible with player.
When the laser(lens) of a player becomes weak, it will not be able to read blank discs. It only takes a very strong laser to read/accept blank discs. If it happens that the laser (lens) is the cause of the problem, then it means you will need to replace the laser (lens) to a brand new one to be able to read blank disc. Though the player might be playing DVD and CD, note that blank disc is stronger when it comes to reading from the laser (lens), it requires sharper laser. I hope you understand this.
So, insert a CD into the player and observe if it will play.If it plays, then its obvious that your laser is very weak.
Concerning the incompatibility issue, I hope you are aware that there are various kinds of empty DVD discs such as DVD +, DVD -, DVD RW. Try any of this empty DVD discs as one of them as to be compatible with this DVD recorder.
Amongst the two topics discussed above, one has to be the cause of the problem. So its up to you to figure out which is the cause of the problem.
I hope you understand the above....
I wish you good luck.
Apr 08, 2011 | GoVideo Go Video VR3840 DVD Recorder/VCR
I have a Magnavox Digital Video Disc Recorder & Video Cassette Recorder. Model# ZV427MG9 A. When recording from a VHS home movie tape to DVD there is a high pitch squealing sound. When playing the DVD...
U play another movie like a Hollywood movie DVD disc play on it have no squealing noises wright?Yes,than the blank DVD discs batch u have is bad.Tries buy another batch DVD blank discs,tries recording again should solved this problems.
Mar 16, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
I was copying vhs tapes to dvd successfully and then it started saying disc unknown.cant figure it out
this issue calls for a little info from my brain
have you tried to reset the recorder if so is there firmware updates for the burner
have you changed the brand of dvd disks lately if so sometimes a different disk has issues for some odd reason i have run into this problem before
Jan 03, 2011 | GoVideo VR3845 DVD Recorder/VCR
I don't know if my first REQUEST for Assistance was received, at any case, I REQUESTED to find WHY my GO.VIDEO COMBO Player is NOT READING any of my blank DVD DISC( SONY, IMATION, MEMOREX, DVD+R ), IT KEEP...
If there is nothing on the disc, it will read, "no disc". It will only read and/or identify discs with media loaded or burned onto it. Your unit is a player, not a DVD+R (recorder). Can record VHS, but not discs.
Jun 30, 2010 | GoVideo Go Video DVD/VCR Combo
I have a rca drc 8295 and have old family movies on vhs and want to record to dvd. what dvd do i need dvd r?
Use the DVD+R Disc better for transfering recording.Read ur DVD Recoder/VCR combo owner manual,before u do this,for the correctly setting to do transfering recording.
Jun 23, 2010 | RCA DRC8295 DVD Recorder/VCR Combo
RCA 8295n dvd-vcr combo starts recording from VHS tape to disk and then stops.
Is the VHS tape a store bought movie or show?
MacroVision and other copy protection systems are put into store bought tapes and discs of movies and shows, and are read by your recording equipment. Once it reads this, it stops recording.
Does the screen turn red before it stops? This is one of the indications that MacroVision is stopping you.
Aug 28, 2009 | RCA DRC8295 DVD Recorder/VCR Combo
HOW DO I RECORD A DVD TO A VHS ON A VHS DVD COMBO BY PHILIPS
Cannot do this on a combo unit. There is a chip that senses copy protection and prevents recording a copy-protected DVD to a VHS and vice-versa. Solution: Use an outboard DVD player or an outboard VHS VCR and try the recording with the video routed through a "stabilizer" box. The stabilizer (about $30 or less on Ebay) defeats the copy protection on MOST DVDs, but not all. It works with Netflix DVDs. Route the audio as usual. Audio is not protected.
Dec 15, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Dvd
Hello?????????! Where have you been living these last five years?? Under a rock in Podunk, Iowa?? Remember when VHS was duking it out with Betamax back in the 1980s? VHS eventually won in 1988. Now it is the 21st century and BlueRay and HD-DVD just concluded their war for supremacy of the new recording/viewing format.
In other words, your HD DVD will not play on your DVD machine. You can either stick with DVDs or buy a new machine. Read the paper; listen to talk radio, listen to a podcast; BE INFORMED.
Sep 14, 2008 | GoVideo Go Video DVD/VCR Combo
GoVideo VR3845
I too have this problem, will read regular CDs but no DVDs. I get the sme message, then the disc ejects. Is there a RESET function?
Jun 30, 2007 | GoVideo VR3845 DVD Recorder/VCR
GoVideo VR3845 DVD Recorder/VCR Logo
535 people viewed this question
Top GoVideo Televison & Video Experts
Marvin
Marvin
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
